Question about Dometic Refrigerators
How to calibrate br400 blood bank refrigerator??? if we set the switch position 1/2/ 3 & enter the service menu but that condition we can not changed CAL/offest etc. can u explain how to eliminate 2 degree C error from the machine?
  • 107 Answers
SOURCE: the computer says Random / muliple cylinder misfire detected
look for a vacuum leak
Posted on Feb 27, 2009
  • 7 Answers
SOURCE: touch pad seem to be out of calibration - when you
not sure what tom tom you have but try this (found in a forum)
SAW THIS IN ANOTHER FORUM - RESOLUTION TO SCREEN CALIBRATION ISSUE
So I will give it a try to help sort out a friends TomTom.
Method valid for NavCore versions until 8.051.
A manual method to correct the calibration of the touchscreen input device of any all-in-one TomTom systems consists in creating a file called calib.txt (e.g., with notepad) and saving it in the main directory of the TomTom disk memory (e.g., the SD card; the same directory of the ttsystem file).
calib.txt should include one line with four numbers separated by a space: MaxX MinX MinY MaxY
Notice that the ‘x’ sequence (max, min) is inverted than the ‘y’ sequence (min, max). MaxX > MinX and MinY < MaxY.
For instance, the file can include:
928 118 107 912
Each TomTom device has its own most appropriate sequence.
In order to compile the file with default data, one method could be to perform a TomTom reset (or to eject the SD card), powering on the device and holding down the ON button for a few seconds until a unit status screen appears. The line named “Touchscreen calib. data:” will include four numbers that in sequence represent MinX MaxX MinY MaxY; these numbers can be used to fill the configuration line of calib.txt remembering to swap the first two ones. For example, if the unit status screen returns 118 928 107 912, calib.txt has to be saved with 928 118 107 912.
Tuning can then be done by adjusting these numbers until the touchscreen is calibrated. Distortions like screen rotation, trapezium and rhombus correction cannot be achieved with this method even if tuning these parameters can provide an acceptable touchscreen management even in presence of distortions; the best screen to tune the calibration is exploiting the soft keyboard of the NavCore application.
For instance, in my old TomTom GO Classic device I realized that, after activating the NavCore soft keyboard, when moving vertically (Y axis) the cursor appeared calibrated, while the horizontal movements (X axis) prevented to manage the left and right key columns (especially in the left bottom corner positions). So, I left the last two digits unaltered and, after some tests, I successfully used the following values: 805 200 107 912.
Method valid for NavCore versions post 8.051.
For NavCore versions 8.2x and 8.3x, use the same method as mentioned above, with these small differences:
the file should be named cal.txt (and not calib.txt) and should again be positioned in the main directory of the SD (or HD) drive of the TomTom system (e.g., the same directory where ttsystem can be found). Besides, the four numbers included in the file should have a different sequence than what previously described for versions until 8.51; cal.txt shall include the following sequence: MaxX MinX MaxY MinY (notice that also MaxY precedes MinY).
For instance, cal.txt could include the following four digits: 928 118 912 107
Again, these numbers are specific of each TomTom single unit.
E.g., my TomTom GO Classic correctly runs 840 245 912 107.
Posted on May 19, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have a blood bank refrigerator with temperature
5 degrees fluctuation is normal, anything over that, then I would suggest testing thermometer and thermostat.
Posted on Aug 26, 2009
Max J
  • 22 Answers
SOURCE: Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
Posted on Sep 07, 2009
emissionwiz
  • 80407 Answers
SOURCE: where are bank 1 sensor 1, bank 2 sensor 1, bank 1
bank one sensor 1 is the bank of cylinders that number 1 spark plug is located in, bank 2 the other side, this assumes u have a V8, the sensor one location is the sensors that are BEFORE THE CATALYTIC CONVERTER, the sensors referred to as sensor 2 are after the ones AFTER THE CATALYTIC CONVERTER IN THE EXHAUST SYSTEM.
Posted on Apr 28, 2010
Menu segreto hannspree hsg1113
http://translate.google.com
Secret service menu Hannspree HSG1113
https://electronicshelponline.blogspot.com/2015/03/hannspree-lcd-tv-how-to-enter-service.html
Possible menu - Quoting from link above:
SERVICE MODE [Hanspree AT06 42" LCD TV] (Horizontal Frequency 31.5KHz to 48KHz)
* In the TV mode, adjust volume to Zero and press number keys 9 > 8 > 7 > 6 to enter service mode.
* To exit, press the EXIT button on the remote control.
