Question about Samsung HCN436W 43" Rear Projection Television
TV TURNS OFF SUDDENLY
Hi, I have a SP43H3HTX/XAX Samsung projection tv, I changed stk´s an 3.9 ohm resistors, however the tv turns off suddenly. If I press on/off in the remote control a few seconds after it turns off then a click indicates pressing on button the tv turns on and if I wait like 10 seconds after tv goes off and then press on button in the remote tv does not come back to on mode. I will appreciate any help
I had a similar issue with my Samsung. It would just turn itself off. I found someone else out who overcame it, forget the site. My fix was as simple as taking off the access panel to the lamp in the back and putting it back in making sure teh bottom went in first. It seems tehre is a switch that detetcs the door open and turns the TV off. The switch apears to "move up" with heat? Anyways, my TV would turn off every few minutes for severla weeks and now it has not done it in 2 days.
Posted on Jun 23, 2008
  • 21 Answers
IF YOU HAVE TO UNPLUG THE T.V. TO GET IT TO RESTART, IT IS PROBABLY HIGH VOLTAGE SHUT DOWN. IT CAN BE THE FLYBACK TRANSFORMER OR POSSIBLE BE A SHORTED CRT.
DOES THE SET HAVE HIGH USAGE ON IT ? WAS IT A FLOOR MODLE ? IS IT WATCHED MORE THAN 4-6 HOURS A DAY ? YOU CAN DROP THE CRT BOARDS AND SEE IF IT STAYS ON. OR REMOVE THE HIGH VOLTAGE (RED ) LEADS OUT OF THE HIGH VOLTAGE BLOCK. MAKE SHURE YOU DON'T REMOVE THE ONE GOING INTO THE BLOCK. ONLY GOING OUT. ALSO CHECK FOR COOLANT LEAK ON THE BOARD. IF THE STK'S ARE ON A SEPRATE BOARD YOU CAN UNPLUG THE CONVERGENCE BOARD AND SEE IF IT STAYS ON.
UNFORNATULY SAMSUNG IS NOT TAKING PHONE CALLS FOR TECH. SUPPORT. THE ONLY WAY TO CONTACT THEM IS BY FAX, AND IF YOUR LUCK THEY CALL YOU BACK IN THE NEXT 2-3 WEEKS....
DON..
Posted on Jun 03, 2008
My tv messed up overnight. It has a double vision picture and the picture adjust setting does not help it.
this is likely a convergence problem, the convergence chips- stk-xxx-xxx would need replacement
along with the large wattage resistors connected to them-look for 1-3 ohms the exact value varies
over a number of models do an ohms check replace if out even a small amount
Feb 05, 2011 | Samsung HCL4715W 47" Rear Projection...
Looks like the TV is 3D and a smell of burning when it is on. It happened all of a sudden no warning.
Replace STK ICs,big black ICs will have PN# on them.
also CK low ohm resistors Mats has ICs 1-800-628-1118
Oct 21, 2010 | Akai PT4298HD Rear Projection Television
I have Hitachi 50GX30B tv suddenly started to give green-red double vision with arcs On top and bottom of screen What is the solution?
The tv have a problems"Known as a Convergence problems"it,dead.The tv convergence board reqiure changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 19, 2010 | Televison & Video
Problem with stk's & low olm resistors on 55 in. Sharp
It's always best to remove one leg, however there tolerance is so close you should be able to get an exact ohm reading, and I mean exact. Some are connected in parallel so if they're 6.8 ohm then you'll read 3.4. What is the number of the STK's you changed?
Yes, I would replace them again.
Feb 27, 2009 | Sharp 55R-WP4H 55" Rear Projection...
Samsung HLM507W 50 in. STK IC's
STK-392-180s these are the best.Replace BOTH
Feb 01, 2009 | Samsung HLM507W 50" Rear Projection HDTV
Samsung SP42W4PHX convergance problem
Hi
The resistors are 39 ohms, metal oxide.
Usually both the stk392-010 ic`s (on heatsinks )
want swapping. You can get them off ebay..
Dave H.
Jan 17, 2009 | Toshiba 53H71 53 in. Rear Projection...
Color suddenly switches to 3 separate colors and is wavy
Replace STK ICS Both of them they are your convergence ICs will Have Part Number on them 2 big black ICs and there is Low ohm resistors that should be replaced also.rk42,46,48,50,52,54,60 62.
Repair Cost in Shop 325.00 and up.
Jan 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Double Vision ...w/waves on top/bottom too much green.
1024x768 Normal 0 Convergence
When A REAR PROJECTION TV has coloured outlines or a 3D image the Convergence Circuits most likely need attention.
Replacing the output amplifiers (located within the Convergence IC's) allows the pictures to line up correctly, and no more color outlines.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable shop/manufacturer's support to repair because of their design that causes other power supply or vertical deflection problems. The poorly designed products require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip may fail again.
This is not a simple repair like changing batteries or a fuse. Reading through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with other "new and improved" IC's, like STK 392-150. These are devices with different characteristics and require different value resistors in the circuit. Replacing with the STK 392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience working on your JVC. My website is below with some costs and explanation.
calgaryconvergencerepair.weebly.com/convergence-explanation.html
Good Luck,
Easyab
Jun 05, 2008 | JVC AV-56WP74 56" Rear Projection...
Sudden shutdown - Red light blinking 3 times
Replace both convergence Ic's Stk392-110 and personally I'd use STK392-150's for greater reliability. Also check all 2.2 ohm 2w resistors for open or change in value and replace as many as needed...
Bill
Apr 18, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Samsung SP42Q2HD standby fault
tha convergence /def. board is faulty,change as a unit.
Dec 13, 2007 | Samsung HCN436W 43" Rear Projection...
Samsung HCN436W 43" Rear Projection Television Logo
262 people viewed this question
Henry  Thomas
Henry Thomas
