Question about Philips DVDR3390/37 DVD Recorder
Phillips dvdr3390 " blocked "
Not long after i bought the thing, it would always say blocked when I wanted to take a disk out or put one in. But, I could try it several times and eventually get in. Now, it won't ever open and is always "blocked". I'm thinking it is a piece garbage. Is there any solution for this problem or just speculation on what to do. My idiot boyfriend threw away the directions for the damn thing, so now it seems I'm out a couple hundred bucks unless you guys can help me with this.
  • Anonymous Sep 04, 2008
    Same problem, the tray door can't open and keep getting the message "Blocked". First, it was able to open after several tries ...now it's just permanently stucked. Blah... Phillips DVDR3390...not good
    Problem Solver:
  • 10 Answers
Old post, but here's the correct solution for anyone who may have this problem in the future. I don't think that always leaving a disc in the tray is a solution, just a temporary fix.
My parents had the identical unit with the same problem. They fixed it by replacing it, and let the 3400 sit and collect dust.
I got sick of this so I set out to fix it today. EASY fix. Should take the novice about 45 minutes, and expert closer to 15 minutes.
This writeup is for educational purposes only, with varying skill levels in the world, I'm not going to be responsible for any damage you cause to your DVD player, yourself, your TV, your neighbor, or your cat.
You'll need:
T-10 Torx screwdriver
P-2 Phillips screwdriver
And a small slotted screwdriver, knife etc.. something to bend tabs back to unsnap plastic pieces.
Make sure the unit is unplugged first.
Remove 7 T-10 screws from cover (2 on each side, 3 on back)
Locate metal bracket over DVD unit.
Remove 2 T-10 screws holding bracket to bottom.
Remove 3 T-10 screws holding bracket to front.
Be careful you don't break the mount tabs, and don't touch any circuitry!
Remove 2 P-2 screws from black cover over DVD unit. Using your weapon of choice, CAREFULLY pry the tabs that are holding the black cover onto the DVD unit. 1 tab on each side, near the front of the machine.
DO NOT TOUCH THE LASER LENS!
With the removed cover in hand, locate 3 tabs that snap 2 white plastic circle halves together, Seperate the halves. Remove 2 washers. Notice one is a standard washer, and one is a strong magnet.
REVERSE their locations. Stack the magnets on the side that comes in contact with the DVD. Place the strong magnet on first, then place the normal washer on top.
I believe the cause of the "BLOCKED" message is this magnet being too strong/the opening mechanism being too weak. You need a magnetic fieldphillips dvdr3390 to center the white circle onto the base that the disc sits on, but too strong of a field causes the BLOCKED message to appear. Lessen the magnetic field and everyone is happy.
Reassembly is the reverse of removal.
Posted on Jun 29, 2010
  • 476 Answers
Mine had the same prblem.
Never close the tray without a DVD in it.
It is the upper part of thre reader that bends a little bit and got stuck with the lower part.
You will se that with a disc inside you will never have the problem.
Posted on Oct 11, 2008
Mine did the same thing when I first got it. Now, when it does it, I just push on the door, lift the front of the unit about 1 inch and drop it. Works every time! I did open it up, but you can't get to the part that sticks - but I was ablet to move it back and forth - which did help also. It sticks down, so when I drop it, it unsticks it! Real professional, huh!
Posted on Sep 26, 2008
(2nd Posting to add more stuff)I have a Phillips DVDR3390 and when I used to put in a DVD sometimes it would show "Unknown Disk" & sometimes it wouldn't. Now it does all the time. The blue lens lo
It sound like you may need to update your firmware..
You can search this like for ready downloads.
Also, I would look for BIOS firmware updates at the Phillips web site
Apr 28, 2014 | Philips DVDR3390/37 DVD Recorder
I lost manual for my DVDR3390/37 and I need it to reprogram it. I need to know where I can get another one since it has been over a year since I purchased it.
You can download the required manual from:
http://www.retrevo.com/support/Philips-DVDR3390-DVD-Players-manual/id/280ag205/t/2/
On the page which opens, you will find 5 manuals. Select the manual which you need. Click on the GET MANUAL button and follow the instructions on the next page to download the manual.
Hope this solves your problem. Thanks.
Oct 24, 2009 | Philips DVDR3390/37 DVD Recorder
DVD is stuck in Disc tray, will not open
I have a Phillips DVDR3390/37 and was getting a BLOCKED message. I found that by utilizing the slot on the bottom of DVD and moving the mechanism slightly to the left, it would open the DVD tray. The white plastic you see through the slot is part of the motor driven mechanism that raises the DVD disk up to the drive wheel that spins the DVD. The opening and raising actions are interconnected mechanically. I suspected the motor was going, so I unsoldered its black and red wires fom the small printed circuit board and removed it by also removing the two small screws on top. The board has a + mark and this is the red wire, remember which wires go where. (Might not be red and black.) I tested the motor with a flashlight battery and it seemed to run OK but didn't spin very long. This is a very small motor without a lot of reserve power. Removing it allowed me to oil the top bearing, the only one you can get at, as the bottom bearing is not open. You don't want oil all over the pulleys and the rubber band that rides in the pulleys and you have very little room to get the oil in under the plastic pulley. I used automatic transmission oil, a fine lubrican for a lot of things. This only takes about 1 drop of oil. If you get oil on the pulleys or belt, clean them with alcohol. This procedure fixed mine. Hope this helps.
Feb 20, 2009 | Philips Televison & Video
Failed to stop recording problem
I also bought this when it was new. I also paid about $150 for it and also had the exact same problem after a while. It seems that after so many hours some of the features stop working. However, through trial and error, I have discovered that you can still record using DVD-R only. For all the boasts of DVD /-R and DVD /-RW, it does not work after a certain amount of time. Philips does indeed have the worst customer service I have ever seen in any company out there. Contacting them is a nightmare and pure hell. I do hope that no one ever buys any of their products again and I also hope this little bit of info I posted helps someone.
Nov 11, 2007 | Philips DVDR3390/37 DVD Recorder
Recorder will say "unknow disc type"
Take the disk out, power off, and on again. If it still says "unknown disc type" instead of "no disc," the internal disk drive is the problem. You can try to clean the sensor, but there is a good chance the drive needs to be replaced. I have a Philips DVDR3400 that did the same thing. I bought a regular computer internal drive, connected the power supply and IDE cable, and it now works.
Nov 03, 2007 | Philips DVDR3390/37 DVD Recorder
MITE HELP
mines working fine but the heaphones broke, well one is louder tahn the other
Mar 23, 2007 | Philips HDD1630 MP3 Player
Philips DVDR3390/37 DVD Recorder Logo
825 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
