Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
The ref is running but not getting cold, the compressor seems to run. the freezer does not get cold either
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: GE PROFILE FRENCH DOOR 3 YRS. OLD
sorry you have a bad control board
Posted on Aug 17, 2008
joecoolvette
  • 5660 Answers
SOURCE: Upright frig/freezer not getting cold, compressor running
1.My first suggestion, is to clean out the compressor area located at the bottom of the refrigerator. Refrigerator unplugged from power. Remove the cardboard panel from the bottom, (Watch the water line), and use a vacuum. I also bring the refrigerator towards an open door, and use compressed air to blow it out, afterward. You'd be surprised how much gunk builds up here, and how cleaning it out will help your fridge tremendously! (Good tip for air conditioners also. Power unplugged, case cover removed. Use a garden hose to flush the fins out. Let it dry, reinstall the cover) 2.Your refrigerator may be low on Freon. This requires a professional to purge the system, and reinstall Freon and lubricant. (Oil)
Posted on Jun 15, 2009
heatman101
  • 43501 Answers
SOURCE: refrigerator does not get cold
The condenser fan at the compressor may be bad and it contributed to the compressor not running...
Turn it off completely and let is cool over night and then plug it back in and see if the fan runs and if the compressor runs...
If the compressor runs but not the fan then check for voltage going to the fan and replace as needed...if there is no voltage then trace bad to see if the main board is bad...
Start relay and capacitor may be bad if the compressor does not run after getting completely cooled down...
Check out these tips that I wrote about that... it is a greatplace to start trouble shooting your unit...and something that you can dorather then calling a repair person to do a simple thing for you...
heatman101
Posted on Nov 09, 2010
heatman101
  • 43501 Answers
SOURCE: the ref.. is not getting
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 08, 2011
Maytag fridge not cooling
If the ref or freezer is too warm and you turn the dial to make it colder the compressor should come on. If the ref or freezer is not cold like you say the compressor should be on all the time. You should hear it, but you can definitely feel it and it should be very warm after a short while.
If the compressor does not get warm unplug the ref with the compressor running and plug it back in immediately. A good compressor should not start up right away.
If it is running and not getting warm and does start right up after unplugging it and plugging it back in it is inefficient and not compressing the freon gas enough and therefore not cooling enough.
The fan in the freezer should be running as should the fan under the refrigerator.
The condenser should be warm and the fan should be blowing[drawing] air across it when the compressor is on.
You don\'t repair compressors and to recharge them correctly is expensive.
May 01, 2013 | Refrigerators
Cooling quit suddenly in both freezer and fridge side. Pulled out unit and sounds like compressor is running and compressor fan (across coils) is running. Circulation fan in freezer is not running....
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 30, 2011 | Frigidaire FRS6R5EMB Side by Side...
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Compressor runs less frequently freezer warms between cycles
any further question let me know.
thanks,,
Mar 29, 2009 | GE Refrigerators
My Kenmore fridge, Model 596-58692890 is not cooling and I've lost use of the water/ice dispenser. The motor and compressor seem to be working but the cool air is not blowing. What part might need to be...
HI,
thanks,
Mar 24, 2009 | Kenmore Refrigerators
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Fridge not working, freezer is
First, I think it’s important to know that the Ref area has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting up to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
If you want mor info to DIY check out: ronbuice.com
Dec 16, 2008 | GE GBS22HCP Bottom Freezer Refrigerator
Running fine but blowing warm air
"it seems to work fine but will not get cold"
Not sure how it can work fine and is not cold. When you say work fine, is the light on and the freezer fan blowing but is the compressor running?
Unplug the Ref and wait about 30 min or so, plug it back in and listen for the compressor to start running. You should be behind the Ref to hear this. If you don't hear it start running then you may hear a clicking noise. This clicking is a problen with the compressor start relay. If the compressor runs but still is not cold then it could be low on coolant.
Dec 16, 2008 | Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
52 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
