Question about Brother DCP 115C All-In-One InkJet Printer
Unable to Clean showing can't see anything lodged in printer. Haven't done nothing to cause any problems. Although did have a leaky ink cartridge. Does this mean my computer has now had its day !
Display at the printer troubleshooting and routine maintenance chapter in users guide
Posted on Oct 17, 2010
I refilled the ink cartridges on my canon mp250 printer. Now the ink lights will not quit flashing and I am unable to print anything. I tried resetting according to instructions provided by canon and it...
How much time you have done refilling a same cartridge? You shouldn't refill a same cartridge more than three times. Make sure that the cartridges are OK. May be the head of the cartridges are not in good condition. You may need to replace cartridge. Check that you have installed the cartridges properly or reinstall it. Align the cartridges. If it doesn't solve your problem then you have to replace the cartridges. Using original cartridge always is recommended.
Jun 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hp Photosmart C5180 I am unable to get Light magneta and magneta cartridge to work. There is ink in the cartridges. All other work fine. the self test page shows no solid color bars under these two. I have...
Greetings the easy cleaning in the back of the cartridges have a metal connectors should be clean and not be exposed for anything ben ink. Well to solve the problem of the magenta who spends a lot is that you get a new cartridge and inserting it as many times you buy to fill and the ink is so solid that nothing comes out of ink.
Jan 29, 2011 | HP Photosmart C5180 All-In-One InkJet...
My Brother MFC5840CN all-in-one printer is saying "Unable to clean" but i cannot see anything stuck in the printer and the message will not clear - what can i do?
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 23, 2009 | Brother MFC 210C All-In-One InkJet Printer
HP 812C will not print yellow but everything else is A-OK Repeated cleanings have NO effect. Cleaned contacts on printer where it connects to cartridge, no effect. HP 23 cartridge only has about 10 pages...
HTML clipboardHi,
It you haven´t used your printer for a while It sounds like the yellow has clogged up in the print head.
Although you have ink you need to print something regularly about every 10 days to keep the tiny jets open
otherwise it´s like trying to pass a camel through the eye of a needle.
So the inks may have clogged up?
The empty weights are 65g C6615A [No. 15] black and
90g C1823A color ink cartridge
anything over that... 1g = 1ml of unused ink.
So if you still have ink you can easily unclog it with a HTML clipboard Magic Inkjet Flush Kit (find it on Ebay)
Or you can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Aug 02, 2009 | HP DeskJet 812c InkJet Printer
Ink blobs on paper
It could be both. Leaky ink can be a problem and that probly is the problem. But, make sure your rollers are clean and cheak that your ink is not leaking. I hope this has helped you.
DigicalJAI
May 19, 2009 | HP Photosmart C4280 Aio Printer
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
Colors are not printing out true.
I replaced the Office Max ink substitute with an original Canon ink. This did not help. I decided this problem most probably had to be a printer head issue, so I gave up and bought a new printer instead.
Dec 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
My printer is running the papers through but it is printing words on top of words and leaving ink spots
If you have a laser printer, it is probably going to be a problem with the fuser. That is not something that you want to attempt to fix yourself, unless you are very technically inclined.
If it is an inkjet printer, you may have a leaky ink cartridge along with other problems. The leaky ink cartridge can cause the ink spots. However, with an inkjet printer, I'm not really sure what will cause it to print words on top of words unless you have a paper feed problem and the paper is not advancing at the speed it normally would.
Nov 24, 2008 | Office Equipment & Supplies
Unable to reset printer after installing new ink cartridges
I want to known you have replaced the cartridges or refill the cartridges.
Feb 23, 2008 | Office Equipment & Supplies
Prints Blank Pages
i was having these same exact problems then i looked at my old ink cartridge and saw that the blue tape was off and that i hadnt taken it off my new one i was trying to print with.!!!
Sep 19, 2007 | Dell A960 All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
52 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
