Question about SAMTRON 55V 15" CRT Monitor
Vga Port I wont to My Old Crt Monitor use like a television. So can i gave tv signal via 15 pin monitor input cable. How can I Prepare the Cable Please Help Me. thanks
Hey there!
by default, you cannot connect a tv signal cable like that..mainly because, the monitor does not have a built in tuner :)
what you need to do is get yourself a tv tuner card, internal or external and you're good to go :) you would need your entire PC though..some external tuners allow you to connect without the PC itself :)
Posted on Jun 03, 2008
My monitor has no signal
Monitors typically use one or more of the following connectors to your computer:
  1. VGA (15 pin connector) usually Blue
  2. DVI (multiple pin configurations exist) usually white
  3. Display Port
  4. HDMI
Your monitor must be connected with one of these connector cables, and the Input on your monitor needs to be set for the correct input type (usually automatically selects based on detection of which connector the signal is coming through).
Typical things to look for if there is no signal:
  • Cable not fully seated on one or both ends
  • Computer not turned on
  • Bad cable (rare)
  • Bad video card or on-board card in the computer
  • Bad monitor
Dec 28, 2017 | Computers & Internet
HP L1950 DISPLAY MESSAGE NO DVI INPUT
in this situation, there are two options. 1.The device connected to your TV via DVI cable is off. 2. DVI cable connected to the HP L1950 is burned.
if you try to connect a device to the HP L1950, it has two ways to connect:
Input Signal - Two connectors: one 15-pin mini D-sub analog VGA and one DVI-D. Try VGA them.
Apr 06, 2014 | HP L1950 Monitor
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
I want to use my television as a computer screen. How do I switch the television to proper mode?
Look for a button on the remote or the TV itself labeled Source or Input. This should let you change the input between TV, AV, HDMI (on some TVs), and PC. Just press the button repeatedly or use the up/down arrows.
Before setting the input to PC (VGA), turn off the TV and the computer. Then connect the VGA cable (M-M) and the audio cable (a 3.5 mm M/M cable, if you plan to use the TV speakers) between the two units. Next turn on the TV and set the input to VGA. Then turn on the computer. (This is if you are using the VGA or D Sub 15 connection.) For a desktop, if you do not have another monitor connected, the TV should automatically be detected and the resolution set with any Windows OS (XP and later). However, you may need to reset the resolution and the refresh rate. For Windows 7, right click on the display and choose Screen Resolution.
For a laptop, you may need to enable the video port in the BIOS. Accessing this depends on the manufacturer of the computer motherboard. (Often Esc, F1 or F2 is the key to press after turning on the computer but before the OS loads. This can be tricky to time correctly.)
With a laptop or a desktop with another monitor attached, you will need to tell the computer how to deal with the multiple monitors. (Extend, monitor 1 only (or laptop internal monitor), monitor 2 only (external monitor), or dual display.) For my HP laptop with Win7, I choose Graphics Properties instead of Screen Resolution. There may be a keyboard Fn shortcut to access this.
Some TVs will accept a PC signal on the HDMI port (directly from an HDMI port on the computer or via a DVI to HDMI cable). Not all TVs do this. (Without the model for your TV, I can't confirm if this will work. If it doesn't, it is because of the differences between the PC output signal and that of set top boxes (cable or blu-ray players).
I hope this helps.
Aug 18, 2011 | Insignia Televison & Video
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
We have a panasonic 32"inch lcd tv.we want to
hdmi Ports Qty 3 port(s) PC Interface VGA (HD-15) HDCP Compatible Yes
I read your tv has 3 hdmi ports and a PC input.
if your pc has hdmi out - the you use a hdmi cable from the pc to the tv on one of the hdmi inputs.
if your pc has a 15pin vga cable you can unplug from your PC monitor (or go buy a VGA cable if you want to keep one on the tv and one on your pc monitor - or if you are using a laptop).
when you unplug the computer from the monitor .. check the pins - should look to be about 15 pins in the connector. it that will plug into the tv- then you are using a vga cable. if it will not plug into the tv pc input .. don't force it. It could be a dvi connector . .take the cable off the PC and to radio shack and they can fix you up (you need a dvi to vga cable - not likely, but possible)
I always turn off a pc before disconnecting monitors - and plug into the other display before turning the pc back on.
Good luck.
Bill.
Nov 29, 2010 | Panasonic TCL32U22 32 in. TV
How do i connect my tv to my notebook computer
You get a VGA cable from a local electronics or computer store and connect the laptop vga external monitor port *(its the 15 pin D shaped blue port) to your TV's VGA input *(also a 15 D shaped port).
Then, when you want to watch your computer on your tv. Change your TV input to computer and toggle the laptops video output *(usually by pressing the laptops FN key and one of the function keys that has a picture of a monitor on it simultaneously).
That should do it. And, if you want the picture on both displays the FN feature normally gives you that option if you press the buttons again.
Good luck and enjoy!
May 04, 2010 | Protron PLTV-4250 42 in. LCD Television
Ilo 42'' says no signal on VGA when connected to a computer
Snap off/fully remove pins 11, 12, and 15 from a spare VGA cable and use this to connect the ILO tv. These pins are used for identification of the monitor by the PC. The video signal is now displayed perfectly on my ILO tv, in all supported resolutions.
Mar 11, 2009 | Televison & Video
Samsung LCD TV not receiving PC signal
Check your vga cable. Some cables have only 14 pins, some have all 15. The missing pin is pin 9, in the 15 pin cable it carries 5v from the graphics card to the screen. Without that 5v signal most LCD and Plasma television screens won't recognise a PC input. I had the same problem and only managed to fix it when my girlfriend swapped a cable over for me and as she did so glanced inside and said "it's got a bit missing" The cable that came with your PC most likely only has 14 ins as that is all a monitor screen needs.
You can buy a 15 pin cable at most PC or electronic shops, just check that isdoes have all 15 pins befiore you buy it. The cheap ones are just as good as the expensive ones unless you are buying 20 foot cable. For 6 foot cable the cheap ones are just as good as the expensive ones.
Mar 08, 2008 | Televison & Video
SAMTRON 55V 15" CRT Monitor Logo
164 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
