Question about GoVideo TW1730 17 in. HD-Ready LCD Television
Unknown mode I have been trying to fix the resolution on my go video tw1730 monitor after my computer had the motherboard and hard drive replaced. I disabled something and now I cannot get the PC mode to work. The desktop momentarily comes up when I switch modes - but then I get a black screen that says unknown mode. Help!
  • Anonymous Mar 31, 2014
    i have intex it 191 model tv tuner..someday ago the pipfunction was working but now it says unknown resolution while i set it 1440x900 with 16:10 ratio plz help
    Genius:
  • GoVideo Master
  • 1,689 Answers
Check the instructions for the default resolution for your monitor. Start your computer in the safe mode. In the safe mode, the resolution should come up at the minimum. Now go in to the screen properties and set the resolution recomended for your monitor.
When you start the computer normaly, it should now come up in the last setting that you put it in to while you were in the safe mode.
Jerry G.
Posted on Jun 03, 2008
Monitor flashes on and off when I turn on computer , how do I fix this?
A hard drive has absolutely noting to do with a monitor, a hard drive is for storage, it's what windows is stored on. Try going into the settings and lowering or raising the resolution of the monitor itself.
Mar 24, 2013 | Envision EN-7410 17" Flat Panel LCD...
Changed motherboard so do I need to reload drivers to get moniter to work
Occasionally after updating or changing a graphics card, Windows may fail to load. This is usually a driver-level issue and can be fixed by installing a different set of drivers. To boot up Windows you may need to use a lower resolution and refresh rate. This is called "VGA Mode" and you can force Windows to run in this mode using the boot menu. Turn on the computer. Press the "F8" key until you see a boot options window. Use the arrow keys on your keyboard to select "Enable VGA Mode" and press "Enter." If you do not see "Enable VGA Mode" try the "Enable low resolution video" setting. If that fails, you will need to use the "Safe Mode" option.
Test all leads that attach to your hard drive including electrical extensions the leads from your ((motherboard to your hard drive)) Sata make sure they have a secure connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty? even something as small as a faulty fan power lead can cause this problem a computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly make sure your graphics card is securely seated with no dust in its socket If you physically remove your graphics to check the socket card restart your computer this should activate found new hardware wizard Hope this helps.
Dec 29, 2012 | Gateway MX6028 PC Notebook
MONITOR POWER INDICATOR BLINKING CONTINIOUSLY.MONITOR COULD NOT DISPLAY ANYTHING.MY COMPUTER HAS IGB RAM,ASUS MOTHERBOARD ,SATA HARD DRIVE.
Signal out of range, the display can't manage the resolution setting being sent to it by the video card.
- - - - - - > The following applies to Microsoft XP and newer OS a) Try booting into your OS in safe mode. Repeatedly press f8 key as computer starts to power up.
b) Right click on empty area on the desktop and select properties or personalize.
b) Select display settings.
c) Select the lowest resolution and color bit depth available (usually 16 bit).
d) Apply or click OK.
e) Restart CPU.
It should be working now, but mega big & ugly.
Set your monitor resolution to next higher setting. If that works, keep futzing with it till it's to your liking.
Sep 16, 2011 | Samsung Syncmaster 2033SW Monitor
My problem is my computer cannot open the display in the screen is "check the video cable"
Good Day Efren!
When you turn on your PC and your monitor displays "Check the Video Cable", it means that there is no signal coming out from the video card going to the monitor.
It just gives you the direction to check if the VGA cable is properly connected to the video card and to the monitor. There are two screws that need to be fixed to both ends of the cable to ensure its connection. You can also try other VGA cable to make sure that the one you are using is not faulty.
After you have made sure VGA connection is secured and restarting the PC did not fix it, the next suggestion might fix it.
Turn off your PC and unplug it. Disconnect VGA cable from the video card and open the casing cover. Disconnect the video card from the motherboard. Using a clean clothe moistened with alcohol, gently wipe the contact surface of the video card. Reseat the video card properly to the motherboard. Return the casing cover and connect the VGA cable.
Restart the PC and see if that fix the problem.
Good Luck Efren!
You can give some ratings if this fix your problem.
Thank you for asking Fixya.
Jun 09, 2011 | Computers & Internet
HP monitor keeps saying "monitor
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 07, 2011 | Acer P205H Widescreen LCD Monitor
I had upgraded my RAM from 128mb to 1Gb.after a few days i noticed the computer's display screen has been reduced to half of the size and is very shaky.its very difficult to work as it is causing...
Open the driver for the monitor and attempt to renew.
1-start in safe mode - check to see if the monitor clears up
2- try a different monitor.
3- You can be sure unless you either put the monitor on another machine or #2 put another monitor on your machine.
4 - I am sure it is not the ram.
5- check for heating problems.
6- attempt another video card an updated one.
7 - the problems you describe sound more like a resolution problem. If the monitor will allow for a greater resolution than your pc is capable of then you must - start in safe mode and change your resolution settings or -- put another monitor on and change the resolution.
Try all of these and let me know if you get your fix in these parameters.
Thanks for choosing Fix Ya.
Gary
May 30, 2010 | Computers & Internet
Computer screen goes into "digital power saving mode"
You should be able to adjust the settings on the monitor to prevent it from going into power save mode, or at least to delay how long it takes before it goes into power save mode. Press the menu button and look for settings that might disable or change power save mode.
Also, does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your newer monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PC's video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG L1915S 19" LCD Monitor
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Feb 15, 2010 | LG Computers & Internet
Monitor resolution
What do you mean that you were unable to get the native resolution of 1440x900? Are you saying that the resolution varries?
Since you mentioned that the mother board supports 1440x900, try to set the monitor resolution to that same resolution and then restart the computer.
If you will get the same problem, you have to make sure that the video card supports 1440x900 resolution.
Apr 15, 2009 | LG L194WT 19" LCD Monitor
THERE IS NO SCREEN DISPLAY WHEN I CONNECT MY GO-VIDEO FLATSCREEN
Start in SAFE MODE AND CHANGE THE RESOLUTION OF THE SCREEN, the screen does not suport that resolution.
Jan 19, 2009 | Computers & Internet
GoVideo TW1730 17 in. HD-Ready LCD Television Logo
203 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
