Question about Canon NP 6551 Black and White Copier
Code error E212, with 3 options: Command card Initial detector Moving device somethig like that
    Guru:
  • Canon Master
  • 452 Answers
E212: problem with the optical section
  1. Home position sensor is defective
  2. Motor Lens move iis defective
  3. Control board is defective
Posted on Oct 16, 2010
What does the word acquired mean
verb (used with object), acquired, acquiring. 1. to come into possession or ownership of; get as one's own: to acquire property.
2. to gain for oneself through one's actions or efforts: to acquire learning.
3. Linguistics. to achieve native or nativelike command of (a language ora linguistic rule or element).
4. Military. to locate and track (a moving target) with a detector, as
Dec 07, 2016 | GPS
1995 Honda accord ex v6 automatic transmission of code p1298
Electric Load Detector Circuit High Voltage
Possible causes - Faulty Electronic Load Detector Unit - Faulty Engine Control Module (ECM) - Electronic Load Detector Unit harness is open or shorted - Electronic Load Detector Unit circuit poor electrical connection
Possible symptoms - Engine Light ON (or Service Engine Soon Warning Light)
P1298 Honda Description The Electric Load Detector (ELD) measures the main current flow and sends that signal to the Engine Control Module (ECM) to command the alternator charging system to get fuel efficiency and decrease the drag of the engine when starting.
Aug 09, 2016 | Honda Cars & Trucks
AVIC-F700BT FIRMWARE ERROR CODE
Download frsh firmware from manufacturer, yours may be corrupt and use a NEW sd card, they do develop faults every now and then
Feb 18, 2014 | Pioneer AVIC-F700BT Car GPS Receiver
How to reformat memory card with an I/O error
first check whether the memory card is out of lock by moving the lock bar in your memory card to unlock.
Then insert the card and go to start accesorries> command prompt
(right click the command prompt and run as administrator if in vista or 7). In the command prompt screen type : format (enter the drive letter and : /s ) . now the card will be formated.
Oct 18, 2010 | Computers & Internet
My toshiba L500 wont boot up when i turn it on it starts to load files then stops and tries to repair the problem but it does not
There are so many reasons boot up; i.e if system files corrupted by virus or hard disk index tables corruption or hdd partions corruption.
So as a initial trouble shooting try to do following things to resolve problem.
Option 1:
1. Power ON your computer and Press F8 key to have Windows boot menu option
2. Select "Safe Mode with Command Prompt" and Press Enter
3. When command prompt loaded then type follwing command and press enter
chkdsk /r c:
(If this command is not working in "safe mode with command prompt" then start computer with Bootable CD and Press "R" key when first time asked. It will open recovery console and type this "chkdsk /r "command again to repair disk.)
This command will scan your hdd and repair disk errors.
Option 2 :
To repair your windows without losing your data.
Start Computer with bootable CD
Press R when it is asked to press.
It will repair windows.
Note : Please read Status Bar and screen messages /nstructions carfully (while Booting computer thru Bootable CD)
Mar 28, 2010 | Toshiba Satellite L505ES5015 NoteBook
Media card inserted has errors to correct use a disk error checking computer
It could be the problem of file system of your media card. Disk check utility help to resolve that by sacnning the defected memory area and blocks.
Step to Do it:
1) Insert the media card into media card reader.
2) Confirm that u can see the device at My Computer
3) Note down the drive name for this device like C: or D: or E:
4) Type command in RUN ( cmd) and press enter
5) It will take you to windows command prompt
6) type the command( chkdsk /f <drive letter for exmaple C: or D: or E:) which belong to device in my computer
7) and press enter
8) It will scan and fix the file system error
9) Once it is finished remove the media card from card reader and reinsert it again
HOPE it works now
Sep 17, 2009 | PNY 2GB microSD Memory Card
Nighthawk model kn-cop-dp, when plugged in i get an error code
I have the same problem....The answer is the detector has died. This kind of detector has a warranty for 5 years. Mine was assembled 8 years ago and just died this morning. 8 years is good for this kind of detector. The protection device inside wears out in time. Thats why you keep getting an err message.
Nov 17, 2008 | Kidde Nighthawk Combo Gas/co Detector
Error code 10 and 39
A Code 10 error usually occurs due to:
Missing device driver
Malfunctioning device driver
Incomplete device driver files
to fix it..........
updating the device driver for the faulty device
1st) To update the driver, select the System option from the Control Panel.
2nd) In the System Properties dialog box, select the Hardware tab,
3rd) select the Device Manager button.
4th) Scroll through the Device Manager window and identify the faulty hardware device.
5th) Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
Nov 09, 2008 | Computers & Internet
Dell Optilex GX300 checkpoint [Vmgr]
Items in blue which are underlined are clickable to give more information about the process
Start the System Restore Utility at a command prompt
1. Restart your computer, and keep tapping F8 during the initial start-up until you get options, select Safe Mode with a Command Prompt then press enter.
2. Log on to your computer with an administrator account or with an account that has administrator credentials.
3. Type the following command at a command prompt, and then press ENTER:
%systemroot%\system32\restore\rstrui.exe
4. Follow the instructions that appear on the screen to restore your computer to an earlier state.
Look for the most recent system checkpoint created before the errors to restore from
For additional information about the Safe mode with a command prompt, click the following article number to see a description of the Safe Mode Boot Options in Windows XPthe article in the Microsoft Knowledge Base: 315222
Mar 06, 2008 | Dell Optilex GX300 (188TD) Motherboard
Canon NP 6551 Black and White Copier Logo
142 people viewed this question
old marine
old marine
