Question about Black & Decker String Trimmer Cordless 12" 18V
Grass trimmer/edger Will improper threading damage trimmer motor?
  • 313 Answers
SOURCE: CST2000 Grass Hog Cordless Trimmer/Edger stops working until shaken
open up the motor housing maybe loose connection between the terminal & motor. for parts & diagram see www.dewaltservcienet.com look for the icon find it now & enter the model #
Posted on Jul 26, 2008
SOURCE: head of trimmer/edger doesn't spin
i have the same problem, the plastic timing pulley on the motor assembly is probably melted, remove all the screws down the side of the housing, including the one hidden under the label, and you will find that the belt and the pulley are both chewed up.
Posted on Apr 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: I have a Black and Decker Grass Hog trimmer and I can't get it
There is only a couple of reasons that I can think of that would cause this
1. The string is wound the wrong direction; it should be wound clockwise on the spool. (This is my bet.)
2. Or maybe, the string is too small for your particular trimmer, but this is very doubtful.
Jim
Posted on Jun 19, 2009
Hy Tech Syst
  • 12 Answers
SOURCE: How do I use the B & D edger and trimmer
This is for a MCCULLOCH TRIMMAC 210, 21CC (petrol/gas Line Trimmer).
http://safemanuals.com/user-guide-instructions-owner-manual/MCCULLOCH/TRIMMAC%20210-%2021CC-_E
Operation of this and other Line Trimmers are all the same with some exceptions with optional attachments.
Posted on Aug 31, 2009
How to rethread spool on black and decker grass hog cordless trimer
with fine file , refurbish male threads.
determine the female threads with magnifying glass to determine damage to female threads. female threads can be repaired with a die from OSH or H/D. ask for help to find the right thread pattern or take them both to the hardware store to get the right die
May 29, 2014 | Black & Decker 14" Grass Hog Xp...
Ok I have a black&decker Grasshopper trimmer I do not no how to thread to spool it has a double spool everytime I thread it. It comes a loose.
There is a tiny hole where you must put the string through in the spool. Then hold it there with your finger and start wrapping the way it shows on the top of the spool.
Aug 06, 2010 | Black & Decker 14" Grass Hog Xp...
Motor runs but grass weeder does not move. Is it
simple answer NO as it will be the same price as a new one sorry
Jul 16, 2010 | Black & Decker 14" Grass Hog Xp...
I was trimming and the head stopped turning, motor still going. Is there a repair center around Charlotte,NC???
May have grass or line bound up between moving and non moving parts. If motor is free wheeling, then the plastic driven gear is likely damaged. The part is not consumer available. No one that I have read about has been able to find it.
Apr 03, 2010 | Black & Decker 14" Grass Hog Xp...
We were trimming our grass and the line stopped spinning
flex shaft most likely broken check online or at a local lawn and garden shop the are normally not too much and somewhat easy to replace
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
Motor spins, shaft does not...
sounds like the cable has broke inside the tube or it popped out of place. loosen the bolt on the motor casing holding the tube and separate the two pieces and pull the cable out. Should be a square at each end of cable.. if not post again
Jul 23, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker String Trimmer Cordless 12" 18V Logo
51 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
