Question about Sony Playstation 3 (PS3) Console
Corrupted hard drive
My PS3 has come up with a screen that says "corrupted hard drive" how can this be fixed or can i buy a cheap hard drive???????
  • michael25 Jun 03, 2008
    i had a reply to my question regarding my corrupted PS3 hard drive from thor_rider08 can you contact me PLEASE
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey michael25,
When a Playstation 3 encounters an issue where data has become damaged or corrupt, the PS3 should normally prompt users to perform a system restore. In some cases simply restoring the PS3 will resolve the problem, but in the event that it doesn't further actions may be necessary.
Should a system restore fail, I would first suggest contacting Sony directly for service if you are still within the manufacturer's warranty. In many instances Sony is able to repair or replace defective hard drives within a few business days, but this would require you to ship the PS3 to them for the duration.
Alternatively, you may always either install a replacement hard drive yourself or attempt hard drive repair using third-party recovery tools. According to Sony, simply replacing or upgrading your hard drive does not void your warranty coverage. Please keep in mind that this coverage may not necessarily include third-party recovery tools (such as Microsoft's CHKDSK, Seagate's SeaTools, etc.), so you may wish to refer to your owner's manual documentation for confirmation before using a recovery tool option.
For step-by-step instructions on how to replace your PS3's hard drive, I would suggest checking out this article from Sony's online support database for more information:
http://www.us.playstation.com/Support/PS3/Manuals
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 05, 2008
Our playstation hard drive is corrupted. what should i do
Well if your using the older model of PS3's (FAT ones) what you can do to attempt to fix it is power off your ps3. Press and hold the power button, you'll here a beep. keep holding until you hear two beeps quickly( e.g. beepbeep) one you hear that, let go of the power button. If done correctly you will see a screen that has some options on it. The option you want is Restore File System. If that does not fix it, and continue's to tell you that the Hard Drive is corrupted, then you need to buy a new hard drive unfortunately.
I've placed a Video here for you that might help visually and also with the "beep" timing.
Apr 18, 2011 | Sony PlayStation 3 40GB System
Sony Playstation 3 (PS3) Console My PS3 hard disk is corrupted, It say to restore i put restore and nothing had been restored Bid
Corrupted hard disk? Lets see....
You could attempt to boot up the PS3 in safe mode and restore the file system (should delete any corrupted data). Describing how to start up your PS3 in safe mode would just be confusing, so instead here's a link to the official page on the PS3 Safe Mode feature.
Follow the instructions, and then I'd say try options 3 (Restore File System). If that doesn't work, try 4 or 5 (Rebuild Database or Restore PS3 System).
If that fails, you could just replace the hard drive. The PS3 uses standard 2.5inch SATA laptop/notebook hard drives (5400 or 7200 RPM). They can be found online at any computer parts website; for example, Tigerdirect.
If somehow the new hard drive doesn't fix it, or you don't feel like buying a new hard drive, you could send the PS3 back to Sony. If you're under warranty it's free; otherwise it's expensive (150$ I believe).
If you request the repair service, they send you a box, you put the PS3 in it and ship it back to them. A month or 2 later they send you a fixed/different PS3. Simple, but takes forever to get a working PS3 back which is why I suggest you try a new hard drive first.
Anyways, hope you get it working soon!
Mar 22, 2011 | Sony Playstation 3 (PS3) Console
My Ps3 keeps freezing up but only on 1 game. I've already tried switching disc with the same game. Can you help?
If it's freezing with the same game it means either one or two things.
Your game data is corrupt, fix them by deleting all instances of the game under Game Data. Make sure you backup your game saves to an external usb drive just in case.
2nd possible reason is you've got a bad sector on your hard drive, if the above doesn't work then I would suggest you swap out your hard drive with a new one. 320gb drives from Best Buy for for $50 so it's a pretty cheap fix ;)
Mar 17, 2011 | Sony Playstation 3 (PS3) Console
My PS3 says the Harddisk is corruptted. How do I
you can try reformatting it?
you can send it back to the supplier or if out of warranty buy a new hard drive. You will need a 2.5" sata drive and it slots in from the left hand side really easy. buy what ever hard drive size you like, the system will format it and set it up for use
Jan 30, 2010 | Sony Playstation 3 (PS3) Console
I have a corrupted file on my ps3 and it trys to repair it self after 30 seconds.it goes right back to the same screen. HELP!!!
Your problem may be more widespread than just that one file. The file system on your hard drive may be corrupt. You can try to reformat the entire hard drive in an attempt to remove all the errors in the PS3 data, or you can buy a new hard drive. You may have to replace the hard drive if the hard drive is failing, and therefore not reading or writing data properly.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
After installing the new Hard Drive you will need to format the drive. When you turn on the PS3, you will see onscreen instructions to help you with this.
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
Hard disk corrupted
vlynch2819
If you are getting the corrupted drive message on your Playstation 3 this means you have corrupted data on your hard drive. The link below will help you fix the problem with the corrupted data. Note if you still have trouble then you will need to replace the hard drive as there is something wrong with it.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or question
Issken
http://www.fixya.com/users/issken
Nov 01, 2009 | Sony Playstation 3 (PS3) Console
Hard Disc Corrupt .
no sorry you need to buy a new one
Jan 31, 2009 | Sony Playstation 3 (PS3) Console
Hard drive
You need to replace the hard drive. That's the ONLY way you'll be able to fix that problem. Any sata drive will do. newegg has them for super cheap.Or you can just grab one from a local Best Buy etc.
Dec 29, 2008 | Sony Playstation 3 (PS3) Console
Hard Drive PS3
The easiest method of working around a Corrupted hard drive is this.
You need to go out and purchase a 3.5" SATA USB Enclosure. they are quite cheap.
you then must remove your Hard drive from the PS3 and insert it into the enclosure.
connect the enclosure to your PC, the HD Will show up in your computer, you must then perform a FULL FORMAT on the harddrive under the FAT32 Format.
Once done, re-insert your hard-drive, and the problems should have gone !
If they do persist or the hard drive is still corrupted, i would suggest contacting sony Customer support !
Hope this helps ?!
Oct 28, 2008 | Sony Playstation 3 (PS3) Console
PS3 startup problem
replace the hard drive, it's probably corrupted.
Dec 28, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
112 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
