Question about Arctic Pool & Spa
Filled artic spa 36 hours ago. not heating properly. what should I check?
  • 35 Answers
If you don't have any error codes, FLO, FLC, then there is a chance your heater has burnt out. You would need an Ohm meter to measure if you have continuity thru the heater element. You should read 11 to 12 ohms. If you have either FLO or FLC on the display this indicates a problem with the pressure switch. The pressure switch is threaded into the side of the heater, the stainless steel tube attached to the #1 or main pump. Its a round module with two wires attached to it. There is an adjusting post in the center of the module. For an FLO code turn the post half a turn CCW. For an FLC code turn it half a turn CW. If this does not solve the problem replace the pressure switch.
Posted on Oct 17, 2010
I have fractional spa pump with 1000 watt heater. the spa was on but no water was in it while it ran overnight. did this burn the heat elements out of it and can I fix it?
It should be OK. These units should have a flow switch to prevent activation of heating element without water flow. Yes, heating elements can be relatively easily be changed if needed.
Dec 08, 2014 | Comfort Line Products Spa2Go Inflatable 4...
GE ARTIC PROFILE REFRIGERATOR....INTERMITTENT HEATING
Sarct, the question is, was the freezer side ok, if it was, I would suspect the damper not opening. If the freezer side was warm too, then I would suspect the evaporator thermistor not sending the signal to the board to terminate the defrost. Have the tech first check the continuity at connector J3. He should have 400ohms at J3-1 to J3-2 and the same at J3-3 to j3-4. If he doesn't get those readings have him check at the damper motor itself. If he doesn't have it there, replace the damper motor. If the damper motor passes all the checks then it's on to the evaporator thermistor. Have him check the resistance. At 5 degrees it should ohm at approx 36K ohms. The evap thermostat is redundant to the defrost operation. It's there as a back up in the event the evap thermistor fails to terminate the defrost. It's normally closed and will open at 140 degrees.
Dec 20, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Arctic spa heater
check temp sensor then heater element
Nov 01, 2017 | Pool & Spa
Dreammaker 400 spa won't heat up
make sure recirculation pump on then check heater element then pressure switch then loud motor you hear
May 21, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Just filled my dream maker brand new has been filled for a couple of hours but all the temp says is ice do you know what that means
This spa is heated by waste heat from the pump. The manual says it can take up to 20 hours to get to 100F. I assume that is starting from 60F. Keep the cover on and let it run at least a day and you should have 100F+ water temperature.
Mar 01, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Our artic spa hot-tub is showing HL in the panel and is not heating up as it should. Everything else seems fine. Why?
HL is normally a "high limit" fault. If your filter is clean and you have sufficient flow, you may have a faulty high limit sensor. It should be mounted on the heater itself. The high limit sensor shuts the heater off if it senses excessively hot water. Check to see that you have sufficient flow, clean the filter, and make sure the filter pump is running. If everything else is running properly, you may have to replace the high limit sensor.
Dec 26, 2009 | Pool & Spa
1991 Honda Accord Wagon
If the battery was dead for more that 36 hours, or if you had the battery out of the car for more than 36 hours, you will have to have it towed to a dealer and have the ECU anti-theaft system reset. It may be less than 36 hours. Maybe it's 12 hours. Something like that. Call the dealer and ask about it. They'll be gald to fill you in.
Jun 18, 2008 | 1991 Honda Accord
Pool & Spa Logo
568 people viewed this question
Top Arctic Pool & Spa Experts
Mike Raino
Level 1 Expert
john h
David Spradling
David Spradling
Are you an Arctic Pool and Spa Expert? Answer questions, earn points and help others
