Video Game Consoles & Games Logo
Posted on Oct 16, 2010
Amstrad DD9900 manual - Video Game Consoles & Games
What type of mini sky receiver box do I need for a 4f3006 Amstrad box 501 201.
You want the version with the Ethernet port and external power supply to go with your
4f3006 Amstrad
I need a service manual for an Amstrad DRX890 sky box...
Google,input name/model followed by "service manual" should be able to download from there.
What i was after was a manual for amstrad emailer plus phone em 2001
Dear Brian Clarke,
Here is the link for the user manual that you require.
http://www.amstrad.com/emailer_faq/emp_auk/index.html
Or you can try
http://www.amstrad.com/emailer_faq/user_guides/index.html
I hope that this is the fixya for you and I look forward to hearing how you get on with this query.
Yours sincerely
Ouszen
Feb 07, 2012 • Cell Phones
1helpful
I have a signalex universal remote" has any 1 got
The codes the manual gives for Amstrad Satellite equipment as...
0317, 0372, 0408, 0488, 0497, 0515, 2014
Or use the auto method...
1) Turn the device you want to program on.
2) Press the button you want to program it in as (i.e TV1, VCR1, etc.)
3) Press and hold the Set and Power Button on the remote for a few seconds, pointing the remote at the equipment.
4) Release the 2 buttons and the light on the remote will flash.
5) As soon as the device turns off press any key on the remote and the light will stop flashing,
6) Check the remote now operates correctly, if not repeat the above until it does
A 220 volt Amstrad monitor that i want to convert to use 110 volt
engagetek, This would be a very easy thing to do if and only if the label on the rear of the unit has printing similar to my GATEWAY LCD. It states as follows: "100 - 240VAC input 50/60hz." If your Amstrad unit's label reads "220-240VAC 50/60hz only, then you will need to reverse engineer the "ac to dc" power supply, be it an old "linear" or a modern "switch-mode-power-supply" type. You did not state what type of monitor technology your Amstrad is. CRT, LCD, Plasma,???? I would guess that it is a CRT type. Well anyway, I hope the info was of some use. Bye for now, I'm louie12fix on fixya
How do i read emails on my amstrad emailer plus phone
Press and hold down the email button. I found their website that also has the complete user guide if you need it.
Please vote "Yes" for me!
4helpful
2answers
Manual. need to know what the connections are for
User guide or Manual for Amstrad Sky+ ...YYY
2 posts - 2 authors - Last post: 27 Jun 2007
I need to add a second sat lead from the LNB to the Box. None the less I need a book of words that tells me about the Amstrad 180 sky+ box. ...
forums.vnunet.com/message.jspa?message... - 29k - Cached - Similar pages -
Sky Digibox remote control codes for your television
This User Manual is the ideal solution if you've bought a Sky Digibox without one. .... it ALSO operated ALL of the functions on my Amstrad Sky+ receiver (not .... in the Digital Installation Manual or via the Sky Customer Service option in ... This actually selects Sky+ mode, but a Sky+ remote works a sky HD box. ...
www.satcure.co.uk/tech/digicode.htm - 49k - Cached - Similar pages -
User manual AMSTRAD SKY PLUS - User guide AMSTRAD SKY PLUS ...
User guide AMSTRAD SKY PLUS. USING YOUR SKY+ WELCOME TO YOUR SKY+ BOX GUIDE .... to repair your Sky+ box. For repairs, please contact Sky Customer Service. ...
safemanuals.com/user-guide-instruction... - 98k - Cached - Similar pages -
For Sale : Amstrad Sky+ Box and QED 1.5m Squart Cable - AVForums.com
Due to an upgrade to Sky HD I have for sale my old Amstrad Sky+ box (model no. DRX180). ... Will try to find the manual for it as well. ...
www.avforums.com/forums/home-cinema-hi... - 102k - Cached - Similar pages -
Amstrad Sky+ Box - HELP PLEASE! - Sky+ - Digital Spy Forums
6 posts - 5 authors
Amstrad Sky+ Box - HELP PLEASE! Sky+. ... The Specifications in the manual state: Hard Drive: 160 Gb (with 80 Gb for personal use); the packaging also has ...
www.digitalspy.co.uk/forums/showthread... - 55k - Cached - Similar pages -
amstrad sky plus on standby
Following the instructions at the top of page 66 in the Manual fixed it. .... Go back and wait by your sky+ box and you should see the red recording light come on, ... Sky & DLM, Sky Broadband Service Status, SkyUser Bandwidth Meter ...
www.skyuser.co.uk/forum/sky/17069-amst... - 117k - Cached - Similar pages -
sky+ box keeps making beeping noise. - Cable Forum
15 posts - 3 authors
can anyone tell me how to stop sky+ box from making a beeping noise, ... thanks paul ill read manual & see if that helps. my sky+ is an amstrad pvr3. ...
www.cableforum.co.uk/board/64/33616556... - 87k - Cached - Similar pages -
Sky+ box amstrad dx280 - FixYa
Technical Support, Instructions & Repair Service. Home | My Expertise | Sign In ... Related Searches: sky remote, sky box, amstrad, skybox, sky manual ...
www.fixya.com/support/t1223689-sky_box... - 49k - Cached - Similar pages -
MobilePhoneMadness.com - GUIDE: Upgrading Your Sky+ Box
Amstrad Sky+: Equal in size as the Pace Sky+ V2 and looks identical, ... We hope Sky will fix the V1 firmware at a later date, as there no manual fix we can ...
www.mobilephonemadness.com/forums/arch... - 13k - Cached - Similar pages -
Amstrad DRX 180 - Review - How did we live without it???
The problem with the cable service, however, is that when you look at the ... No matter which Sky+ box you end up with, the instruction manual is the same ...
www.ciao.co.uk/Amstrad_DRX_180__Review... - 82k
''Low Memory'' on Amstrad E-Mailer
E-mails use memory to have you deleted them?
Convert Amstrad Word Processor Files to PC
i would suggest you search the internet for freeware ,of the same type of program you have on the old Amstrad disc's
they will be:
  • Free
  • better quality
  • up to date
it just would not be worth while trying to find then use an emulator, if in fact there is one available to do what you require,
good luck
Terry
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
