Question about Dell Dimension 4600 PC Desktop
No sound with new Vizio 22" LCD TV being used as monitor
We could not get any sound out of the RGB and audio connection with our Dell Dimension 4600 desktop when we hooked it up to a brand new Vizio LCD TV. My work laptop (also a Dell) worked beautifully with the Vizio, but the desktop won't playback any sound whatsoever. We've tried the basic headphone jack for a CD playback on the Dimension and now it isn't working either. Could this be a sound card problem?
  • melb-caudete Mar 06, 2009
    baier 26 inch lcd connected hdmi to desktop comp no sound
  • calsabree Apr 15, 2009
    no sound coming from Vizio LCD TV being used as a monitor
    Sergeant:
  • 284 Answers
You have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
Posted on Jun 03, 2008
Can a vizio monitor be used with an apple G4 desktop computer
Oh wow guess I was proved wrong! But I read here that alot of people were having problems, my only concern is if the computer has a pc mode that can use hdmi or mini display port. If not you may have to mess with the settings to get a good picture.
g4 led
May 24, 2012 | Vizio E220VA 22 inches LED-backlit LCD LCD...
Are you able to use the VIZIO 47" Class 1080p 480Hz SPS LED Backlit LCD HDTV as a computer monitor and use a wireless keyboard and mouse to browse on a pc through rgb and speaker jack?
Yes, all new TV's of 1080p specification will have a dedicated PC connection (and should have either a 3.5mm audio socket or 2 x RCA inputs for audio).
The most common way is to use a VGA lead (with 3.5mm audio lead) - VGA out of pc to VGA in of TV. 3.5mm audio output of pc (ie headphone socket) to 3.5mm audio input of TV.
You will just require the correct VGA lead long enough to connect to your pc.
The wireless keyboard and mouse will need to be connected to your pc, and must be within "line of sight" to the wireless receiver.
If you specifically want to use pc output to RGB input (and RCA audio in) of your TV, then you will need to obtain a long VGA to RGB conversion cable, plus 3.5mm audio lead. Have a look on Ebay for a coversion cable.
Cheers,
"Please take a moment to rate this solution with a 'testimonial' and/or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you."
Jul 31, 2011 | Televison & Video
How i am connect Wi Fi or internet to my TV.it is vizio and model number is J V 50 P HD TV 10 A. and Serial number is PHLANCJ2804679. I WANT CONECT WITH INTERNET FOR NETFLIX PLEASE LET ME WHAT CAN I DO.
As I type this, I am using my Vizio 50" plasma. All you need to do is ditch your current monitor you use for your internet service and use the same cord from the monitor to plug it into your RBG port on the back of your tv.
Next for sound there is a 1/4 jack next to the RGB port on your tv. Connect your tv to your audio out on your computer. (headphones or aud out)
Select RGB on your tv, and your good to go. I bought a wireless keyboard and mouse for my computer which makes it more convenient.
Apr 19, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
I hooked up my vizio 22" tv up to my laptop
Check the tuner i/o board connector there might be a loose connection from the soccket.
I/O board means input output board, this is where the antenna and audio video input are pack in.It is just inserted at the socket..check whethere the connectors are lock properly
Jan 30, 2011 | Vizio VA220E LCD TV
Extended Desktop on Dell Dimensions 4600
yes your right..leave it set to AUTO BUT ONLY USE THE ATI CHIP SET VIDEO CARDS.
Dell Dimension 4600 We saw great image quality from the 17-inch E171FP analog LCD monitor that accompanied our review system. Text looked sharp and evenly focused at all sizes, while colors appeared lifelike, with evenly saturated tones in our photo test screen, in a DVD movie, and during a session of Return to Castle Wolfenstein. As part of a new case design for Dell's midrange Dimension line, the 4600 has eight USB 2.0 ports, more than on most value (and some power) systems: six on the back and two up front. An audio port for connecting headphones sits next to the front USB ports.
