Question about GE JGRS14 Gas Single Oven
HELP! what is the best way to replace the ignitor on a GE JGRS14?? mine doesnt glow. Oven will not turn on.
    Brigadier General:
  • 3,513 Answers
This is a common problem. The oven to heat the igniters must heat up enough to open the oven safety valve. This happens by the igniters drawing enough amperage thru the safety valve. Just because it glows it may not be strong enough. or if you see no glow it may have a broke coil in that igniters and wont glow at all. You will need a volt meter to check if no glow. If soft glow, replace igniters. The igniters costs 5$. You can consult your manual to replace it yourself.
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Posted on Oct 16, 2010
  • Ruth Carlson Dec 09, 2011
    The manual does not tell how to get it out
GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Nov 24, 2012 | GE JGRS14 Gas Single Oven
Tip
Replacing igniter
GE wall ovens have panels for regulator and ignitor wiring at the lower back of oven. remove all screws and plates to expose wiring. clip off defective igniter and use ceramic wire nuts to fasten new one. re-assemble.
I learned from local gas company that igniter is most frequent part to replace.
cost = $35
GE technical support = non-existent.
power of the internet - priceless!
on Jun 18, 2008 | GE JGRS14 Gas Single Oven
Not heating stays at 100
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 17, 2010 | GE JGRS14 Gas Single Oven
Oven wont light
Check the amp draw on the ignitor. If 2.9 amps or less, replace the ignitor. If 2.9 amps or more, replace the gas safety valve.
Aug 02, 2009 | GE Ovens
Don't know how to light GE Glow-Bar oven
Perhaps the oven ignitor (glow bar) is defective. To test, check the voltage going to the ignitor when you turn on the oven to bake. If you have 110 volts testing with a voltage meter, replace the ignitor. If you do not have voltage, trougleshoot backwards to see where you have voltage in but not out.
If I can help further, I am here.
Eric Campion
Mar 04, 2009 | GE JGRP17 Gas Single Oven
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
Oven won't heat up
hi atdowhower,for your oven to heat the[ignitor]must heat up enough to open the oven safty valve.this happens by the ignitor drawing enough amprage thru the safty valve.just because it glows it may not be strong enough.or if you see no glow it may have a broke coil in that ignitor and wont glow at all.you wll need an volt meter to check if no glow.if soft glow,replace ignitor.shoul be very brite.God bless,tom
Jan 02, 2009 | GE JGRS14 Gas Single Oven
Will not fire up
see the post under tips for replacing igniter yourself
Apr 28, 2008 | GE JGRS14 Gas Single Oven
Electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Nov 13, 2007 | GE JGRP17 Gas Single Oven
GE JGRS14 Gas Single Oven Logo
171 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
