Question about Sony KV-32S26 32" TV
I have a Sony tv (32v-s15) and the picture was slow to appear (even though the volumn was fine) so I turned it off, then on again, and it worked. The next time I tried to turn it on, the whole thing just shut off and I cannot get it to turn on now--no power at all. I have the back off, and the small fuse looks ok. What can I do?
    Top Expert:
  • Sony Master
  • 74,243 Answers
Your TV has something shorted inside, and is not a direct short. If it was a direct short, the fuse have been blown. Through my experience I advise you to replace the Picture Tube base socket, which can be located at the picture tube base card. Some CRT base cards will poise this type of problem. as their contacts will worn out with time.
Posted on Oct 16, 2010
Why does my Sony Google TV NSX-46GT1 46 in. HDTV LCD TV powers up, displays application screen on bottom, makes a computer chime and shuts off completely, and starts the same process over and over aga
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 25, 2014 | Sony Google TV NSX-46GT1 46 in. HDTV LCD...
The TV typically works fine, however lately without any prompting when turned on sound is there without the picture. Turning the set on/off repeatedly used to help and eventually the picture would appear....
Make a fist bang on the tv bazel frame.See if u get a picture or flashes of a picture?If Yes,ur tv have cold solders joints on the tv video board,that the video board connected to CRT- tv picture tube.U have a soldering iron and a roll of sloders,also can u do basic soldering?Yes resolder all the Video sockets pins Holes that connected the video board to the CRT tube together.Tv shoud have picture again.
Jan 06, 2011 | Panasonic CT-36D30 TV
My volumn doesn't work when using the HDMI cable
Your TV and the cable box may not be compatible via HDMI or the digital audio format of the cable box is not set to PCM (contact your cable provider for information on how to change this on your cable box... too many models to speculate). The easiest solution is to use the component connections on the box and the TV (5 wire - Green, Blue, Red, White, Red). This will give you HD and eliminate to question of compatibility. I hope this was helpful, best wishes.
Apr 22, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a sony kdf60xbr950 rear projection television. the bulb has recently been replaced. one day while programming the tv to work with a universal remote it stopped turning on. when i attempt to turn...
depress the pin that the lamp cover should and the picture returns. never will i buy sony ever again. their tech support could not tell me to push a pin down when i described my problem to them and told them the led light pattern? i bought sony because i felt like i would have support for my products. boy was i wrong. now even though the tv works again it suffer from a blue blob across the screen now. perhaps the pin is not depressed all the way.
Apr 08, 2009 | Televison & Video
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
SONY KV19TR20
I found this at another site. I don't know what the "infamous" problem is, but you might consider it:
Sony TV with bad butchered soldering: (From: Repair Brief #81: Sony KV-19TR20 Color TV - No Reception).
The final example is of a Sony TV that had the infamous tuner/IF box solder problems. This is normally a fairly easy repair, especially for this particular model where the IF box (which was faulty in this case) is readily accessible without taking the whole thing to bits. Once repaired, like the RCA/GE/Proscan TVs with similar solder problems, the result is a solid reliable TV. However, the friend of a friend who had attempted to replace it, apparently used a Weller soldering gun to do the fine soldering, leaving nearly every pad detached or missing. Fortunately, only the pads appeared to have suffered and after 20 minutes and several jumper wires, this one was healthy again.
Found at: http://www.repairfaq.org/sam/tshoot.htm
Nov 19, 2007 | Sony KV-32FV27 32" TV
Tv reacts very slow
the problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Sony KV-32S26 32" TV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
