Question about Sport & Outdoor - Others
I have a TX400 Treadmill i set everything up on the screen them it beeps and go to the # 03 the Belt never moves
  • 1 more comment
  • zzlegs36 Oct 16, 2010
    Don't know
    Don't know, don't have a manual and the Treadmill was given to me and it worked fine then. What usually cause this to happen? I checked the fuse it fine the light is green on the cirrciut board.Belt looks good. I really could use your help, but if it's going to be costly of having to keep asking ???? them i will just throw the machine out.
    08/2003
  • 712 Answers
How old is the model?
Posted on Oct 16, 2010
  • Sebin Punnacheril
    Sebin Punnacheril Oct 16, 2010
    Check the wheel speed sensor. Pull the plug. Remove the motor cover. If the magnet is on the wheel belt shaft wheel then try to move the sensor a bit closer or inspect it for problems!
What kind of oil do I use on the Tx400?
Its not oil. You have to use silicon lubricant .
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 09, 2016 | Exercise & Fitness
When i start my tx400 treadmill it shuts off after 7 sec. everything checks out fine it just wont stay running.
see the video attached, lube too the rollers bearing front+back. and fix it. God bless you
Oct 09, 2013 | Exercise & Fitness
Tx400 treadmill runs for 7 sec then turns off
1)lUBE THE treadmill deck belt, the lack of maintenance produce SHUT down for to protect the electronic system
2) Lube the rollers bearing too
3) Measure the input voltage motor, if there are the motor need repair
4) Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. See the block diagram
God bless you
Jun 18, 2012 | Exercise & Fitness
My treadmill will light up an make a beeping nose when a button is pushed. The treadmill is pluged up and the red cord magnet is on when the buttons are pushed. However it just does the same beep for...
If the screen is lit and the screen shows that the belt is moving then it’s the motor controller. If the screen does not show that the belt is moving then it’s the console.
Oct 20, 2017 | Horizon Fitness T82 Treadmill
Belt won't move
does is just not move when you're standing on it, or not even move when you're not standing on it. It may be a simple belt adjustment or if the motor is running but there's no track movement you may be looking at a loose/broken drive belt. Take the cover off, start it up and look at the motor/drive pulley assembly. If the motor turns and the front roller doesn't, tension the drive motor by moving it back. If the front roller turns but the track doesnt, do a track adjustment as per your users manual.
May 26, 2010 | Proform CrossTrainer Treadmill
Treadmill tx400 wont work for llonger then 6 seconds
Sportcraft tradmill are very safe. First check and make sure there are no recalls on you unit. Do that on line or call Walmart where you most lickly got you treadmill. Try lubing you deck wich is under the belt. This is something that needs to be done to stop friction... Frition may have worn down the motor. Get back to me
Oct 10, 2009 | Exercise & Fitness
Sport & Outdoor - Others Logo
71 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
