Have somehow lost all our digital channels & when I try to rescan them it still doesn't work
    President:
  • 1,140 Answers
Sounds like an Aerial fault. Obviously, the first thing you should do is check the the aerial connection to the TV.
Simple test for the aerial is to connect another television to the aerial connection for the faulty TV. If the second TV is OK, it's a faulty TV. If neither work, it's an aerial or aerial cable fault. If you don't have a spare to test with, can someone loan you one for a short time?
If neither work, check the aerial itself? Has it moved in the wind? Is it still pointing the right way (towards your transmitter). Has an element (one of the metal fins) broken off?
Try this and post back.
Posted on Oct 16, 2010
These answers do not fit my question. One day, on three different sets in my home, where I have received NBC for years just quit working. Did NBC quit broadcasting? It is not snowy, etc, it is just no
Ok This is what I found out and hopefully found your solution..
Have you heard of Double Rescan?
The Federal Communication Comission Designed a Process called double rescan.
Double Rescanning erases and thenreprograms the channels in the converter box an digital TVs memory.
To Double Rescan, you will first need to disconnect the antenna from the converter box or antenna.
Then disconnect the converter and or digital tv power supplies from the wall. Wait a minute before plugging them back in. The antenna should still be disconnected.
With the antenna disconnected run the channel scan function on the coverter box or digital tv. When the scan completes you will have completely removed any channel data the converter box or digital tv, had in its memory.
Now it's time to rescan for real.
Do this by reconnecting the antenna to the converter box or digital tv and running the channel scan function again.
Thus the double rescan is born.
If the double rescan doesn't work, then try some tips and tricks to get your converter box up and running..I will have to look up the url again that has the tips and tricks...
If the double rescan doesn't work let me know and I will look up more options..
I really hope this works..
Dec 18, 2014 | Samsung Televison & Video
Some of my channels were lost after I TRIED RESCANNING I I LOST
Check your antenna direction (antennaweb.org or tvfool.com are good sources for signal direction). When I lose channels, it's a digital signal that came in with "bad signal" strength and my external antenna has rotated in the wind. (Oddly another TV in the house doesn't seem to lose the signal as easily even though they share an antenna.)
Also check the weather conditions and time of day. I've gained distant channels when scanning near sunrise or sunset and lost others during thunderstorms.
I hope this helps.
Jun 07, 2010 | Vizio L32 32 in. LCD HDTV
I have lost a few asian channels on Starview
you are doing well to have any channels at all as all the other people have lost all sports and movies so i would delete the channels that are scrambled and then rescan you must delete the scrambled channels before you rescan
May 13, 2010 | StarTech.com StarView SV211K 2-port KVM...
Starview channels missing
you should not have factory reset when you lose a chnl delete the chnl then rescan you never need to factory reset you lose the flash or newest update you had installed reflash your box and delete the chnls that are scrambled only and then rescan
Feb 20, 2010 | StarTech.com StarView SV431USB 4-port KVM...
How do i reset my nokia d box i lost some channels so i tried to rescan but now i can't receive any channels
i catched the remote & the button for the d-box on the remote . catched it again , but dont know which i catched & it went off . tried re-booting it & the remote wont work it . no matter which button you press it wont register on the box . it works manualy , but wont work with the remote . can it be solved ? . brian
Jan 26, 2010 | Televison & Video
Lost all digital channels - Sony KDL-52W3100
Use ur original remote of the tv u want setup to the DTV box go menu switch cable back to air
reseption.Set tv channel 3 hook up the DTV box and rescan the channels u have it.
Aug 15, 2009 | Televison & Video
Lost several stations afyter conversion like al PBS stations. Is there something we can do?
Try rescanning for new channels. Some stations changed their Digital transmitter frequencies when they took their Analog transmitters off air. Rescanning will relocate those transmissions.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Local channel went digital, lost signal.
You need a digital to analog convertor box to recieve the digital signal.
All UHF+VHF signals will be digital starting in June.
Thanks for using FixYa - a FixYa rating is appreciated.
Feb 20, 2009 | Televison & Video
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
Electro Med Services...
