Question about Rinnai Heating & Cooling
I have a rinnai energysaver 431ftr heater that is on a houseboat & will not start. lights come on & there is power to the unit. it just will not ignite. pls reply a.s.a.p. regards Dave
hotuna
  • 288 Answers
SOURCE: 606tr rinnai silent server
You are not getting gas for some reason. Check the valve to make sure it is getting power to open the solenoid. It may need to be set to on. If you are getting power to the valve and its not getting gas, check the orifice. Sometimes a spider or other bug will get in there and plug it up. Its a very small hole, so it wont take much to block it.
Posted on Mar 02, 2008
SOURCE: Rinnai EnergySaver 556F Heater flashes
I'm picking up a faint propane scent when the heater is completely turned off. When I turn the heater on it lights fine so I don't suspect it's the pilot light. Is this an issue with the installation of the fuel line, or could it still be the pilot? Any ideas on troubleshooting the source?
Posted on May 26, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: rinnai energysaver 557ftr keeps switched itself
An H12 indicates a flame failure, which could be caused by an obstruction in the combustion chamber, buildup of debris on the flame rod, not enough or no fuel, or no spark at the igniter. You may wish to get a technician in and look at these. One thing I have found is that spiders love to webs in the burners of these heaters and the only way to check it out is to disassemble the entire burner.
Posted on Aug 04, 2008
ngfam1
  • 639 Answers
SOURCE: Rinnai energysaver 556FTR filter light
Friend,
Happy to assist you!
Perhaps a bad blower.
Sounds like an electronic failure!
words alone will not remedy the situation!
Do not wait to fix it next year!
The cost will be more then Bad Infaltion!!!!!!!!!
You need to call service !!!!!!!!!!!!!
LET ME KNOW WHAT HAPPENS???
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF
Posted on Aug 29, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai 556F Not Exactly and "Energy Saver"...
Raise the thermistor. It is a black rubber probe located on the back of the heater close to the coldest spot in your home, the floor. Raise it a few inches. To do this you will need to unhook it from its holder and open the front of the heater to unravel the extra length of yellow wire.
Posted on Feb 20, 2009
My rinnai energysaver 1001ft will not turn on.It has power to it but it will not power up when switched on.no lights no go.HELP;;
Hello Mark Obrien,
I searched the internet trying to get a HIT from your
rinnai+energysaver+1001ft
and all combinations there-of...
I also went on-line to a MAJOR RETAILER site & poured over their inventory of systems and parts (see below)...
Alpine Home Air Products Contractor grade furnaces heaters air...
Nothing... so:
Assuming you are talking about a heater here
If you are seeing no "lights"...
perhaps checking the SECONDARY side of your
POWER TRANSFORMER would be the best advice...
If that has the required (typically 24 volt output)
continue on to your main control board...
(looking for the Typical FUSE (usually 5 AMP)...
If the fuse is OPERATED... replace it...
f it operates again... IT is time to consider purchasing that
SPARE MAINBOARD you always wanted...
Like a YORK furnace... (verify your OWN NUMBERS)
031 01267 001A OEM Upgraded York Furnace Control Circuit Board by BDP... (PC (Main Control Board)
ALSO CHECK HERE
https://www.supply.com/rinnai-furnaces/b2098
Fuse kit
Amazon com Bussmann NO 44 ATC Blade Fuse Tester Puller Kit Home Improvement
Hope this helps...
Carnac the Magnificent
Jun 25, 2017 | Rinnai Heating & Cooling
My rinnai energysaver 431ftr keeps coming up with error 53. How do I fix this please?
Here is a link to the Manuel you should be able to find the error in here.
http://www.rinnai.us/documentation/downloads/Owners_Manual_431FA.pdf
If you cant handle the problem yourslef you may want to call a service professional.
AC Repair West Palm Beach
Apr 26, 2015 | Rinnai Heating & Cooling
How to install
Unfortunately, the installation of one of these units is not quite as simple as 1, 2, 3.
So, I am providing a couple links on the installation process. You can download and print each one.
The first is the Flue Installation Guide.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/CI_ES_Flue_Inst_Manual.pdf
The second is the Operation Guide, which also deals with proper installation.
The third is the exploded parts view & parts diagram, Which you may need in the future.
I hope all of this information will help you properly install the unit.
Jun 02, 2011 | Rinnai EnergySaver 556 Air Conditioner
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/556&431FTR.pdf
Jul 27, 2010 | Panasonic Heating & Cooling
My tank says I have 32 gallons left but the heater won't work (rinnai 556f). It turns on for about 15 seconds and the light on the power button turns red and starts blinking. What does this mean?
If you hold down the economy button and the up and down arrow buttons for 5 seconds the unit will start an error code display. Get a helper and yell out the numbers when they start blinking. Post the error codes and we can help you
Dec 23, 2009 | Rinnai EnergySaver 556 Air Conditioner
Rinnai Energysaver 1001F - Turn on, ignites, blows + powers off
Try disconnecting the unit and thoroughly cleaning the dual walled intake and vent pipe that goes through the wall. Use a small brush to make sure the passages are free from any obstructions. These units have safety mechanisms that are very sensitive and sometimes will shut off when something as seemingly insignificant as a leaf or spider web creates a slight blockage. A yearly inspection and clean out are necessary.
Jun 29, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Energysaver 1004FTR
Check for a blockage in the heat exchanger. Spiders love to make nests in these units. Remove the front cover and the two rectangular viewing ports on the front of the heat exchanger. Watch as the unit ignites. There are three burners you need to watch and the first one is in the center and hard to see. If there is flame but it goes out quickly, you have a blockage in the unit. Check the venting to make sure it is clear of debris.
Aug 19, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
55 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
