Question about New Home Sewing Machines
I have a old new home knitlock overlocker the top needle (upper looper) is broke can u tell me where i can purchase a new one please
kent581
  • 87 Answers
SOURCE: timing on a Huskylock 535D surger
the eyes of the needles must line up with lower looper as they pass (timing) the distance between the needle and the looper must be exact. No distance between them and not touching. yep, that tight. they shouldnt move the needle even the slightest amount as they pass each other, yet no space between them.
Kent
Posted on Mar 19, 2009
SOURCE: thread continually breaking in lower looper needle
I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
4-3-3-3 and default settings for the rest.
Hope this helps someone someday.
Jo Griffith
Posted on Mar 29, 2009
SOURCE: The needles on my Janome 9102D keep breaking
I had a similar problem with my machine. What I've started doing with mine is setting the stitch length at 3 and the differential feed ratio at 1.0 then I set all 4 thread tensions at 3. I thread the machine from right to left, and then when everything seems to be working okay I take scrap material to test the tension and then set them to suit the material I'm using. Right now I'm working with a twill so my settings are 4-4-5-5. This seems to have stopped the thread slipping off the bottom looper and I haven't had any more needles break. I hope this is helpful.
Posted on Sep 01, 2009
SOURCE: When i use my janome overlocker the needle is
I have a ses 1000 singer, when I use the embroidery unit the needle is hitting the pressure foot. The needle does not line up in the middle of the pressure foot, and breaks my needles. I have the correct pressure foot attached. What can I do to fix this problem?
Belinda
Posted on Oct 04, 2009
  • 1116 Answers
SOURCE: Serger stitch not forming right
It sounds like the timing needs to be reset by a sewing machine repair tech.
Posted on May 09, 2010
How do you adjust the timing on a serger? I have a White Speedylock 1634.
There are a lot of web sites & videos dealing with timing. Just search for "serger timing" or "overlocker timing."
Jul 28, 2016 | Sewing Machines
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
Correct threading for 4 th. Juki ind. overlocker
Overlockers and or Sergers are ALWAYS threaded the same way. Upper looper, Lower looper, right needle, left needle. If you have a model number for your Juki we might be able to find you more information.
The best way to figure out tension problems is to thread each thread in a different color so you can determine which thread is giving you problems.
These machines can be frustrating and EVERY time the thread breaks you MUST start the threading problem from the beginning... upper looper, lower looper, right needle left needle.
Aug 31, 2012 | Sewing Machines
I have just inherited my Aunts NewHome 743 KNITLOCK Overlocker, but over the years she has misplaced the instruction manual, PLEASE can anyone help me locate a copy of one ?
I found my original instruction booklet for the New Home Knitlock Model 743 743D after being misplaced for many years. It is very old and tatty. I still have the overlocker stored somewhere as I replaced it with a new overlocker. I am hoping to sell the overlocker with instruction booklet when I get round to having the machine serviced. Please let me know if you still need a copy of the manual.
May 31, 2011 | Yamata FY750
I have a bernina overlocker and whenever I use it the lower looper (marked in red) thread breaks. How can I fix this? It was serviced yesterday and when other people used it before me it worked fine!
Then it's one of two things. First try setting your lower looper tension on 3 and see if that works. If not set it back on 4 and cut ALL your threads and re-thread the machine STARTING with the UPPER looper, then the lower looper, then the right needle, last the left needle if you're sewing a 4 thread overlock stitch. Make sure the threads aren't twisted in the thread guide. Make sure the lower looper thread is OVER the elbow on the upper looper and over the upper looper thread. Let me know if this works. We'll work until we get it fixed!
Sep 14, 2010 | Sewing Machines
I can't find my Bernina Serger 800 dl manual - how do I thread for a 2 thread rolled hem, and do I need a upper looper cover and that the heck is that anyway?? Thanks
From what I have read this manual is less than desirable. Neither is the one for the brand that I have.
You may have better guidance if you purchase and use Nancy Zieman's "Serge with Confidence". I have found it very helpful.
For the two thread rolled hem, the looper cover is used to "trick" the looper into "thinking" it is threaded.
On my serger (not a Bernina), this is referred to as a "subsidiary looper". It is a spring type mechanism that fits in a small hole at the top of the upper looper.
You use a rolled edge presser foot; right or left needle; stitch length @ normal or wider; stitch length @ 1mm for the left needle/0.5 for the right needle; differential feed @ normal; needle tension - tighten; lower looper tension - normal or looser; two thread looper cover - engaged.
Test and adjust the tension as needed before making the rolled hem on your garment.
I hope this helps.
Apr 18, 2010 | Bernina 1008
How do I change to straight stitching from overlock stitch please? I am using a friends Bernina1015 and she is in New Zealand!
Hi. Take out the looper threads and just leave the needles threaded. And if you want just one line of thread unthread one of the needles.
Of course then your going to have to rethread the loopers later to overlock in which case its important to do them in order.
Upper looper, lower looper, right needle, left. If yours is color coded as most are then the order would be blue, red, green, yellow.
Hope this helped.
Rick
Nov 05, 2009 | Bernina Sewing Machines
Timing on a Huskylock 535D surger
Kent
Feb 07, 2009 | Husqvarna Husky 165
Thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
May 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
27 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
