Question about Acer TravelMate 2700 Notebook
My laptop will not turn on it just makes some beeping sounds
    President:
  • 739 Answers
Ok. normaly beeping error is hardware problems. check your ram ( use the eraser to rub the surface of the copper circuit at the ram, or you can use the new ram to do troubleshooting.)
Posted on Dec 31, 2011
Samsung R519 irregular beeps on startup
check your ram it could be faulty.or over heating,check and make sure your fan is running.if its the fan get a hoover and clean it out.
Apr 29, 2014 | Samsung R Computers & Internet
I have dell power edge 1900, it can not display even though the power turns on well
you must take note to the beep of your laptop. when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max. if it dose make the beep then try to connect a normal screen to the laptop.
Oct 26, 2013 | Computers & Internet
How to remove beep sound after the system sound?
the beeps ate called post
Then what happens does it restart ? or just wont boot up ?
A bit more information please.
Not sure what you mean by 'when the hard drive beeps
does the hard drive start when you turn the laptop on
(at which point a do the beeps occur a single beep isn't unusual) and it stops when you turn the hard drive off - a beep then would be unusual.
I suspect you don't mean that, & if the laptop is working fine otherwise then I wouldn't worry about it or do you mean something else completely?
make sure the ram modules have secure seatings also check all power and data leads attached from motherboard to hard drive the same will apply for your graphics card
hope this helps
Oct 10, 2012 | Computers & Internet
My acer aspire laptop makes a beep sound when swith on button is pressed
beep are of manyh types how many beeps it gives?????? reply me fast so that i can help u
Jul 06, 2012 | Acer Computers & Internet
I have Dell Inspiron 1440 Laptop. I am using it fop almost 2 years. But recently there is a problem when I turn on my laptop. At the start up I hear a continuous beep (beep-beep-beep-beep-.....beep....)...
I would check to make sure that no keys are stuck down, if they are they oveload a buffer in the computer and the beeping will drvie you crazy. Get some compressed air and blow under the keys or you can vacuum them sideways don't do it straight down or you'll **** the keys off :)
Aug 25, 2011 | Computers & Internet
My D600 beeps when I first push the power button. It beeps about 2 times and then 4-5 times. It then goe ahead and comes up Thanks
sounds like a key is stuck on a keyboard. Rub your fingers all over the keyboard to make sure none of the keys are sticking. Then go ahead and turn on the laptop and see if the beeps stop. If that doesn't work, then disconnect the keyboard completely and turn on the laptop and see if the beeps stop and the laptop turns on.
If those two things don't work, unseat the memory and reseat it back into the slots one at a time and turn on the laptop after each reseat.
The beeps should go away and if they don't then you know the motherboard is starting to go bad.
Jan 04, 2010 | Dell Latitude D600 Notebook
E6500 making a beeping noise
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
Dec 11, 2009 | Dell Latitude E6500 Laptop
Spilled soda on eeepc 1000ha cleaned and dried interior but now will not complete boot and makes a continus beeping sound
Liquid damage is usually fatal. It maybe that the beeping sound is a keyboard key that is stuck on. It sounds that, at the very least, you will need the keyboard replacing, but I wouldn't like to say that was all. Don't get your hopes up!
Nov 19, 2009 | ASUS Eee PC 1000H Laptop
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
3 beeps at start
hmmm...that's not good. works fine with no battery. I suspect your motherboard may be taking a vacation from working soon.
got backup for your HP?
Feb 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Acer TravelMate 2700 Notebook Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
