I have been trying to register my Linksys router and cannot get on...I pasted the web address sent to me and cannot get on.
  • 55 Answers
I want to connect a Scientific-Atlanta WebSTAR 2000 series Cable Modem to a Linksys Wireless-G WRT54G wireless router but the linksys doesnt detect the modem and the computer wont let the setup program for...
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting Devices Together
iii. Checking the Router's LEDs
iv. Configuring a Linksys Router for a Cable Internet Connection
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G WRT54G Router
My linksys w/2phone ports cannot hook up with the ethernet
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
ii. Connecting the Devices Together
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is 192.168.1.1. NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
How do you manually connect a computer to the router? Trying different cables in port 1 but does not register to the computer. Please help!
You need to connect a standard network patch cable between port 1 and the ethernat port on your computer. To access the Web-based Utility, launch Internet Explorer, and enter the Router’s default IP address, 192.168.1.1, in the Address field. Then press Enter. This should bring up the router confiuration web page.
The password request page should appear. Leave the User Name field blank. The first time you open the Web-based Utility, use the default password admin.(You can set a new password from the Administration tab’s Management screen.) Then click the OK button.
Nov 08, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless connected to router, signal fine, no web pages
First thing i would try is power cycling your equipment. Unplug the router and the Modem-
Plug the modem in first and once all the lights come on- plug in your router- then restart your computer.
Apr 09, 2009 | Linksys Wireless-G WRT54G Router
Firmware
Here's the Linksys step-by-step guide for your router:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3686&lid=5531661879B01
Are you connected to the wireless router with an ethernet cable? Generally, you want to hook it up this way first so you can configure it. If you are hooked up with a cable open your web browser and type in the following address: 192.168.1.1 this should get you to the router's web page. The default login for linksys is username: blank, password: admin
See if you can connect to the router in this way. If you can then we can go through the next steps or you can try using the above link.
Good luck.
Dec 19, 2007 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
