Question about IBM TP A20M PIII700MHZ 64MB 12GB 14.1"24X 3COM COMBO (26334WU) PC Notebook
Change of Hard Disk
Original hard disk (IDE, Toshiba 6.0 GB) of the laptop failed and I need to change it. I could not find a hard disk of the same size. The minimum was 40GB (Fujitsu). Do you know what is the maximum hard disk size I can install in this laptop? Could I install a 120 GB Hard Disk?
Thanks in advance.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Well,you can install any size you want and make sure you reboot from the cd rom when you reinstall the disc toshiba are hard to reboot sometimes unless you have the reboot disc .. lala linda
Posted on Jun 03, 2008
When i tried to reboot the toshiba laptop to factory the HD came up black and the mouse pointer was visible, but the windows reboot would not start. HD failure?
Go to BIOS setup and check out the mode of the hard disk use. Usually must be AHCI, sometimes IDE. Every change after installation makes Windows unusable.
Feb 01, 2014 | Toshiba MK3263GSX 320 GB SATA Hard Drive
New hard disk problem
Unplug , remove battery, reseat the HDD, plug in, reboot. Is the HDD new? If no remove and test.
Mar 11, 2013 | Computers & Internet
Hi, I have a segate barracuda 7200.9 160 gb hard disk which was working fine with my desktop but when i am connecting it to laptop thorugh USB it is showing in device manager as portable media.. showing in...
I would suspect that Windows is screwing things up, your laptop cdrom drive should be "d" drive and your portable usb drive should be the "e" drive. You could try to change the usb to "e" in disk management, failing that I would reboot the laptop with usb drive connected to see if Windows straighten things out.
May 14, 2017 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
This is my suggestion for you to possibly recover the back up file in your external hard disk.
Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I have a Toshiba (MK4004GAH) 40 GB Hard Drive which was taken out from a Old Toshiba Laptop. I bought a 1.8" IDE casing with USB and connected to my new laptop....however, it fails to detect the HDD....
You have to make sure that you have connected the HDD in the right way. Please open it and ensure that you placed the disk rightly into the casing with each pin tapping the rightful hole, see the casing's small manual. Note also that the laptop has to detect the casing as well, so cross check the casing to ensure that its working.
Dec 03, 2010 | Toshiba (MK4004GAH) 40 GB Hard Drive
Disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Mar 30, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Hard drive failed - replaced 60GB with 250 GB M35X can't format
Does your BIOS recognize the new hard drive?
Are you reinstalling from a Toshiba recovery disk or an operating system disk?
Additionally, there is a setting in the BIOS to turn on or off ACPI function for the hard drive. Find this in the BIOS, change it, and try reinstalling again.
When it works, be sure to change it back after installation.
Good luck.
tony
Jan 30, 2009 | Toshiba Satellite M35X-S109 Notebook
Hard disk capacity increase
yeah you need to replace the old hard disk to new IDE 120GB hard disk.
Jan 20, 2009 | Toshiba 100GB Laptop for Satellite 2400,...
Hard Disk hangs
You have to give it for reairing or buy a new hard disk..
Aug 22, 2008 | Seagate Barracuda (ST380215A) 80 GB IDE...
Hard Disk Toshiba MK1646GSX
Change setting to SATA as this is a sata/300 drive.
Jul 10, 2008 | Computers & Internet
Computers & Internet Logo
117 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
