Question about Samsung LE26R72B 26 in. HD-Ready LCD Television
I have lost the digital signal to my Samsung LE26R8 TV. I can still view analogue. There is no option to rescan on the menu. This occurred after receiving a message asking if I wanted to upgrade the system to which I answered yes.
SOURCE: Digital Tv stopped working
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: fazalhareef@yahoo.co.uk
Posted on Apr 19, 2008
SOURCE: built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Posted on Dec 25, 2008
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
lyleglass
  • 32 Answers
SOURCE: i have digital tv with no signal
If you are accessing ATSC signal with an ATSC tuner, then you need an external antenna with good placement to recieve most channels. You may have to move it around. Be sure the coax cable to antenna is not too long with an un-amplified antenna.
Posted on Sep 27, 2009
  • 6 Answers
SOURCE: no digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Posted on Oct 05, 2009
I Have a 15inch acoustic solution telly with built in freeview model number astv15id , however it has lost most of the freeview channels how do i retrieve them back.
Go into main menu set up and navigate to option to rescan. (might be called install or re-install stations)
Note - if it has lost channels it may be due to poor signal quality - check the quality of your aerial connections. You may also have lost channels if your area has recently been subject to 'digital switch-over' . Although they are already on digital tv all Freeview boxes will need re-tuning after switch over because this entails a change of some channel frequencies post analogue.
Feb 26, 2011 | Music
Samsung lcd tv32 s 86 lost all freeview chanels. How do we get them back?
Enter the menu system and find the set up menu. Select the reset or retune option in digital mode.
It should rescan 21 - 68 and find the free view channels again.
Jan 03, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Reset code for le32r73bd - OTHER THAN INFO, MENU, MUTE, POWER
Jan 2016 --- Panzo's solution worked a treat, just remember to go into analogue, press buttons quickly, navigate to reset (option#12) and press left arrow which will remove the snow effect in analogue.
Thank you, and the rescanning worked without a hitch. Whew thanks again
Aug 02, 2010 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Lost digital channels, only getting analogue installed new antenna, no help other sony lcd is working fine
Got to -
Menu -> settings -> set-up menu -. auto start up
Rescan your tv for all channels.
Any more problems, call sony. 08456000124 local rate number
Dec 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
Lost all digital channels - Sony KDL-52W3100
Use ur original remote of the tv u want setup to the DTV box go menu switch cable back to air
reseption.Set tv channel 3 hook up the DTV box and rescan the channels u have it.
Aug 15, 2009 | Televison & Video
I have a Samsung LE26R72B. the digital tv has just stopped working. the digital screen has frozen with 'FILM 4' on it. i can't acces the digital menu and i cant change channel. all other features of the tv...
Solution that worked for me:
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jul 07, 2008 | Televison & Video
Samsung LE26R Digital Frozen
Beware: Although the process should be safe, it technically voids your warranty.
Jun 04, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung LE26R73BDX 26INCH - LOSS OF DIGITAL SERVICE
Dec 28, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung LE26R72B 26 in. HD-Ready LCD Television Logo
158 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
