Question about Danby 7,000 BTU Portable Air Conditioner - Euro Gray
Installation The instructions to my danby 7,000 BTU Portable AC states that the end of the exhaust hose should be inserted into the rear of the unit. However it does not specify where in the rear it should be installed. any suggestions?
  • 525 Answers
This is apparently a new product, and not having provided me with a model number, I was only able to ascertain that this is a dual hose model? If so, then I would assume that since there is no direct correlation between 1 hose and the other, that it probably doesn't matter, since both hoses are utilized for proper operation. Click the link below for more information.
http://www.rainbowappliance.com/Air-Conditioners-1/Danby-DPAC90061-9000BTU-115V-PORT-AC-DANBY-3340.html?utm_medium=shoppingengine&utm_source=yahooshopping&cvsfa=673&cvsfe=3&cvsfp=DPAC90061
Posted on Jun 03, 2008
Need my users manual
Here is a link to a 12,000 BTU, Danby Portable AC Unit. Since you failed to mention the model number of the unit you have, I can only guess that is the same as yours. In any event, all Danby Portable AC units work the same. You can download and print this manual for future reference.
http://www.danby.com/cms/uploads/products/en_manual/DPAC_12099_EFOM.pdf
I hope this helps you and thanks for choosing FixYa.
Jul 23, 2011 | Danby Portable Air Conditioner
I need to replace a hose on a Danby portable airconditioner model # DPAC120068
The first place to start is with the manufacturer, Danby 800-496-6049. Or take a section of the hose with you and go to your nearest home center and purchase a similar hose (same diameter) and use all the existing fittings that you have, to remount it with the new hose. There are several types available that will work well for this type of application and probably last longer than the original hose did.
Hope this helped you. Please let me know. Thanks.
Jun 08, 2011 | Danby 7,000 BTU Portable Air Conditioner -...
Patio Door Kit
look in the yellow pages under sheet metal fabricator
J.
Jul 04, 2010 | Danby 7,000 BTU Portable Air Conditioner -...
Does this air conditioner draw fresh air form outside through the
i dont think you are drawing air from outside you are expeling the heat from indoor ...outdoor so for it to cool the room you must vent the hose outside
Apr 09, 2010 | Danby 7,000 BTU Portable Air Conditioner -...
MY PORTABLE AIR CONDITIONER NOT WORKING!
There is a switch inside the bottom of unit that shuts it off when it is full of water. Has to go in just right to be able to work. Russ
Jul 24, 2009 | Danby 7,000 BTU Portable Air Conditioner -...
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
Danby 7,000 BTU Portable Air Conditioner - Euro Gray Logo
424 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
