Question about AEG Lavamat 16810 Front Load Washer/Dryer
My Lavamat Turbo 16810 is failing frequently to complete a tumble drying session. I do not use the dryer more than once a week but the error code E10 keeps showing after 10 minutes approx.drying time. I have been turning it off and on to try again but the machine bleeps with the error code E10 after about 10 mins.?? Advise problem and possible cost. Many thanks
5 Suggested Answers
  • 257 Answers
SOURCE: My AEG lavamat turbo 16810
I'm not sure if this model has an access panel with 2 screws at the bottom, but if not, An easy way to access is by tilting the washer against the wall and removing the bottom panel, Should be 4 screws. from there you can remove the hose and retrieve the debris from the pump most likely change. have a fairly good size bowl and towels close by to catch the water. make sure the washer is disconnected from it's power source. Hope this helps.
Posted on May 02, 2011
SOURCE: My aeg lavamat 16810 washer dryer won't dry. The
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
Posted on Nov 11, 2009
lgdinesh
  • 35 Answers
SOURCE: rubber frontseal came away from metal spanning
gasket(rubber) is comes off means the metail spring may be damaged check the spring
Posted on Jun 06, 2010
  • 6277 Answers
SOURCE: my AEG Lavamat 16810 Turbo
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 13, 2011
Testimonial: "thnks will check it out "
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Feb 17, 2012 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
My aeg lavamat 16810 washer dryer won't dry. The error message is E10, meaning the water isn't going in. Water is running until the dryer kicks in, then the valve closes and it stops. The heater etc are...
Oct 28, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
16820 dryer not working
I suggest checking the moister sensor and or cycling thermostat. the hi limit thermostat as well, with a meter for continuity. other wise you may have a bad timer
Mar 20, 2017 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Lavamat 16820
The reason the machine is coming up with E20 when drying.
is that there is a blockage of fluff in the dryer air duct on the right hand side of the machine just below the fan unit.
the air that goes through this duct is heated and returns back to the tub to dry the clothes. because there is a blockage in this duct the fan pushes air up the pressure switch tubes and fools the machine in to thinking that there is too much water in the drum,
too remove this blockage you have to disconnect the power supply, remove the lid and remove the back panel, 4 screws at the bottom + 4 up top under the lid. plull the water pipe with the valve out of the way and pull back panel away.
you should now see the dryer condensor unit blocked up with fluff. remove this unit and clean with bottle brush.
replace and make sure hoses are done up tight. replace back panel and lid, try again on drying and things should be alot better, drying should be alot quicker as well.
Sep 27, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
168 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
