Question about Durabrand DVD-1002 DVD Player
Blew Up My DVD player snapped and started smoking, and shut off.  I pushed the power button, another snap and more smoke. The smoked smelled horrible.  I don't know what's wrong with it, nothing got spilled on it.... What can I do?
    Genius:
  • 1,689 Answers
The power supply is probably what blew. There is nothing you can do yourself other than sending it for repair.
Considering that this is a low end player, It may not be worth to pay the cost of servicing it.
Jerry G.
Posted on Jun 03, 2008
HOW DO I REPLACE BATTERY ON FIREX FX1218
BATTERY REPLACEMENT Always turn off power to smoke alarm before replacing battery.
Replace battery at least once a year, or immediately when the low
battery signal sounds (a beep once per minute indicates low bat-
tery). Batteries should be replaced regularly as necessary, even
when the smoke alarm is receiving AC power.
Use only the following batteries as replacements in this smoke alarm: Eveready 216, 522, 1222, Duracell MN 1604, or Ultralife U9VL-J [Alkaline batteries 9Volt] DO NOT USE RECHARGEABLE
BATTERIES.
1. Turn off power to smoke alarm at main service panel.
2. Turn smoke alarm counter-clockwise to detach from mounting plate.
3. Gently pull down smoke alarm. Be careful not to separate wire
connections.
4. Pull out power plug from back of smoke alarm.
5. From back of smoke alarm, lift tab to open battery pocket door.
6. Remove battery from pocket. Disconnect and discard bad battery from battery connector.
7. Connect a fresh, 9-volt battery to connector. The battery will fit
only one way. Be sure battery connector is securely attached to
battery terminals.
8. Place battery into battery pocket.
9. Close battery pocket door. Push down until it snaps into place.
10. Replace connector plug. Connector will "snap" into place.
Gently tug connector to be sure it is attached properly.
11. Reattach smoke alarm to mounting plate by turning smoke
alarm clockwise until it snaps into plate.
12. Turn on power and test smoke alarm using Push-to-Test button
Jan 03, 2018 | Home
Dodge caravan 2001 blowing burning power steering fluid.
I can answer some of your questions without being there in person.
The smell inside the van is from fresh air entering the venting system. Not sure why you don't get it from all vents. The fresh air intake is in front of the windshield and will pick up any smells from the engine compartment.
Loosing the serpentine belt would not necessarily cause you to loose ps fluid, but having a leak could drain the pump and damage the bearings in the pump, causing the pump pulley to drag on the belt.
The ps pump could be in the final stage of failing.
And the shaft seal in the pump could be leaking fluid onto the engine and exhaust.
Feb 23, 2013 | Dodge Grand Caravan Cars & Trucks
Smokes and smells like gas at muffler
That has to be gas that is not being burned! No idea why blowing a fuse with the air compressor rashed your car like that - must be coincidental or collateral damage.
Sep 04, 2017 | 1994 Ford Mustang
Whenever I start the car it smokes than after warming up it stops smoking.
The key is how much smoke? Does the smoke have a smell to it. Are you consuming any fluids, like coolant, or oil?
Tons White smoke that is sweet smelling is usually coolant getting into the combustion chamber.
Less white smoke, especially if other cars are doing it, is normal. For every gallon of gas that you burn, you generate a gallon (GALLON) of water. so this water usually evaporates, but sometimes not. It has little or no smell.
If the smoke is bluish white, that is oil, but usually your converter would fill with oil, and cause error codes, or loss of power. This smell is distinct, but not necessarily sweet.... After the converter heats up, it may be able to burn off the oil and the smoke stops.
What are you consuming, fluid wise, will direct where you go next.
Jan 27, 2011 | 1995 Lexus LS 400
I accidently sucked up a pen cap and it stopped working then it began smoking and the belt snapped??
Take the pen cap out of where it is stuck and replace the belt. Most likely the smoke was from the belt slipping around the gear and getting hot. Did the smoke smell like burning rubber?
Oct 01, 2009 | Bissell 3576 CleanView II Bagless Upright...
Smoking
If it smoking,get rid of it immediately!,its dangerous,and not worth the risk of a fire
May 03, 2009 | Durabrand DUR7 Portable DVD Player
Intermittant loud "pop" when starting my microwave
Clean well the inside of the oven, if you keep having the problem and the inside is clean, then the magnetron is starting to go.
Jan 28, 2009 | GE Microwave Ovens
Smoking DVD player
Throw it away an buy a new one. WalMart's dvd's and all their electronics stuff are produced in china without any quality control and from the cheapest components. They aren't even worth repair.
Buy a branded DVD (SAMSUNG, Sony) to avoid future problems.
May 05, 2008 | Durabrand DVD-1002 DVD Player
Durabrand DVD-1002 DVD Player Logo
65 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
