Question about Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop
My Dell Inspiron 531 will not boot. It runs on Windows Vista Home Premium 31 bit. I have attempted to reload the operating system DVD I received with the system but during this process it asks to load the drivers but when I insert the drivers and utilities DVD I received with the system, the response is "does not recognize drivers" so I cannot complete the reloading of the operating system. I don't know if the operating system on the computer is corrupt or the hard drive is the problem and would appreciate any assistance as I am at the end of my rope on this problem. Any suggestions or info on problems Dell has had with the situation would be appreciated.
Thunder55
  • 318 Answers
SOURCE: PC will not boot from CD drive
Download the six winxp install floppies,,from bootdisk.com and install that way.
Your PC was not meant for XP it was meant for Millenium at most.
But if you load through floppies and then use the cd you should be OK
Posted on Jan 19, 2009
larsonhome
SOURCE: No Ethernet After Reloading WIndows XP and Drivers
Sounds like you need a driver disk for your motherboard, this usually will load and install the devices you are referring to. This may not have been included with a pre-loaded computer. Search on the Dell website or get the make and model of your motherboard and search on a computer with internet access for the appropriate drivers. This may solve your problem but if it doesn't then we can go from there. Sometimes these come on a floppy but with newer systems they are on a disc.
Posted on Mar 12, 2009
jassji
  • 105 Answers
SOURCE: I want to replace my hard drive in a dell
If you have the oprating system disk with you thats the most convenient way to install the OS. Else the only option left for you is to contact dell and then order a new OEM disk which costs only $10 - 11 which is very less as compared to the price of a new OS
Posted on Jul 15, 2009
  • 17 Answers
SOURCE: dell dimension 5150 ethernet problem
Okay, so it seems you installed Microsoft Windows XP Home on a what was Media Center Edition installation, and the ethernet is no longer worker.
Please refer to dell.com's support section, enter your model, and download drivers that you need.
To find drivers you need, Go to start --> control panel and then go to (under classic view) system --> the hardware section, open up device manager, and then look for ones with a yellow big question mark, and get those drivers from dell's website. Burn these drivers to a CD on another computer, or use a USB flash drive if that does work.
Good luck.
Posted on Jul 16, 2009
asingh1225
  • 122 Answers
SOURCE: Dell Inspiron 531 gets me crazy..
hello, sounds like memory issue, I would say if you have more than one stick of memory in it remove one at a time and try it again.
also while you are at it reset BIOS by remove battery from motherboard and/or switching jumper setting.
hope it helps.
regards
Amar Sondhi
Posted on Dec 05, 2009
Inspiron 531 / vista restore
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios. Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system. Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd\dvd. Hope this helps.
Dec 31, 2012 | Dell Inspiron 531 Athlon 64 X2 4400+...
Hp officejet j3640 not working on windows vista. I had the printer working and when disconnected when moved it doesn't work. I've tried uninstalling and reinstalling the driver several times....
first check your is working or not
then open control panel - administrative tools - services - printer spooler services - double click the services - click stop button - next click start button - choose automatic then give the print if not coming connect other pc to ur printer check printer
Oct 29, 2011 | Dell Inspiron 531 Athlon 64 X2 4400+...
My dell inspiron 531 PC just keeps beeping and will not boot up!
The beeping is called a beep code, you may be able to check the connections on the inside but only if you know what you're doing. You will most likely have to take it in the be serviced.
Jul 28, 2011 | Dell Inspiron 531 Athlon 64 X2 4400+...
Show a blue screen
You need to go into the Setup Utility or BIOS when the computer boots. You need to enable the computer to boot from the CD drive, and set up boot priority with CD Drive first, then Hard Drive HDD.
Then it will boot the disc.
Dec 17, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
hope it helps.
regards
Amar Sondhi
Dec 05, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Dell desktop vista 531 computer: dvd wont burn/copy or anything?
Have you tried using another burning software ? Try with
http://www.softpedia.com/get/PORTABLE-SOFTWARE/CD-DVD-Tools/Windows-Portable-Applications-Power-Laser-Express.shtml
Nov 27, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
No desktop display
Ok. Try pressing ctrl shift and esc at once. Then go to file- run (new task) and in the box type explorer.exe, then press OK. This should solve it.
May 02, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop Logo
206 people viewed this question
Alun Cox
