My daughter was playing around with my laptop and change the appreance ofmy screen. It is cloudy and big. i want to change it back to normal. can you help.
    Scholar:
  • 63 Answers
*********************SOLUTION 48********************
YOUR SOLUTION:
  1. right click on desktop.
  2. select properties.
  3. one new window appear.
    in theme tab select theme ' windows XP'
  4. click ok
or else you can manual change appearance in appearance tab..
ANY DOUBT? REMEMBER US.
RATE THIS SOLUTION, IF IT HELPS YOU.
THANK YOU,
Posted on Oct 16, 2010
Can you suggest any good pretend play props that we might have around the house? I want to encourage my daughter to pretend play more without having to spend on new toys.
You are totally right. Pretend play doesn't need a big spending spree to make it fun. Kids just love using household items for their games. It makes them feel big and grown up. Here are some examples;
Boxes ie cardboard
Dressing up clothes - old shoes, hats and scarves
Blankets and bottles
Kitchen equipment
Feb 18, 2013 | Toys
When turning on Dell laptop, lcd screen turns gray
Maybe you have wrongly pressed the keys for turning down the brightness of Dell inspiron 1545 under a careless.Just back to the normal setting. Good luck!
Feb 17, 2011 | Dell Inspiron 1545 Notebook
When i turn on my computer a black screen pops up saying enter current password._ Unable to use f2 or f12 What am I supposeed to do
Hi
You could try to start up in safe mode ( quite often f8 ) sign in as administrator and cancel the password
Also if you get into safe mode try a system restore back to when it was ok
Or hit delete key a few times when starting up hopefully this will take you into the bios because the f12 or f2 key may be disabled
Be very careful what you change in your bios because on a laptop its not very easy to change jumpers on bios battery so only enable the f2 or f12 then hit save and exit windows will then restart
But be very very carefull not to play around in the bios if you dont understand it you may end up with BIG BIG Problems
Nov 13, 2010 | Toshiba Satellite Pro L300 Notebook
Screen turned sideways
Hi there. Your daughter mus have press on something on the keyboard. Inorder to get the screen back to normal . Try to press and hold the crtl + alt + uparrow key at the same time. This will take your screen back to normal position.
May 31, 2010 | Dell XPS M1210 Notebook
The screen of my computer became big
sounds like the video settings have been changed by the download
goto control panel>display>settings and play around with the size until you are back to what you want
Feb 21, 2009 | Gateway MX6920 Notebook
Double images with the red in myKP-51HW40
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 18, 2009 | Sony KP-51HW40 51" Rear Projection...
Pictures are cloudy now.
I tried cleaning the printhead 3 times in a row and it made a huge difference. Don't give up after cleaning it just once if it doesn't make a difference. it wasn't until after the 3rd time that i actually saw a big difference. It's back pretty close to normal now. Hope this helps someone else.
Bill
Dec 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
Wrong region
Hey there, colchester. It appears your daughter, (Blessed be her little angel hands), may have managed to change the setting for TV type from NTSC to PAL, or vice versa. Try entering setup, and using the left arrow, or right arrow, move across the icons on the top of the screen, until you find the box on a plate "TV Type". From here change the type to the other alternate, and you are good to go.. If you still have a problem there is a more in-depth approach if required. Let me know. Good Luck!
Feb 02, 2008 | Digix HT1056A DVD
Widescreen reset
Go to the control panel and click display and reset it the way you want it. You may have to do this everytime you play your game.
Apr 25, 2017 | 3G Technology GEM GL-822A/B 17" Flat Panel...
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
