Question about Watches
Cannot change time, but there is proper movement when stem is pushed in
Is there a solution other than taking to a repair shop?
  • Boboblues Jun 05, 2008
    Rotary Revelation new in box, hands on white face will move to set time, not on black face, both sets of hands "keep time" (i.e., move in synch) but at different times.
  • Anonymous Oct 31, 2008
    I can't work out how to change the time on the reverse face of my Rotary Revelation!!!
I spoke to a Rotary technician and they explained what to do. The smaller dial on the second side works the same as the larger on on the first side, with 2 exceptions. First, it only pulls out one click, since there is no date that can be set. Second, it is very hard to pull out. I used a penknife, just eased it gently under the smaller dial and popped it up. Once you do it the first time you realize how simple it is, however they should have put a dial with a better grip on it!
Posted on Nov 02, 2008
Put new battery in pulsa chronograph 100m watch how do I get it working Plz help
You might need a jump start the watch, or cleaning. I usually try using a air dust blower ball to get all the particles that is invisible to the eye, you can do this on the movement and around the battery area. Aftwards try inserting the battery again then pull out the stem and move it clockwise at least 10 times passing the 12'o clock marker. If the watch is not brough back to life you can try one last thing before buying a new movement or taking it to the watch repair shop. If you take it to watch repair shop they might charge you a few bucks to jump start the movement. I hope this helps. Marcelo
Oct 22, 2013 | Pulsar Chronograph Watch
I have a FOSSIL mens wristwatch model # AM3423. I recently had a watch repair person replace the battery. Battery type and charge confirmed. I received the watch used as a gift from a relative who was...
Quartz watches stop working most often for one of three reasons: (1) dead battery; (2) dirt in the gears blocking the train; and (3) a bad crystal. This is the order in which I typically troubleshoot watches.
If the watch isn't working after you change the battery, first check to see that the stem is fully pushed in. A watch movement can shift just enough inside the case that a stem sometimes looks pushed in, but isn't quite in far enough to re-engage the movement. Pull out and push in the stem a few times to see if that changes anything.
Next, assuming that the battery is indeed fine, look closely at the second hand. Is it moving at all, even a tiny bit? Hold the watch up to your ear. Is there any kind of "chunk" sound about once every second? If you can answer "yes" to either of these questions, a speck of dirt has gotten into the movement and is preventing the gears from moving freely. It doesn't take more than a a big spec of dust to cause this. Sometimes, advancing the time will move the gears enough to cause the dirt to fall out. Some watch repair places also have a special machine that spins the hands rapidly to blow out or compact any dirt in the train. It's usually not economically rational to have the movement professionally cleaned beyond this point.
Finally, if you don't hear anything coming from your watch, the battery is good, and the setting stem is pushed firmly and completely into the watch movement, you may have a bad quartz timing crystal. It does happen, and when it does, the only repair is to replace the entire watch movement. Sometimes, that's affordable; sometimes, it just doesn't make sense.
Sep 20, 2012 | Fossil AM3424 Wrist Watch
I want to remove the stem from a Miyota 2015 Movement and insert a shotened version.
Hello Malcolm,
You can view the details with diagrams on how to remove the stem from this link:
Stem Removal (screw type)
Stem Removal (Push Button Type)
For the complete guide, you can refer to this link:
Changing Watch Movement / Stem
Oct 21, 2011 | Watches
I want to remove my quartz movement to dry moisture from inside my watch. How can I remove crown, so that I can remove movement? Watch is old Gruen. Not worth shop repair.
Thanks for contacting FixYa.
It is WAY too risky to remove crown/fixture. Try this instead;
  • Step 2 Lay the watch in a dry place in sunlight and see if the water evaporates on its own. Put a piece of soft, absorbent cloth such as a towel under the watch. If the water inside the watch face is only a fine film of condensation that clears on its own after a short time, you probably do not need to do anything else.
  • Step 3 Seal the watch in a plastic bag filled with unopened packets of silica gel desiccant. These are the packets that come in shoe boxes and other packaged items. You can also use dry rice instead of the silica gel packets. Leave the bag somewhere warm and dry for a few days. The silica gel packets or rice can help draw out the water from inside the watch.
  • Step 4 Direct a fan at the watch or use a hair dryer on the lowest heat setting to blow air on the watch. Alternatively, if you can safely leave the watch on top of a low heat source such as a floor vent or radiator, this can help evaporate the water from inside the watch.
  • Step 5 Obtain the appropriate watch repair supplies. If you need to purchase tools, look for these at a watch repair shop or at a jewelry store. You can also find watch repair tools online. You may need small, fine-tipped screwdrivers and watch openers and closers.
  • Step 6 Take off the back of the watch, as if you were changing the battery. Use care not to scratch or damage any of the mechanisms such as the coil or stem. Let the watch dry thoroughly in the open air until there is no trace of moisture. Reassemble the watch once it is dry and press the seal firmly back into place. If the seal does not fit tightly, you may need to replace it
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Best regards. Jewel
    Sep 21, 2010 | Watches
    Perpetual Calendar Two Tone , SLL086 Watch for Men: sometimes when you take the stem out of a automati...
    mcdevito75 here, Look for a small watch repair shop in your area for adjustment, don"t force the stem into any position, chances are it just needs an adjustment a watch maker can make.
    May 12, 2010 | Seiko SLL086 Watch
    The stem pulled out of my airspeed day date auto- what to do??
    Dont try to put it back in yourself...put the watch and stem in a plastic baggy and take it to a reputable watch repair shop. Its too easy to slip and miss the hold that the stem goes into and you can do some other damage to the movement!
    Jan 19, 2010 | Airspeed Revue Thommen 8516002BBLUE Wrist...
    I was changing the battery in my watch and the hands fell off.I think I can put them back on however I can't get the time adjust pin out.Can anyone help?
    Stop...take your watch and all the parts to a reputable watch repair shop! The time adjust pin is called a "stem" and there is a TINY little release in the movement that you would need jewelers loupes to see! Save yourself time and frustration and let a pro help you! :-)
    Jan 16, 2010 | Adidas Sport Adp1131 Watch
    Stem falls out
    It can happen to ANY watch! Take it to a reputable watch repair shop and let them fix it....just needs some loctite but the stem needs to be removed from the movement so the crown can be correctly put back on!
    Jan 13, 2010 | Invicta Watches
    Removing the crown/stem of CASIO EF-321
    Other case for a simple Casio quartz watch :
    Jan 15, 2009 | Casio Edifice EF106D2AV Wrist Watch
    How to remove the movement ,the stem to release the movement
    when your watch is open already ,near the stem inside the watch there is small hole,use a needle to push this hole while pushing you pull also the stem,that it then take out the machine ,when going back the stem just put back where you taken,and it automatically lack,you cannot take out unless you push the hole,...that all benton..if my suggestion help you to understand your problem rate me as fixya..
    Jun 21, 2008 | Watches
    Watches Logo
    393 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
