Question about Canon Cameras
I know the batteries are fresh, have tried several rounds of 4 new batteries. But, when push On/Off button it fails to respond. Nothing happens. Cannon PowerShot A610. Can confirm camera has never been wet and I take good care of it. 2nd time happening, 1st time lasted only overnight but now camera hasnt turned on in days
  • Canon Master
  • 4,738 Answers
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
Posted on Jun 04, 2008
Can't get my dell Inspiron 1525 to work. Tried all the obvious . It simply won't load anything. It freezes just when you think something is happening. Please help
Try to "Cold-Start"your laptop: 1) unplug from AC outlet, 2) remove battery,3) hold on/off button for 10 seconds, 4) replace battery 5) plug into AC outlet, 6) try to boot normaly. let me know what happens.If it fails repeat process and when you push the on/off button REPEATEDLY TAP THE F-8 KEY until you get a response. let me know what happens.
Nov 01, 2012 | Computers & Internet
Intermitantly working v2 rangefinder
Had the same problem with my first Bushnell V2 (Slope). Worked intermittently and sometimes just quit altogether. Finally had to send it back to them. They sent it back and said nothing was wrong with it. I called them and told them they were wrong and I was sending it back and they should take more time in testing it. This time they acknowledged problem, said it was fixed and sent it back to me. I wound up getting a real good deal on the V2 without the slope calculator (necessary if you want to use it in championships). Used this one for some time with no problem, but now it just went dead again. Battery tests well into green area on meter, but I'm going to try a brand new one and see what happens. From all the things I've read about the V2 and battery life, it looks like you might need pretty fresh batteries to keep it going.
Jul 22, 2012 | Bushnell Tour V2 Pinseeker Laser...
I put new lithium triple aaa batteries in my TI-83. Nothing happened . days later it turned on worked for a little while then stopped. would it help to change the round lithium battery? Do you know what...
The button cell backup battery keeps the memory electrically refreshed when the calculator is turned OFF. The necessary power for regular use is supplied by the 4 AAA batteries (main power). That nothing happened when you put in a fresh set of (expensive) lithium batteries may be due to the screen being too dim to see anything.
If the calculator displays RAM CLEARED each time it is turned on, it may be due to a depleted backup battery. The battery model number is CR1616 or CR1620. On my TI84PLUS the backup battery is of type 303 (Sony) or SR44SW (Maxell).
Sep 05, 2010 | Texas Instruments TI-83 Plus Calculator
Coolpix L1 that won't take a picture after getting wet
try dismantling you will find a gooey substance in a microchip. try removing it.i hope it works
Sep 12, 2009 | Cameras
New remote for WII
you need to sync it with the console
Apr 13, 2009 | Nintendo Wii Console
Tv does not respond to remote commands
You need to isolate the problem.
1) Unplug the TV for a few seconds and then plug it back in.
2) Operate the TV with the buttons on the TV. (Channels etc) I presumed you have scanned in the channels.
If no problem found then do this for the remote.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Now try the remote to see if it works. If it fails you will need a new remote.
Mar 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Power on Problems
Sounds like your battery is dead. Does the phone respond when you plug in the charger? If it does not respond, you may either have damage in the charging port, or a bad charger. If the phone recognizes the charger, shows that it is charging, but still won't work when you unplug it, I would recommend trying a new battery. You should be able to go to a retail store that sells razr's and ask them to try a different battery in the phone to see if it works. If it powers on with the new battery, buy it.
Sep 18, 2008 | Motorola Mobility RAZR V3
Garmin Foretrex 101 won't respond to pushed buttons
while this may not be a fully working solution, have you guys tried pressing and holding the page button while at the same time pressing power. hold them in for a while and see what happens. it might just work. mine is sort of working after doing it a couple of times. page+power same time and hold longer than 5 sec just to be sure.
Jan 20, 2008 | Garmin Foretrex 101 GPS Receiver
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one.
Apr 03, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Cameras Logo
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
