How do i restore factory convergence settings for the samsung sp54t8he
  • 37 Answers
HELLO HOW ARE YOU?? YOU HAVE TO FOLLOW THESE STEPS:- open menu then go to settings then go to last option of this program it may be named as restore factory settings or formate phone select it and give your password then switch off your phone after 2 minutes switch it on your work is done thank you, , have a nice time thanks for using fixya
Posted on Oct 16, 2010
How do i restore system factory settings on a samsung R50 PC
Method one:
<1>. Press and hold on Esc key, and then start Samsung laptop
Note: Please don't loosen your hand on Esc key until the Samsung laptop starts with restore system.
<2>. Find Samsung Recovery Solution program, and run it. Or Enter Menu window.
Note: Samsung Recovery Solution is system restore program provided by Samsung. Used for Samsung password recovery etc.
<3>. Press F11 to restore Samsung factory setting.
Method two:
As we all know, Samsung laptop is taken with one function that Samsung factory reset with one key. Just start your Samsung laptop and press F4 or F7 at the same time. And Samsung laptop will run system restore program automatically.
May 21, 2016 | Samsung Computers & Internet
How do i restore samsung x10 to factory settings?
Hi! Welcome to www.fixya.com.
Click "Start" and then "All Programs."
2Click "Samsung," and then click "Samsung Recovery Solution." Click "Samsung Recovery Solution" again to launch the Samsung Recovery Solution program.
3Click "Restore," and then select "Complete Restore."
4Click the empty circle to the left of "Complete Initial Status," and then click "Next." The computer will automatically restart.
5Click "Agree" when the licensing agreement appears on the screen.
6Click "OK" after the computer restarts to begin the restoration process. When the process is complete, a dialog box will appear on the screen telling you the process is complete and that you can click "OK" to restart the computer. Click "OK." When the computer restarts you can begin setting up Windows.
Read more: How to Restore Factory Settings on a Computer System ' eHow.com http://www.ehow.com/how_7213487_restore-factory-settings-computer-system.html#ixzz1Sb728twX
Hope this resolution fix the problem on your computer.Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | Samsung X10 XTC 1600 Notebook
How to reset samsung star to default factory
pls help me how to restore samsung mobile phone s5233w factory setting code
May 04, 2010 | Samsung Star GT-S5233 Cell Phone
Samsung HCM4215w has wavy red lines and bowtie effect
Are you saying that after installing a new convergence board, you still have the same issue? If that's the case, another new board isn't going to resolve this. Also, you can't do a factory reset. Doing that would lose all the convergence and geometry data in the TV and would require a qualified technician hours of work to restore the settings. If you've installed a new board and have the same problem, suspect a problem in the TV's power supply. All convergence circuits require 2 voltages to operate. There will be a postive and a negative voltage of the same value. If you're missing either of these voltages, your convergence will never work properly.
michtech
Feb 17, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung hcp-4752w
With power on, press Mute-1-8-3. That will get you into convergence mode. 1 sets factory default convergence. Avoid pressing 2 - it resets everything. 3 restores the last saved settings, 4 switches among fine adjust, line adjust and grid move. 7,8,9 - select R,G,B. The three keys below those turn RBG on/off.
Self-focus to save the settings. S-Mode to exit.
It can be a REAL headache, but take your time, and you'll get it done.
As an after thought....if you have a need to manually adjust the convergence, you probably have something wrong - unless you've just replaced parts and are doing the initial convergence.
Dec 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Samsung remote control acces
Key Functions
7,8,9 = select R, G or B
+100,0,PRE-CH = mute R, G or B
INFO = test/normal
4 = shifts from point to line, grid move
2 = restore factory
SOURCE = H/V select
ADD/DEL = Save
S.MODE = exit
MUTE = cursor forward
P.MODE = cursor back
Volume +/- = moves convergence left or right
Channel +/- = moves convergence up or down
1 = zero's all convergence settings (ugly!)
U/D/L/R = move cursor
SELF FOCUS = saves the convergence adjustment - do before exiting
Oct 28, 2007 | Samsung HC-P4752W 47" Rear Projection...
Convergence settings
Key Functions
INFO = test/normal
2 = restore factory
SOURCE = H/V select
ADD/DEL = Save
S.MODE = exit
Good luck.  I let a sub-standard service joint work on mine - they replaced the OEM chips with a higher wattage equivalent, and I've had nothing but problems ever since.
Oct 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
