Question about LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone
My screen shows dust build up .. between layers of the screen Maybe between the casing and the screen itself. How can i clean it many thanks
  • 410 Answers
U can clean it by going to a mobile repairing shop.and ask them to do so........they will unscrew it and clean it......
Posted on Oct 16, 2010
We relocated our Sullair 3700 about 30m from air receiver, due to excess dust. Now the compressor never stops running, trips on high pressure yet the receiver is not achieving the pressure required
would say dust has done something to do with it
before you had time to move it
will need the compressor serviced
first ..in simple words
to replace the compressor pressure shut off /turn on valve
that should fix the pressure trip build up limit problem
and maybe a partial strip down to clean out the casing
if dust build up is noted
Oct 14, 2016 | Sullair 350 Air Compressor; Sullair...
Evedure heater difficult to turn OFF. Touch panel doesn't seem sensitive any more.
Spray glass cleaner on a rag or paper towel..not on the touch screen...wipe the touch screen down and clean it. Touch screens often build up a layer of the oils on our fingers which then traps dust and dirt making them less sensitive.
Aug 09, 2016 | Heating & Cooling
Samsung tv model LNS3241DX flickers
I'm not sure of a jumper wire to cut, but one of the first things is to clean out the dust that has accumulated on the electronics. You can blow out the back with compressed air or disassemble the TV case and dust it. Sometimes a layer of dust can cause excessive heat to build and shut off any type of overload circuit. Good luck!
Dec 18, 2013 | Samsung Flat Panel 32-inch 720p 60hz...
I have observed shadow at the upper right corner on the screen & how can I clean the inside part of ambilight from dust? Pls give me your recommendations.Thanks. (P.S:TV type philips 32pf9830/10)
You will have to take off the lcd panel itself and then take the panel apart.
There are multiple layers of plastic that illuminate with the ccfl bulbs.
Find the layer with the dust issue and clean with ammonia free cleaner.
You will need to have a dust free environment to do this, or it will only make the problem worse as you attempt to pull the plastic panels apart.
Goodluck...and please rate!
Apr 19, 2011 | Philips 32PF9830 32 in. HD-Ready LCD...
I want to take my dell inspirion 1501 apart to clean fans and I can not figure it out it keeps overheating
There is one particular spot where dust builds up in a thin layer between the heatsink and fan on the inside. However if this laptop is just sitting a carpeted or cloth surface it can very easily heat up quickly eventually to the point of over heating, I would suggest never setting any laptop directly on a flat surface, try and find something you can lift it up on like two books on the sides of it. No matter how much you clean it out, you will still have heat problems. Maybe suggest getting one of the cool pads, try this maybe by thermaltake. http://www.google.com/products?q=thermaltake+R15ON01&hl=en&scoring=p
Nov 01, 2009 | Dell Inspiron 1501 Notebook
Over heatng and shuting down
Computers will shut themselves down when they overheat in order to avoid damage.
Try pulling the battery out and seeing if it works better. If it does, then replace the battery.
It could also be that the CPU heatsink has fouled. Either the heatsink grease is bad (provides a good connection between the CPU and the heatsink itself). Or there could be a insulating layer of dust between the fan and the heatsink.
-=/ Daft Tech /=-
Oct 27, 2009 | Computers & Internet
My cpu overheats
clean the cpu cooler slots and replace the thermal compound on the cpu ....make sure you clean off the old thermal compound .....only a thin layer of new thermal C will do all most see through ... hope this helps my friend
Oct 25, 2009 | Gateway 504GR PC Desktop
Aspire 9500 just shuts off
Maybe it needs cleaning for better ventilation or the CPU fan may be faulty. You will need to have those checked.
Thanks,
Lolita
Mar 02, 2009 | Acer Aspire 9500 Notebook
Just powered itself off
It will shut off if your bag is full. If you are cleaning up fine dust, it will give a false bag full indication. Take the bag out and carefully, shake it down to get the dust out of the filter layers inside. This will let more air flow through the sensor.
Nov 20, 2008 | Electrolux UltraLux 2000 Bagged Canister...
52" rca model #p52930bl
The plastic screen itself never gets dirty on the inside, unless a spider has taken up residence nearby. What you are likely experiencing is dust built up on the CRT lens and mirror - which would cause the picture to look dull with low contrast and brightness. If that is the case, you may find on your model that the screen either pulls out or that there is a wood piece at the bottom that is hiding some screws or maybe the speaker grill needs to be removed to expose said screws. Be gentle cleaning the mirror, as it is surface coated and could be scratched easily.
Dec 26, 2007 | RCA D52W19 52" Rear Projection Television
LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone Logo
35 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
