Question about Kenmore Washing Machines
20442991...washing machine wont go into spin cycle...i believe filter is clog...how to locate filter and clean?
fanny
  • 146 Answers
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Posted on Nov 03, 2007
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
MNTECH
  • 1543 Answers
SOURCE: where can I clean lint out of GE front-loader washing machine
You don't give the model number, so I can not know for sure. That being said, on newer front load GE washers there is a filter access right on the lower side of the very front of the machine. On many slightly older GE front load washers you will have to take the lower portion of the front panel off to find a filter access. On them, it is usually a bit to the right side, about an inch and a half round removable plug with filter attached. Be advised that when you take it out the remaining water from inside the machine and it's pump and hoses will also come out, so be prepared.
Posted on Feb 01, 2009
  • 228 Answers
SOURCE: neff washing machine not spinning
sounds like motor brushes have worn out will need to remove motor to replace they are inexpensive.the clicking is the relay telling motor to rotate clockwise or anticlockwise.
Posted on Oct 28, 2009
SOURCE: Washing Machine Wont Fill and cycles unresponsive, Help :/
My comment is generic to all washing machines in which there is a fill problem. Finally I remembered that when we did an upgrade on our basement I installed the type of fill hose that will prevent flooding. Sure enough, when I interchanged the hoses the problem switched from no hot to no cold. A flood prevention mechanism had malfunctioned on one hose and the reset feature did not work. A return to Home Depot will complete the solution to my problem - but I feel humbled to have overlooked the possibility that this simple malfunction had caused the grief.
Posted on Dec 07, 2009
My zanussi washing machine wont start a cycle. at first i thought it was the pump because it wouldnt spin cycle, so i put a new pump in and the spin cycle worked. i tried putting an a half load then and it...
Hi tdld6365,
Drain pump may be clogged. Even though you replaced the pump, the filter may still be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Washing Machines
My machine will not spin or go to the next cycle
Hi johnson_anit,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
Jul 18, 2011 | KitchenAid Washing Machines
Hi our Bosch exxcel washing machine has stopped spinning and doesn't reach the end of its cycle most of the time. If it does the washing is still soaking and needs a new rinse and spin cycle after....
Hi gillsteer,
Kind Regards :-)
Jul 18, 2011 | Bosch Washing Machines
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Front load washer
  1. Turn off machine and unplug it.
  2. Open filter it and clean it.
  3. Check if in pump turbine is clogged or jammed with foreign object. On some pumps you can test if turbine it rotates free using screwdriver or a finger.
  4. Check if the drain outlet pipe is clogged.
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
Apr 20, 2008 | Washing Machines
Nov 03, 2007 | Washing Machines
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Nd appears onscreen
First drain out the water from the machine with a tube. You have to check your outlet filter, likely it is clogged. Clean out and refit. Your machine will not do the spin because it knows the filter is clogged.
Jun 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
112 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
