Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Engine will not start i have spark also changed fuel filtter
  • Parks Optical Master
  • 7,482 Answers
Check your fuel filter if you have one.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 16, 2010
1996 pontiac firebird will start up and then it will die . The fuel pump is working.
Well the fuel filter would be an easy choice, but it could be something electrical.
You'll need to figure out if you are missing fuel pressure or spark when it stops running to know how to proceed.
Feb 28, 2014 | 1996 Pontiac Firebird
Cold start is fine but after warm start the engine misses and sta
I would start by changing the fuel filter then check to see if there is any water in the fuel if those are ok see if a critter built a nest in the air filtter or the exhaust.
Jan 31, 2010 | 1990 Mercedes-Benz 300 Diesel
Not starting and metalfileing in oil filtter
Something is really wrong.Your gears engage correctly? plug on the spark plug's cap a new spark plug and ground it on the engine and crank it to see if there is any spark.If it is then check your carb.
Jun 13, 2009 | 2003 Yamaha YZ 250 F
Jag diesel x-type fuel filter change
change fuel filler as normal then connect fuel feed from tank connect injectors leak off to fuel fillter leaving the rail flow pipe off this is the midddle one with the arrow pointing out
connect a piace of clear plastic pipe to this connection and slowly suck the fuel through the filtter and half way up pipe you can see this happen stop sucking the fuel will flow back to fillter take the pipe you were sucking through off and connect the feed to rail pipe turn on and crank engine she will start immediately
Mar 14, 2009 | 2004 Jaguar X-Type
Won't start
1996 sidekick wont fire up and start
May 20, 2008 | 1996 Suzuki Sidekick
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
67 people viewed this question
Top Parks Optical Garden Experts
Roland W VanLue
Roland W VanLue
Renee Knafel-Bullock
Mike Squire
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
