Question about AOC Computers & Internet
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that connector.
  • Brett Oct 15, 2012
    Hmmm found out it was due to Overscan Issue... Installed AMD Catalyst Control Centre software and found the advanced setting for Flat Panel Monitors and reset the SCALING OPTIONS slider bar to 0% - Problem Solved! Why this software isn't bundled in with the GPU drivers I don't know!?
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Posted on Feb 13, 2011
OSD Locked 2236Vw:
Make sure the unit is OFF mode.
Press and Hold Menu button.
Press power button.
(FROM THE MANUFACTURER)
Posted on Dec 02, 2010
  • eegras Feb 13, 2011
    The above solution only works if the entire OSD is locked (it displays OSD Locked when you press the menu button). The problem the original poster was having can be fixed by changing the "overscan" settings on your GPU. I only know how to do it on ATI Catalyst Control Center.
Posted on Oct 15, 2012
Need to stretch screen to fill space on monitor
Here is a good tutorial on how to adjust the screen resolution on a mac: How to change Mac screen resolution Macworld . However, it may be that the output from your computer doesn't match the size of the screen you have. Did you check to see that the computer can output an image that matches the size of your screen. That is a common problem.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Mar 04, 2014 | DoubleSight DS2700DW Monitor
The audio out on my monitor doesn't work
Check the cable of your better speakers or used another hdmi cable
Jan 10, 2014 | AOC 2436VH LCD Monitor
AOC 19 inch LED Monitor e950Swn - Will HDMI adapter to VGA connector to PC get hi def?
HDMI will only go as far as HDTV. Use DVI, component video (RGB etc) or VGA instead.
Jan 10, 2013 | AOC 19" LED Monitor e950Swn Black
AOC i2353 has border around displayed image, not running at full 1920x1080res?
Had the same problem! Solve it: go to the AMD catalist and choose advanced look. then inside the digital display setting you'll see scalling option that will show 10% . Set it to 0%. Done!overscan.png
Oct 15, 2012 | AOC I2353PH New
Can't figure out where the volume controls are.
Unfortunately, the 24" AOC 2436Vw Monitor does not have built in Stereo Speakers. I know that is not the best answer to hear, but after doing a little more research, I found that the 24" AOC 2436Vh Monitor has 2 built 1.5W Stereo Speakers for just $50 more.
Mar 05, 2011 | AOC 2436Vw Monitor
I have a 24" aoc 2436Vh display and a new 15"
I purchased the AOC 2436Vh display yesterday. To get my MacBook Pro to work with it I purchased Apple's Mini DisplayPort to VGA Adapter. Since the monitor comes with the VGA cable, all you need is the adapter to plug it into your MacBook Pro. It works beautifully and set up is easy if you know your way around the Mac. Although the HDMI works perfectly with my PS3, I strongly recommend the Apple Mini DisplayPort to VGA adapter. I hope this helps.
Nov 11, 2010 | Computers & Internet
Have a 23 inch p235h hd monitor for windows 7 with hdmi hooked up and can not get to use whole screen still has border around it
most like you are not using the native format of the resolution of the screen, it will adjust and not use the whole dimension.
check the manual and then the settings on the computer
Aug 27, 2010 | Acer Computers & Internet
How to change the picture format on my monitor?
You should set your PC to the monitor native resolution for this monitor: 1440 x 900 @60Hz.
Here is the spec for your monitor: http://www.dealtime.com/xPO-AOC-919Swa1-Black
Jan 27, 2010 | AOC 919Swa1 - Black 19 inch LCD Monitor
I have a 1 inch on the left and right side how do I get full scre
if you hav a monitor separate from your computer(not a laptop)then just use your settings on the monitor untill it works again the way you like it..
or for laptops and monitors with no controls on them go 2 control panel>>>>appearance and themes>>>>display. then click on the tab that says settings. go 2 advanced and the dpi setting should be set at 96....and if nothing changes go 2 the appearance tab then 2 advanced. and at the bottom for the item look for active window border and the size should say 1. if it does then keepo trying to make the number bigger so your page doesnt have a black border
Nov 30, 2008 | Gateway Computers & Internet
Computers & Internet Logo
3,410 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
