Question about Samsung Refrigerators
Hi i have a samsung fridge freezer and it works fine for about four or five hours then trips the fuse box then it won't go back on it. can it be repaired or should i get rid if it is beyond repair .
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Sounds like defrost heater is faulty , you can buy it on its own
this video shows you how to fit
Posted on Oct 17, 2010
Testimonial: "thanks a million exactly what you said it was i was giving it one more day then it was going to the tip cheers to every one"
Samsung rsh1nhmh fridge freezer not turning on and tripping electrics.
sounds like electrical fault within your freezer any small fault will throw your contact breakers on your consumer box without blowing the fuse in the appliances plug
Aug 30, 2015 | Samsung Refrigerators
My samsung will run fine for about 4 hours and then will get too cold. if i unplug it and then plug it back in it will then work fine for another 4 hours. please advise thank you
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Feb 14, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
FREEZER WORKS...FRIDGE DOESN'T
Hi,...
In that case you need to check this
  • Make sure the refrigerator is plugged in securely
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for current
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outlet voltage
Good luck !!!
Regards
PCmania
Jul 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
Lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Mar 10, 2009 | Refrigerators
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge freezer model number srs615dp. The temperature displays -16 and 3 degrees. After approx 10 hours the display flashes. Turn off the power and on again and it displays 4 and 14 degrees and...
Hi just wondering if you figured out the problem with your Samsung fridge yet.
It is definately a problem with the defrost part of the fridge. After approximately 4 to 10 hours dependent on many different factors it enters into defrost mode to get rid of any excess ice in both the fridge and the freezer. During the defrost stage the compressor will not run. If any fault occurs during the defrost stage the fridge will not restart unless you turn it off and back on again which restes the pcb and takes it out of defrost mode and the timer starts again.
Please let me know how you went with it.
Jul 04, 2008 | Frigidaire FRT18B4A Top Freezer...
Kelvinator fridge/freezer problem
It could be a thermostat but is more likely to be a defrost problem. If it freezes up within a short space of time I would suggest contacting a fridge guy who should be able to diagnose either the defrost heater, defrost thermostat, defrost timer or thermostat. Hope this is of some help.
Sep 14, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
276 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