The compact 4600 does not have the tool-less accessibility of its predecessor, the Dimension 4500, although opening the case is easy: Just depress a thick L-shaped lever and lift off the side panel. You'll need a screwdriver to add a PCI card or a hard drive; unlike the 4500 series, which secured expansion cards and drives with innovative quick-release mechanisms, the 4600 series uses screws. Our test configuration had only one available drive bay (a vertically mounted internal bay), and it's a struggle to use it. You must remove four screws (two on the bottom of the case and two inside) and take out the bay holding the existing hard drive along with the empty bay that's crammed up against the front of the case. The two open PCI slots are reasonably easy to access, but to reach the two open memory sockets, you must push aside a snarl of data and power cables.
The Dimension 4600 we tested came with a 2.8-GHz Pentium 4 processor and 512MB of DDR400 memory. It earned a PC WorldBench 4 score of 122, about average for similarly configured systems. The ATI Radeon 9000 Pro graphics card is not a top-of-the-line board, but it yielded solid frame rates in our gaming tests. And it's perfectly fine for playing games at moderate resolution, especially considering that the bundled LCD monitor won't display anything higher than 1280-by-1024 resolution. It has a combination DVI/analog-out port (you use an adapter to hook up an analog monitor), plus S-Video-out and composite-out ports to output video to a TV.
Please leave comment and feeb back.
Thanks
Feb 24, 2010 | Dell Dimension 4600 PC Desktop
Connect and operate audio and video from Toshiba A215 4747 laptop PC to Vizio 32" TV for listening and watching internet on TV
Connect the Toshiba A215-S4747 to the Vizio TV by using either the Standard RGB (monitor out) port or the S-Video out. Use the headphone output port for the audio.
Jan 27, 2010 | Computers & Internet
I can not get TV to pick signal from PC
I had a problem where my VO22L was giving me a "No RGB Signal" "The Power Will Be Turned Off" message when I had it in RGB mode (with VGA input from my PC). Anytime I left my PC on and turned off the power of this unit, I got this message. I just got off the phone with a very friendly and patient Tech Support woman at Vizio, who talked to several different techs who all came up with things that didn't help. Finally, while we were talking, she came up with the idea of going into the settings menu and doing a "System Reset" to see what happens. What do you know, it worked!
To anyone else having this problem, try this. With the PC and TV on, in RGB mode, go into the menu screen with the remote. The far right tab is "Setup". Use the arrow keys to go down to the "System Reset" option. When prompted "are you sure" select "Yes". I powered the monitor off and on, and the problem is gone. Now if it happens again, I know what to do.
Apr 08, 2009 | Vizio VO22L 22 in. LCD TV
I bought a connector that you would use for an ipod but, I still have no sound. On the back of my Vizio TV...where the RGB cable is hooked up, there is a small headphone size jack there. Is that the one...
Clarifying...
You are trying to play audio from the TV through your computer?
You need an adapter cable that has an 1/8" stereo phone plug on one end, and two RCA male jacks on the other end.
The RCA connectors are to be plugged into your RV using the AUDIO OUT jacks (usually red/white) and the small plug goes into the auxiliary or line in jack on the back of your computer.
Then, Double-Click on the volume icon in the system tray (this should bring up the system mixer), unmute the line in sound if it is not already and run the "slider" control for that input up about half way.
then, Tune the TV to whatever channel or input you wish and adjust the volume level on your computer to a comfortable listening level.
Rob
ps. Some TVs don't use fixed level audio outputs, and the volume will vary as you run the volume up/down on the TV, too...
Mar 06, 2009 | Dell Dimension 4600 PC Desktop
Extended my monitor to a Vizio 37" LCD TV Echoed Sound
You have an HDMI connection on a Thinkpad T20???
Per definition, HDMI is supposed to send video and audio data from the TV to the PC -so, yes, it should work.
I say "should", because I tried to hook up my PC that way and I went back to a VGA connection (and sent the sound to an old stereo), because the resolution was awful.
I rather think that the audio cable is the culprit here - if the connectors are not fitting perfectly, they can create a lot of distortion.
Also check your audio settings on the PC (updated driver, settings not on maximum volume, etc.)
If you want to try HDMI, there is no need to get the ultra expensive "Monster" cable. Look here for an example.
Feb 24, 2009 | IBM ThinkPad T20 2647 Notebook
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
Dell Dimension 4600 PC Desktop Logo
2,243 people viewed this question
Alun Cox
