Question about Microwave Ovens
HOW DO I CHANGE THE BULB IN MY PRESTIGE GS25 MICROWAVE
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: PRESTIGE CB130
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
jyackle5
  • 8197 Answers
SOURCE: Please how can I get
To get the manual for your microwave you need to send an email to www.meyergroup.co.uk Please give the make and model # so they know the item you are takling about.
Posted on Jan 08, 2011
SOURCE: manual for prestige GS25 microwave
Www.manualsonline.com hope this helps :)
Posted on Oct 21, 2011
How do i change the interior light inside my Panasonic The Genius Prestige model #NN-SD291W
The bulb, which may be replaceable, is accessed by taking the cover off the machine.
God bless your efforts.
Jul 28, 2017 | Panasonic Microwave Ovens
Prestige microwave
I believe that you are referring to the waveguide cover. You should be able to call a local appliance parts store to get a sheet of mica material that you can use the old part as a template to cut out a new cover for your unit.
Nov 20, 2013 | Microwave Ovens
How do you set clock on prestige microwave model sde23r
how to set time on prestige microwave sde 23r
Jul 02, 2012 | Microwave Ovens
Prestige gs25 microwave won't heat
no the problem is more than your fuze! Micro waves have a high voltage output transformer inside that goes bad. You can fix it yourself but if your not good with electronics I would have someone else do the job!
Feb 07, 2012 | Microwave Ovens
PRESTIGE CB130
On Prestige Combi Microwave the bub is on the control panel side. First remove the cover, Philips and torx required to remove screws on the back. *** MAKE SURE MAINS PLUG PULLED OUT ***
Looking at at the magnetron unit, find a black oval shape between it and the control panel with two wires plugged in, there are two bend strips holding the bulb holder in (this is directly behind the vent holes on the right hand side of the microwave oven), straighten them and extract holder with bulb, swap bulb with same rating and reverse the operation and re-assemble.
Jul 27, 2008 | Microwave Ovens
Microwave Ovens Logo
449 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
