Question about Gateway Computers & Internet
Gateway GT4015E crashed. LCD went crazy then could not get keyboard response. Reset does not work screen does have "no input" with color bars.
    Sergeant:
  • 284 Answers
On board video card died, if its intergrated, if not time for a replacement video card. might have not completly crashed, could be just video. always make a backup of your vital files :)
Posted on Jun 03, 2008
Turned computer on, now screen is pink? How do I reset the color. I've already tried the "color adjust" buttons at the bottom of screen.
Verify your data cable if it is firmly planted on the sockets.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 12, 2011 | ViewSonic VX1935wm LCD Monitor
I have a Gateway FPD1760TFT LCD color monitor. I
What is the display resolution you have set in your display properties? For this monitor it should be set to 1280x1024 pixels, which should give you proper screen geometry.
Jan 24, 2010 | Gateway FPD1760 17" LCD Monitor
No pic on monitor-no response to keyboard
Please check your power cord on your monitor, make sure each end is plugged in tightly. If it is on a seperate power strip, make sure if it has a breaker , that the breaker is not tripped. Are there any indicator lights on, on the front of the monitor. If so what color are they?
Mar 14, 2009 | Computers & Internet
No display lights
Run the PSA Diagnostics and Obtain the PSA Error Code
To run the PSA diagnostics and obtain the PSA error code, perform the following steps:
Shutdown the computer.
Press and hold the <Fn> key, then press and release the power button.
Release the <Fn> key when the lock lights above the keyboard begin to flash or Diagnostic boot selected is displayed in the upper right corner of the screen.
Release the <Fn> key.
The PSA diagnostics sequence begins.
After approximately 2 minutes the system produces a number of alert tones.
After the alert tones, the system produces either a series of low beeps or error codes.
Note:
PSA diagnostics will prompt for input during some tests. The resulting error message does not necessarily indicate hardware failure.
For example, input is required during the color bar test. Failure to input a response will eventually result in a timeout error: 1000-0333 Graphics test timed out waiting for keyboard response. This does not indicate a graphics failure has occurred.
Note the sequence of beeps or error codes.
Initialize LCD BIST Diagnostics
You can initialize the LCD Built-in Self Test (BIST) in two ways, depending on the revision of Pre-boot System Assessment (PSA) diagnostics:
PSA versions 3019 and greater run LCD BIST immediately after failing the color bar test, via user input of <N> or waiting for it to time out prior to generating the 3-3-3 or 3-3-4 error. PSA version 3019 became available in November 2005 on various Dell laptops. The PSA version is upgraded with the BIOS.
With older versions of PSA diagnostics prior to November 2005, LCD BIST runs after responding with a <Y> after receiving a 3-3-3 or 3-3-4 error code.
To initiate the LCD BIST on PSA versions 3019 and greater:
Boot to the PSA Diagnostics.
Watch the screen and listen for the color bar test prompt tones emitted by the PSA Diagnostics. If the screen is visible, one will see the PSA diagnostics draw a series of multi-colored bars across the screen. When completed, a prompt asking if the pattern was seen appears, accompanied by a brief series of tones.
Press <N> or wait approximately 30 seconds to fail the color bar test.
Watch for the LCD BIST color generation and listen for the beeps every 2 seconds that indicate LCD BIST is running.
LCD BIST runs for approximately 20 seconds, then stops. The 3-3-3 or 3-3-4 error code is then displayed when the LCD BIST is complete. If LCD BIST does not initialize, then the system may not have been upgraded to PSA version 3019.
To initiate LCD BIST on systems with PSA versions prior to 3019:
The system emits a 3-3-3 or 3-3-4 PSA error after failing the color bar test. Wait for two iterations of the failure code and then press <Y>.
Note:
On a working LCD, the PSA diagnostics shows the following message:
Error Detected, continue testing? Yes or No or Retry.
Watch for the BIST color generation and listen for the single beeps that indicate LCD BIST is running.
Patterns of flashing color should appear on the screen. With every color change, an audible beep is heard. If the patterns of color do not appear, and the beeps are audible, an LCD failure may be the issue. If the patterns of color appear, a video card or motherboard failure may be the issue.
IF AN ERROR IS INDICATED, PLEASE CALL DELL SO YOU CAN SEND SYSTEM TO SERVICE DEPOT FOR REPAIR (WE'VE JUST TRIED TO ISOLATE ISSUE TO SEE IF ERROR IS CAUSED BY HARDWARE OR SOFTWARE, OR JUST SOME CONFIGURATIONS)
Thanks and Goood luck! =)
Jan 03, 2009 | Dell Inspiron 9100 Notebook
PLZ HELP SIDEKICK 3 SCREEN WENT RED AN GREEN
reylakers-
You can try and reset the flex cable on the lcd.
follow these instructions.
Fix Sidekick White LCD Screen
If that doesnt work then a new lcd screen unit will.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
Jun 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Lcd will not turn off
same tv similar issue
the menu screen is garbled and the buttons don't work
have to input the numbers on my radioshack remote pushing a 1 then a 3 etc
must unplug cord to reset logic board I was told
great clear picture!! lisa
Apr 29, 2008 | Gateway LCD26TV 26 in. Television
Pink screen
When the "pink screen" happens on my Polaroid FLM-1911 TV, I unplug the power cord from the back of the unit, wait 30 seconds, and replug it. This fixes the problem.
Oct 23, 2007 | Televison & Video
Computers & Internet Logo
71 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
