Question about GPS
PLZ!!! i rele need help!!! ='(
I tried so many things to fix it.
every time i try to turn it on,
all the screen reads is
"Boot Error! Please format unit."
i dont know what this means or what to do.
ive even pushed the reset button.
it was my last resource.
nothing happened. it just turns off.
when i turn it back on, it reads the same thing.
plus, my computer wont even read the device while its connected.
i need some help. if all is not lost,
please answer as soon as possible
  • 8,596 Answers
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jun 07, 2008
My toshiba L505-S5963 will boot but it stops and says "a disk read error has occured plz press ctl+alt+del to restart" even after I do that, it comes back to the same thing EVERY time! how do I...
your hard drive might be causing that, but to be sure of that, take out the hard drive and try booting from your cd rom.
and pls let us know after trying.
Aug 27, 2012 | Computers & Internet
I accidentally deleted my files on my nav720 no it tell me to install the program back on it it will not boot no program help plz
You description is relay confusing. So, you'd better illustrate your problem clearly next time. But, right now, if you simply want to get back all your deleted files back, you can try to check it on your computer
If this camera memory card can be read functionally on your computer, you'd better copy off all your stored photos to another memory card or drive and format this card immediately to check whether it can still be read on your camera.
But, if this card unfortunately also gets the same error, you'd better try to apply a memory card photo recovery freeware to get all your stored photos back successfully for free:
http://freeware-fix.blogspot.com/2013/04/memory-card-error.html
In fact, this freeware helped a lot as the external hard drive of my friend was mistakenly formatted. It finally restored all the needed data of my friend. It always works well on both of a memory card and a hard drive. So, I believe it will also help you a lot.
Try to read more information of this freeware here:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
After experiencing these troubles, I hope you can learn a valuable lesson to back up everything important well at least on two memory cards or hard drives all the time.
Feb 13, 2012 | Cameras
When i turn my laptop on it says (disk read error occurred ) then it say to press control alt delete to restart and i did and then this message came up agian so i plugged it into the charger did the same...
That error shows up when Windows find an irreversible error on the Hard Disk Drive. I'm sorry to say that the only solution is to change the Hard Disk Drive.
Jul 27, 2011 | Computers & Internet
My dell inspiron cannot boot. On startup dell logo screen appears with only f2 and f12 options then my screen goes black with a flashing dash in top left corner. I cant access safe mode, i cant do anything...
The Operating System in your hard disk gone corrupt, you need new installation of Operating System using boot from CD/DVD.
P.S. Formating of Harddisk is recommended, because it seems the act of virus infection
Good Luck
DO rate if helps
Dec 02, 2010 | Dell Inspiron 1501 Notebook
-Tha Mp3 Doctor
Jun 03, 2008 | RCA OPAL M4001 MP3 Player
Its actually an rca opal M4008
myspacepepe this just worked for me. Try downloading the firmware here:
http://www.fixya.com/support/t322643-rca_opal_m4008a
Then read this solution another user posted. Hopefully this helps you. I had the same issue.
I had this problem. Backing up data wasn't a concern though, as I hadn't anything on the OPAL yet.
First I let the OPAL charge up for 3 hours. Then I made sure it was powered off. I had previously downloaded onto a PC the firmware update for the M4004 which also works on the M4008 and other OPAL's. I plugged the OPAL into the PC, and booted up the PC. After installing the firmware package in the PC, you get an install screen for the new firmware with a format option for the OPAL. I selected that option, but the "start" button was greyed out as the PC still couldn;t see the OPAL. I pressed the reset (paperclip in the back of the OPAL) for about 15 seconds, than held down the "Play" button and waited. Eventually the software recognized the OPAL, and started to format it.
If you get a dialogue to restart the PC, press NO! You have to read the instructions that come with the install. Eventually I reformatted the drive, and installed new firmware.
BTW, there was no picture folder after I did this, so I just created a new folder named picture and it worked fine for the thumbnail pics I threw in there. Also when I use a MAC with the OPAL, I power the MAC up with the OPAL off but attached. After drag and dropping files into the OPAL, I power down the MAC. After power down the OPAL will after a pause give the "building databases please wait" messages, then when done go to the start menu. It is difficult on a MAC to eject the OPAL, it just reappears on the desktop so shutting down is the only safe way to administer the device. But to update firmware, which is easily corrupted BTW if you unplug the thing at the wrong time, you HAVE to do it on a PC operating system. Might work on an Intel MAC with a PC OS though.
Hope this helps.
Boot Error please format unit
my rca mp3 player started saying boot error please format unit how do i fix this so i can hear my music again
Mar 19, 2008 | RCA OPAL M4001 MP3 Player
Boot error! please format unit
It might be cause by a corrupt firmware. You need to have a utility that restore the mp3 player to its original setting. i had exactly the same problem with my ipod shuffle 1st generation 2 years ago. Good thing Apple has that utility for me to download and until no it is still working. Try to visit and upgrade the firmware using this link for you mp3 player http://support.rcaaudiovideo.com/downloads.aspx?product=192
Please Rate Appropriately Thanks!
Jan 14, 2008 | RCA OPAL M4001 MP3 Player
RCA LYRA MC5102A
you just go 2 ur computer where ur hard drive thing is like it says my computer then u open it up and ur lyra should appear there and right click it a menu should come up and itll say format
Nov 24, 2007 | Audio Players & Recorders
GPS Logo
101 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
