Question about Toshiba Televison & Video
My Toshiba television is making a popping noise with scattered white lines on the screens. It is not constant; but increasingly frequent. What is the cause
    Top Expert:
  • Toshiba Master
  • 74,377 Answers
Hello
If there is a poping sound inside the tv, some type of arcing takes places inside it. So many white lines across the screen can be caused by over screen voltage. You should contact to a service technician to rectify the problem.
Posted on Oct 16, 2010
White lines that are constantly on will go away for a few seconds then pop back up.. Mitsubishi 73" model number WD-73640
You need to replace the 4719-001997 DLP Chip. this should solve the issue.
This chip can be expensive so look around before you purchase. This is a common problem with these TVs, both white lines and white dots. You can find out how to replace the chip by going to this website: http://www.fixyourdlp.com/2012/09/04/solve-the-mitsubishi-wd-73640-white-dot-problem-with-a-new-4719-001997-dlp-chip/.Hope this helps
Feb 27, 2013 | Televison & Video
White lines on screen
It is a problem in the vertical circuit of the set---most likely a bad filter cap connected directly to the vertical output IC chip.
It may be a do it yourself repair if you are handy.
Let me know if you have questions.
SD TECH
Jul 24, 2010 | Toshiba 32A33 32" TV
Fine line down centre of screen
call Toshiba ASAP if you still have warranty, the TV needs to be replaced. The line will get worse!!
Feb 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
27"tv sharp analog
Good day.
Refering to to mr walts inquiry and if it is, maybe you are having some issues in your vertical circuitry. It may be loose that it needs to be resoldered and other filter capacitors within the vertical section.
chris
Mar 22, 2008 | Sharp 27C-240 27" TV
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Plasma Tvs
When switching to STBY raster remains and buzz noise is heared from the speakers
Cause: +B voltage (103 V) does not switch-off. Remedy: Replace defective C541
Ticking noise and line in picture
Transistor 7381 (BC848C) defective when hot
Dead with ticking noise from line
Replaced C622, C604 and Q509
Nov 26, 2007 | Televison & Video
White noise on screen with screeching sound
white unstable lines plus screeching noise it basically due to loose contact at input 1 like antena or cable wire or socket loose. 2 loose contact some where in your tv. 3 loose contact in some electrical thing. 4 loose near tuner section. hope this will help.
Oct 01, 2007 | Toshiba CF32F50 TV
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Apr 12, 2007 | JVC AV-32F704 32" TV
Televison & Video Logo
127 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
