Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Refrigerator stopped cooling but freezer is fine. what could cause this and will it be expensive to fix?
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
Maytag MBF1958WEW1 refrigerator not cooling but bottom freezer is fine help
Sounds this fridge/freezer has a refrigerant leak. Eventually the freezer will also stop freezing. Need to find and fix leak and refill with refrigerant.
Feb 01, 2018 | Maytag Refrigerators
Frig freezer wont get cold enough after move . 35 degress then back up to 45 . cleaned everything good . coils everything . worked fine till moved . waited 24 hours after move to plugg in . help
Hi Kim, Before you check out the link below, Read about your refrigerator not cooling?Is your older or newer model refrigerator plugged in, getting power, the lights are on inside but the fridge will not cool and the freezer won't freeze? If your refrigerator or freezer has suddenly stopped cooling and the freezer won't freeze, we have multiple solutions for you.If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor is overheating or not getting proper power and will not start. The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
Refrigerator Is Not Cooling What To Check And How To Fix
Apr 03, 2016 | Refrigerators
My RJ 523V-R refrigerator has worked perfectly for 8 years, but suddenly stopped cooling the fridge properly while the freezer seems ok. how can I fix this?
Often times their is a fan from the freezer section to the refrigerator section, of some brands of boxes. If the fan goes out, the refrigerator sections no longer cools.
May 23, 2014 | Electrolux Refrigerators
Top refrigerator section will not cool
Check the evaporator fan , freezer must have a fan to avoid ice formation, if evaporator does not work, thermic sensor jams up and freezer stop working. The fan is located behind the panel in the freezer.
Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.
This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.
Check also the defrost thermostat, which is on the evaporator inside the freezer.
If it isnt defrosting, change both.
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator and Freezer stopped cooling after intermittent noise
Hello
if the ice maker arm is down regardless of the water being off the valve will energize ( dry ) no this will not effect cooling
Apr 12, 2017 | Kenmore 73503 Stainless Steel Bottom...
Fridge not working properly
Your compressor has most likely gone out or you have had a freon leak. I would say the compressor is the culprit. You need to have a appliance company come out to make sure, hopefully it's under warrenty, if not, it's usually better to buy a new fridge than to fix it. It's usually more expensive to fix old fridges than to just replace them completely.
Aug 25, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
