Question about Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch integrated dishwater that is just over 2 years old. It has suddenly stopped working and the tray at the bottom is not emptying, although you can still hear a buzzing sound. The cycle does not go beyond this point. I have emptied the tray of water and the dishwasher will start again, and pump water in, but it then stops, as though it is not able to pump water out. Does anyone know what this is? Could it be the pump? A blockage?
5 Suggested Answers
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
  • 32 Answers
SOURCE: Bosch Dishwasher pump keeps emptying
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Bosch Dishwasher Parts:
Posted on Feb 11, 2009
  • 3247 Answers
SOURCE: My bosch dishwasher has water
the drain is blocked somewhere. It is probably trying to drain water out but is not successful and then shuts down.
Posted on Jan 19, 2011
Testimonial: "Thanks, I got it. I had a new disposal put in yesterday by my dad who didn't read the directions and remove the plug running into the disposal."
What steps will improve dishwater performance?
You can remove hard water deposits/scale by running one cycle of your dishwasher (empty) with distilled white vinegar. Add 2 cups of vinegar to the bottom and turn the machine on to an energy saving or low wash. Stop the machine mid-wash, so the vinegar can set on the bottom and work. check links below , press the helpful button.
Cleaning the Inside of Dishwasher with Vinegar and Baking Soda
How to remove and clean your dishwasher spray arms
Jan 26, 2016 | Dishwashers
Ecologixx 7. Why does it keep switching itself off?
could be the door switch has failed . try leaning on door when starting .
Sep 13, 2015 | Bosch Washing Machines
Water leaking from bottom of my Bosch fridge (irregular - might be defrosting??)
There is a tray under many refrigerators that traps water so that it may harmlessly evaporate. It or the drip tube may have become dislodged, possibly by cleaning under the unit. The tray should easily be removed, then you may see if it or the tube is the problem.
Nov 19, 2014 | Bosch Refrigerators
What doesn't my dishwater finish its cycle?
What is the make and model number
Jun 09, 2013 | Dishwashers
Following the wash cycle with my Miele G464SC
sounds like you mean when the unit is running you are getting water dripping from the bottom of the door panel. if you remove the door panel at the bottom where the door hinges you will find an overflow tray which runs the width of the door. This is probably blocked with food deposits.
If not you may be using too much detergent. try running with no detergent and see if there are any leaks.if you open the door mid cycle the water level shouldn't be any higher than the bottom spray arm. hope this helps
Jan 02, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Bosch Evolution B20CS50SNS about two years old. No ice is dispensed. Looked inside and tray is frozen over solid. Also looks like water has overflowed and frozen down in bin. Could not figure out how to...
I've had lots of problems with my Bosch refrigerator ice maker. The ice tray has a tab on the back corner that twists the tray when it cycle to empty the ice. That tab broke off and when I looked into replacing the ice tray the authorized Bosch dealer said the tray is only sold with the complete ice maker unit. Sells for about $160. I have a hard time spending $160 for another complete ice maker when I only need a $10 replacement ice tray. This ice maker is sub-par for an appliance name brand like Bosch.
Dec 08, 2009 | Bosch Refrigerators
Door on my integrated Bosch fridge keeps opening
Seals rarely fail most likely needs hinges replaced,parts quite cheap
Jun 16, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
52 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
