Question about Xerox WorkCentre PE16 All-In-One Laser Printer
PE16 throws lots of extra sheets when printing
When printing or copying, more than one sheet is expelled. It is much worse when the in-tray is nearly empty when a whole bunch of clean sheets are expelled along with the copy.
    President:
  • 2,072 Answers
There is a small rubber pad, probably yours in shiney gray. It is worn, it is the pad that stops multi sheet feeding. You can scuff it up some with some sandpaper, that will help, but call 1-800-835-6100 and follow the prompts. Or google a business called The parts drop, then call Britt and see if he has that.
Its a pretty cheap part and easy to fix. Its on the paper tray.
Posted on Jun 05, 2008
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Ricoh copier i make some copies but when i turn the papers to print the other side of the sheets the paper gets folded as it enters leaves the tray and creates paper jam
Make sure the ink is dry and the paper is cold before replacing as this can weaken the paper strength and cause it to fold. Also a lot of printers are very picky about paper alignment and don't like you just putting in single sheets. Try having at least 6 sheets in the slot and 'tapping' them on a flat surface to align the bottom surface before feeding them in.
Oct 22, 2013 | Office Equipment & Supplies
Installed new printhead,took new ink I had just put in old printhead and put it back in new printhead. Will print nothing.just spits put blank 4x6 photo paper it says to load in to get calibration.Then it...
The document specs of your printer is given below:
Document & Media Handling Max Original Size Legal (8.5 in x 14 in) Original Type Sheets Min Copy Size 3.5 in x 5 in Max Copy Size Legal (8.5 in x 14 in) Standard Media Capacity 100 sheets Output Trays Capacity 50 sheets Document & Media Handling Details Input tray - 100 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ Output tray - 50 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ ADF - 3.94 in x 5.9 in I would rather suggest to take a print in normal A4 size plain paper and see what you get. Please revert back Suspected 1) paper scanner faulty not able to judge paper.
Sep 10, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
My Xerox 4150 keeps taking lots of blank pages through when printing multiple page documents sometimes 30 or 40 at a time
Two possible solutions to your problem.
If you are talking about grabbing more sheets than one from the tray, you need to make sure the tray guides are up flush against the paper.
If on the other hand you are talking about scanned/copied jobs, check the setting for your scanner, it may be set to letter size which is longer than A4, so the machine thinks it needs another sheet to complete the job causing a blank page to be sent.
Hope this helps
Jan 10, 2011 | Xerox WorkCentre 4150 Black and White...
HP Laserjet 4350 not recognizing addtional paper trays
Print a CONFIGURATION Page. On the 1st sheet/right side near the bottom will be a list of the trays that the printer detects. If all the trays are there, then your print drivers need to be reloaded. If the CONFIG page doesn't see the extra trays, then the tray may have a bad connector. You might want to try a COLD RESET.
May 12, 2010 | HP LaserJet 4350dtn Printer
DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
May 11, 2010 | Canon iR 1600 Laser Photo Printer
How do I print 8-1/2" x 14" paper. I only have one 8-1/2" x 11" tray? Konica Minolta Magicolor 5430DL
On the 5430 DL there is an aux legal tray that can be purchased for legal printing. On a later successor the 5550 a manual feed option was included, however for the 5430 there is no option for printing legal without the extra tray being installed. On a side note, I have this tray and when not printing legal it lets me load an extra 500 sheets of letter paper which is very convenient when I need to print a bunch of sheets overnight.
Mar 15, 2010 | Konica Minolta magicolor 5430 DL Laser...
My kodak easyshare5300 is printing black picture
Hi-
If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
Try this first
Calibrate your printer, then print a demo sheet.
  1. If paper is in the photo paper tray, remove it.
  2. Load photo paper into the photo tray.
    1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
    2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
  3. Calibrate your printer.
    1. Press Menu.
    2. Select Calibrate Printer, then press Start.
    3. Wait for your printer to print the calibration sheet.
    4. Place the calibration sheet face down on the scanner glass.
      • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
      • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
    5. Press Start.
    6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
    7. Remove the calibration sheet from the scanner glass, then press OK.
  4. Print a demo sheet.
    1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
    2. Select Print Demo Page, then press Start.
    3. Wait for the demo sheet to print.
Then call them if issue Persist at these numbers:
In the U.S. and Canada: 1-800-421-6699
In Australia and New Zealand: 1800 793 895
Thanks for using Fixya!
Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper tray
place the sheet properly in paper tray like put deep inside like when you feel some resist stop it putting inside
Sep 08, 2007 | HP PSC 1510 All-In-One InkJet Printer
Printing and faxing more than one page at a time
Hi This is a common problem, not only with your printer, but most at some time or other. In part it seems you get what you pay for, in that if you buy premium paper (business grade 40 mil), you normally have less problems. The paper is drawn into the printer by a rubber or compacted foam roller, and sometimes the paper sheets will sick to each other, and more than one will be drawn in. The best thing to do if you are using less expensive paper, or even the expensive stuff, is to "fan" the stack of paper several times with your thumb, at the end that will face the rollers, and also don't let the stack get down to only 3 or 4 sheets, as the problem is worse near the bottom of the stack. Hope this helps. Good Luck!
Nov 30, 2006 | HP OfficeJet 6110xi All-In-One Thermal...
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
51 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