SERVICE MODE (Hanhspree GT02 32E - GT03-37E1)
1 Switch on the LCD TV .
2 Press 9-9-1 on the remote control to enter the internal Service menu.
3 Press MENU to switch the service mode pages.
4 Press ?? to scroll through the various menu options.
5 Press ?? to change the menu settings.
6 Press MENUto save the new settings and switch to next page and press EXITto exit from service mode to normal mode.
TV / AV / S-VIDEO / WHITE BALANCE / BRIGHTNESS & CONTRAST ADJUSTMENTS
WHITE BALANCE ADJUSTMENT
1 Press 991 on the remote control to enter the internal Service menu.
2 Press MENU to switch to the PW106 Scaler Menu page
3 Press ?? to scroll to Page 2-3 options
4 Press ??
to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings.
5 Press EXIT to save the new settings and exit. [Don't adjust others setting in page 2-3]
Click on the Pictures to Zoom In
BRIGHTNESS ADJUSTMENT
1 Repeat the above mentioned step 1 to 2
2 Press ?? to scroll to PW106 FE VDC Menu Page 2-1 options
3 Press ?? adjust the Brightness setting.
4 Press ?? to scroll to TV/AV/S Parameter=AV1 setting and pressuto run the setting. (This procedure will copy the settings of AV1 to S & TV)
ATSC DTV WHITE BALANCE / BRIGHTNESS / CONTRAST ADJUSTMENT
2 Press ?? to scroll to PW106 Scaler Menu Page 2-3 options
3 Press ?,? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings
4 Press to save the new settings and exit. [Don't adjust others settings in page 2-3]
YCbCr & YpbPr of COMPONENT 1, 2 WHITE BALANCE/BRIGHTNESS/CONTRAST ADJUSTMENT
Getting COMPONENT-1 connect to 1080i signal. (The settings could not be saved if signals input from COMPONENT 2 or connect to other sources such as 720P, 480P, 480i,etc.
WHITE BALANCE ADJUSTMENT OF Component
1] Repeat the above mentioned step 1 to 2
2] Press ?? to scroll to PE106 FE ADC page 2-3 options
3] Press ?? to adjust the Offset Red and Off Blue settings.
4] Press ??to adjust the Offset Green setting.
5] Press ?? to adjust the Gain Green setting.
6] Press ?? to scroll to 480i/480P/720P Parameter=1080i setting and press ? to run the setting. (This procedure will copy the setting of 1080i to 480i/480P/720P)
7] Press EXIT to save the new settings and exit.
WHITE BALANCE ADJUSTMENT OF PC INPUT
1.Connecting to VGA Timing mode
2.Under service mode, Press ?? to scroll to PE106 FE ADC page 2-2 options
3.Press ?? to adjust the Offset Red, Offset Green and Off Blue settings.
4.Press ??
to adjust the Gain Red and Gain Blue settings.
5.Press EXIT to save the new settings and exit.
May 14, 2018 | Hannspree Televison & Video
Tip
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Samsung LA32A450 32 in. HD-Ready LCD TV
Suzuki xl7 2007 when you wiggle key in ignition check engine comes on with code p0008
great answer
my guess, op simple turns key to on, and is not really wiggling it.
just doing the normal thing. to start car.
then fails to ask a real question, just a statement in fact.
what does it mean.
what do i do (get car serviced as the opr. guide states)
what tests to do, if DIY savvy, RTM?
just 4 bucks to read it .
https://suzukipitstopplus.com/Products/10182-2007-xl7-service-manual.aspx
what is a good guess? (my guess is loose cam drive.)
all my guesses are useless..... car unseen or inspected.
3.6L V6. GM LY7 engine
https://en.wikipedia.org/wiki/GM_High_Feature_engine#LY7
Suzuki calls this the N36A engine.
with VVT cam drive
if the chain gets loose it can fail. this.
and lost more....
get it serviced?
or the tensioner is bad.? (wild useless guess 2)
x marks the spot?
Jun 12, 2014 | 2007 Suzuki XL7 AWD
Code p1131 please help
P1131 - Lack Of HO2S Switch - Sensor Indicates Leanxicon.jpghttp://engine-codes.com/p1131.htmlForum CodePossible causes- Vacuum leak affecting bank 1 only
- Fuel injector problem bank 1
- Check for cylinder misfire on bank 1
- Engine mechanical condition
- Faulty O2 sensor. Symptoms- Engine Light ON (or Service Engine Soon Warning Light)P1131 Description A Heated Exhaust Oxygen (HO2S) sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
Jul 25, 2012 | 2009 Tata Indigo GLS
I have a p0008 code & I'm worried
P0008 CADILLAC - Engine Positions System Performance Bank 1
The ECM detects that both camshafts on either bank of the engine are mis-aligned with the crankshaft for more than 4 seconds or a cumulative of 50 seconds.
