Question about Keurig B60 Coffee Maker
What does it mean and how do you "descale" a coffee maker? the little window says "descale" . i assume it has to do with some regular maintenance that I'm not doing. also since it appeared, the water flow quits before the cup is filled.
    Problem Solver:
  • 5 Answers
WHITE VINEGER THRU A CYCLE
Posted on Oct 16, 2010
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
Tip
How To Clean Descale Unclog Keurig K-Cup Coffee Brewer Maker Maintenance
<utube src="XgtVEfNM95U"></utube>This video will show you how to clean or descale your Keurig Coffee brewer using water. Great preventative maintenance tip.
on Aug 05, 2013 | Keurig Coffee Makers & Espresso Machines
Red light showing when i go touse frother steam not consistent
For Saeco Vienna De Luxe Espresso MachineTeam De-Brewerz.com says:
1. Your coffee maker might suffer from Steam, Coffee Bolier clogging due to scale. Due to clogging you are unable to product perfect steam, temperature drop in coffee, inconsistent steam flow, inconsistent water flow etc. We strongly advise you to do regular Descaling to your coffee maker (every 200-300 cups or 2 months)
2. If your coffee maker in working condition but still light is keep on blinking means required "Descaling". Please use the food graded Delonghi or equivalent brand descaler. You can order to us @ www.De-Brewerz.com or buy online in India @ www.fabkaart.com
Still issue not resolved claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Oct 20, 2014 | Saeco Vienna De Luxe Espresso Machine
My keurig b60 says prime
This can go out by draw out some hot water. However if this happens very often then you need to perform a descale.The brewer should be descaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. Descaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend descaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The descaling process involves using 48 ounces of undiluted white vinegar. Learn how to descale your brewer.
Feb 24, 2012 | Keurig B60 Coffee Maker
What does it need when the window reads "descale"
when the display says "Descale" it means that the machine wants to run a cleaning program to remove any limescale build up on the heating elements.
you will need to put a descaleing solution in to the main water tank and run the descale program
follow the instructions in the manual to descale
Note (useing anything but the recommended descaler may void the warranty)
Feb 18, 2011 | Keurig B70 Coffee Maker
De Scaling instructions
Also, if you have an in sink garbage disposal, don't waste the hot vinegar.  Pour it into the disposal, turning the unit on as you pour, off when you're done.  The vinegar is mildly acidic and will disinfect the disposal unit.
Feb 17, 2009 | Keurig B60 Coffee Maker
What is citric acid for cleaning coffeemakers
just get the regular cleaner for descaling coffee machines. that has citric acid in it.
Descale according to manual
Jul 20, 2008 | DeLonghi Caffe Nabucco BCO70...
Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Nov 10, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
The display reads CALC.
I have a Krups model FME4 and it means that you should descale the machine. Here's a link to the use and care instructions for my model, I assume it would be the same for yours.
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Use+and+Care/ResultUseAndCare.htm?SelectedService=Use%20and%20Care&SelectedGuIDService={EC10140D-AA43-4DCA-8D3A-A5A4823D9E52}&SelectedProdRef=FME4
My problem is that CALC continues to display even after I've descaled several times. Good luck with yours.
Oct 30, 2007 | Krups ProAroma 453-42 Coffee Maker
Keurig B60 Coffee Maker Logo
102 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
