Question about Casio FX-9860G Graphic Calculator
How to use casio calculator in solving regression problems
  • Casio Master
  • 7,993 Answers
I am sorry but I will have to assume that you know how to enter the data.
Once you enter your data [MENU][STAT], press [F1:Graph], select Gph1, Gph2, or Gph3. Once the graph of the experimental data is drawn, you will have access to the diverse regression models. Your choices are [X:Linear] [Med-Med], [Quadratic :X^2] [Cubic;X^3] [Quartic: X^2]. Press [F6] to scroll right to access the others: [Logarithmic:LOG], [Exponential :EXP], [Power :Pwr] and [Sinusoidal: Sin]
After you select a model and press [EXE], the screen displays the equation and its various coefficients. On that same screen, you have a menu option [F6:Draw]. If you select it, the regression curve will be drawn on the same screen as your statistical graph. This allows you to judge if the fit is good. If it is not, you have the option to choose another model.
The other option [F5:Copy] allows you to save the regression equation in the Y1, Y2, etc. variables.
PS If you do not know how to enter data post a comment to this effect and I will see what I can do to help you.
Posted on Oct 30, 2010
How do I type this exact equation into my calculator?
You should check your manual. The FX300MS has only three calculation modes: COMP (regular calculator), SD (standard deviation) and REG (statistical regression analysis). You cannot solve equations.
Apr 28, 2016 | Casio FX300MS Scientific Calculator
How to do interpolation in Casio f2f-4800p?
Interpolation mannual in fx-4800P - Fixya
www.fixya.com/support/t22818601-interpolation_mannual_in_fx_4800p
Jan 11, 2014 - interpolation mannual in fx-4800P - Casio Rare Vintage Scientific question. ... SOURCE: how can we do linear interpolation in casio fx-991ES ...
interpolate how can interpolate linear regression by casio ...
www.fixya.com/support/t22818666-interpolate
Jan 11, 2014 - interpolate how can interpolate linear regression by casio fx-4800P -Casio ... SOURCE: how can we do linear interpolation in casio fx-991ES ...
how to perform linear interpolation manually and on casio fx ...
? 6:39
https://www.youtube.com/watch?v=rCVM6RWMjQ4
Jan 7, 2015 - Uploaded by Yabets Jab
In this video you can simply understand how to find a value of a given missing number in a table on Casio fx ...Missing: 4800p
Linear Regression on a Casio calculator - YouTube
? 6:25
https://www.youtube.com/watch?v=OGmHagjZPjg
Oct 31, 2012 - Uploaded by cpobyrne1
How to perform a linear regression on a Casio scientific calculator. Example uses a ... A Casio fx-83WA calculator is used for the demonstration. .... Lagrange Interpolation Easily Explained on Casio fx-991ES Calculator!Missing: 4800p
Jan 05, 2016 | Casio Office Equipment & Supplies
How do i type the letter r on a casio calculator
It it is a graphing calculator, the sequence ALPHA 6 should enter the letter r on the command line. For scientific calculator, the r is a system variable that holds the correlation coefficient for some regression models.
Apr 25, 2014 | Casio Office Equipment & Supplies
How do i get l1 l2 l3 charts up
L1, L2, L3?
If you are doing statistics, Set MODE to 3. Stat.
Choose 1-Var or any regression model. If you press 1-var you will have two lists x and frequency.
For any regression model you have 3 lists x, y, and Freq(uency).
L1, L2, L3, are list names in the TI 83/84 Plus and the Casio graphing calculators.
However I have no idea what getting the charts up mean.
I hope it helps
Oct 26, 2013 | Casio fx-115ES Plus Scientific Calculator
How to get l1 l2 l3 charts
L1, L2, L3?
I hope it helps
How do you do turn on diagnostics with a casio fx-9750g plus?
You don't do anything for the Casios.. If the correlation and determination coefficients have a meaning in the regression model (such as linear regression) they will be calculated and displayed automatically on the same screen where the regression equation is displayed. However if the regression model has no such coefficients nothing will be displayed.
May 02, 2012 | Casio FX-9750GPlus Calculator
I forgot how to do linear regression on casio fx-115ES. Example: (1,2), (3,Y), (5,6). How can i solve for Y in casio FX-115ES?
Press [MODE][3][2]. In first column enter known x-coordinates (1 and 5), in second known y-coordinates (2 and 6). The solution you are looking for is in form Y=A+B*X where X=3. Your calculator computes A and B after you enter data. To calculate Y (which is equal to A+B*3 press [SHIFT][1][7][1][+][SHIFT][1][7][2][*][3][=]. The result should be 4.
If I helped you, please rate my answer :)
Sep 07, 2011 | Casio FX-115ES Scientific Calculator
Am trying to calculate corelation on a Casio fx-9750GII,
Press Menu.
Use arrows to highlight STAT icon and press EXE.
Enter your data in two lists (x-values in L1, Y-values in L2)
Press F2 to activate the CALC Tab at the bottom of screen.
This is what you see.
Press F3 to activate the REGression tab.
This is what you will see: the TABs at the bottom of screen.
Each tab corresponds to a regression model: X-linear, X2 quadratic, etc.
If you press F3:X^2, you get the following
You see the parameters of the regression equation, the coefficient of determination r^2, and the Mean Square error. No correlation coefficient is defined for this regression model.
For other models like linear, logarithmic, power and exponential regressions, the correlation coefficient is defined and is thus displayed with the regression equation. It is the r-value.
Jul 31, 2011 | Casio FX-9750GPlus Calculator
How do I find the correlation coefficient on my calculator?
You will find it on the same screen where you find the regression equation, the regression coefficients etc. However it is not defined for certain types of regressions.
Hope it helps.
Sep 26, 2009 | Casio CFX-9850G Plus Calculator
Casio FX-9860G Graphic Calculator Logo
360 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