The Engine Control Module (ECM) monitors the position of both camshafts and the crankshaft. The ECM performs a test for misalignment between both camshafts on one bank of the engine and the crankshaft. During the test the ECM learns the position of the camshafts and the crankshaft. While the engine is idling, the ECM compares the position of both the camshafts and the crankshaft with the learned value. The ECM will set the P0008 code if both learned values for one bank of the engine are exceeding a calibrated threshold in the same direction.
Symptoms
Possible causes
- Engine mechanical problems
- Incorrect timing chain
- Stretched timing chain
- Failed camshaft actuator or actuator solenoid
Tech notes
There is a factory service bulletin for the following Cadillac models:
2004-2008 Cadillac CTS SRX
2005-2008 Cadillac STS
The service bulletin suggest replacing the primary drive and both secondary drive timing chains. Contact your Cadillac dealer for more information. The repair could still be cover under factory warranty.
Hope this helps (remember to rate this answer).
Jun 02, 2011 | Cadillac SRX Cars & Trucks
During tank refilling
With switch on press YES/ENTER & STOP/NO key at the same time and watch the screen to come back as normal condition. If it is the same then you have to replace SCALE assy.
After replacing SCALE assy.you must CALIBRATE the new scal before use the machine. For calibration follow as bellow:
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key. now follow the on screen text.
NOTE:you should have 9KG/20LBS of weight for scale calibra
Hope this will solve your problem & if my solution is useful to you please vote for it.
Jul 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
My hp printer color 2605 does not print correctly with colors
Sometimes we need to calibrate your printer, and the normal calibration does not help us (which comes in the configuration options), to calibrate the Cpr and other components must enter the secondary service for that we must take the following steps:
1 Confirm that the printer is in a state of "ready".
2 Press (SELECT) to enter the menu list.
3 Press the button (left arrow) and the (CANCEL) simultaneously.
4 Press the (SELECT) to enter the secondary service.
5 Press the button (ARROW LEFT AND RIGHT ARROW) to navigate the secondary service) in one of those going to choose service menu.
then you enter calibration option and you will have the following items
All Cals
■ CPR Cal
■ DMAX / DHALF Cal
■ Only Cal DHALF
■ Test Page
We tested the first of all callbs and prints a test page
also, in the same secondary menu you should try with the option to clean ETB, it might be faulty, is the most you can do. test and leave a comment to know how did it go
Apr 07, 2010 | HP Color LaserJet 2600n Printer
Upper body workout arms on Startrac 6230 crosstrainer are locked in the ''None'' position. How do I switch to ''Pushing'' or ''Pulling''?
You May have to recalibrate Here is the procedure
Engaging Maintenance Mode 1. Press and hold the , and keys together. 2. A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information window. 3. Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode The following keys are used to modify Maintenance Settings: Upper and Lower Data Information Window SCROLL keys: Display the next and previous settings. Increase and Decrease Level Keys: Adjust the value of the displayed setting up and down respectively, in increments of 1 unit. OK Key: Updates (saves) the value of the display setting in the Flash
Diagnostics - UB Calibration UB (Upper Body) Calibration (Elite Only) The UB Calibration will set the minimum and maximum range of the upper body arms in which they can move within. You can do a Manual Calibration or an Auto Calibration. Auto Calibration is recommended. To calibrate the Upper Body: 1. Enter the Maintenance Mode (see Settings – Maintenance Mode). 2. Press until UB Calibration is displayed in the information window. 3. Press to enter UB Calibration Mode. Manual Calibration 1. For Manual Calibration press 1. 2. Press the until the upper body arms stop moving (None Position), and then press to save. 3. Press the until the upper body actuator stops, and then press the to save. Auto Calibration For Auto Calibration press 2. The display will automatically raise the arms up, then bring them back down to calibrate the positions.
Mar 15, 2010 | Startrac Fitness Products Exercise &...
Mar 23, 2009 | Health & Beauty
Plotter needs recalibration
You need to enter the service calibrations menu, to do this select the set up menu, once inside the set up menu press the up arrow & enter keys together. This will take you to the service tools menu, from here select service calibrations (printhead alignment and colour calibration are both in this menu). If you still here problems after you have calibrated your machine or the calibration fail replace the printheads.
Oct 16, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
Refrigerators Logo
61 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
