Question about Kodak ESP 5 Printer
Error code 3508 appears after replacing coulor ink cartridge,saying new ink cartridge is empty.Tried following screen instructions lots of times ,to no avail.
SOURCE: Overiding Empty Cartridge error for Dell A10 962
Hit the options button (just under the digital display on the printer) (and between the two arrows) 10 times. The hit the +arrow once to change. Go through the change motions again and you should get a new ink read.
Jim
Posted on Jan 20, 2008
Mix-it-up
  • 832 Answers
SOURCE: MFC 210C Ink Problems
Steve,
did you watch the display after replacing the cart?
Very often the machine asks if you have changed the cart and demands an answer (1 for yes).
You can try to do an update of the firmware, too. Go to www.brother.com , choose your country and then your machine. Download a small update tool and run it.
If it aint getting better:
Do unplug from power outlet (even though you have done already) wait 10 Min. leave scanner cover open and take all carts out. Plugin to power again and leave scanner open. Wait uintil machine gives a warning signal. Reinsert carts and close cover: now watch the display and give always the answer YES(1).
Posted on Mar 04, 2008
  • 8 Answers
SOURCE: Dell 926 Printer ink refill instructions
i want to know how many contanners the printer users.
i don't have this type of printer, but this is waht you are going to do. take one of the empty cartridge and scratch the nuzul on a what peace of paper. this in most cases will give you small lines which you can use to identify the colour.
if you can do this it will help you
go to a shop with the printer number, where they sell printer cartridges. Tell them you want one of the cartridges, if they have take a close look at them and tell you will came back later but ask them how you will know the black ink since you want to buy that one.
in this way you can identify the two
thank you
Posted on Nov 14, 2008
SOURCE: Kodak Easyshare G600 printer dock problem!
I HAD THE SAME PROBLEM. tALKED WITH THE KODAK TECH LINE AND THEY TOLD ME TO...TURN OFF PRINTER, HOLD TRANSFER BUTTON AND LEFT ARROW DOWN AT THE SAME TIME AND TURN THE PRINTER ON. DO THIS THREE TIMES. iT WORKED FOR ME. GIVE IT A TRY.
Posted on Nov 27, 2008
professor_sc
  • 180 Answers
SOURCE: ink cartridge problem! The following ink cartridges appear to be missing or damaged.
Solution :
1. clean the ink cartridge contacts both in the printer and the cartridge with a lint free cloth or a cotton swab. and try inserting the ink cartridges again. if it wont work proceed to step 2.
2. unplug the power cord at the back of the printer
3. press and hold # and 3 keys at the same time and plug the power cord back in. Do not release the two keys. wait until the printer would say "partial nvram reset" or anything that says "reset". if this still would not resolve the problem
4. do the same process as 2 & 3 but instead of # and 3 try # and 6. instead of saying "partial nvram reset" it should say "semi-full nvram reset". and if it would not work better go to an onsite technician. but if your printer if brand new return it to the retailer and exchange it. but before you do that try calling HP technician they would instruct you to the things i have given you. Just tell them what you have had done and asked them to replace the ink cartridges. This are the informations the agent would ask you about the ink cartridge
part number and also the expiration date.
try to ask for a replacement first if it would not resolve it. then go to a technician. I could not assure you that a technician could fix it because i have troubleshoot this kind of problems and there are alot of printer parts that needs to be fixed. Usually i suggest my clients to buy a new printer instead
Posted on Mar 07, 2009
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
Www cartridgesupport com
What could have happen was that you refilled it when it was emptied dry, usually this spoils the cartridge. I would recommend you buy a new one and when its about 80% empty that's the time to refill, not after.
May 07, 2013 | Used Hp Photosmart C4780 All-in-one...
Help me please, i have new HP j3508, but when i install new cartridge into my HP 3508, the message on the screen says :"Cartridge Error" cartridge on right is not intended for this printer... help me
You need to remove the cartridges, see to it that the colored cartridge are olaced in its right location the same as with the black cartridge to avoid an error.
Jan 09, 2013 | Office Equipment & Supplies
HP7280 printer replaced color ink cartridge but still says low
This would appear to be a defective ink cartridge. As far as I am aware this printer will not let you continue if it thinks the cartridge is empty. I would contact your retailer to arrange a replacement.
Nov 20, 2012 | Office Equipment & Supplies
Advent resetting ink levels
Hi There
Your all-in-one printer is designed to stop printing before quality is compromised. Make sure you always use KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to the KODAK Store.
To resolve the error, replace the black ink cartridge with a new cartridge:
  1. Turn on your printer.
  2. Open the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers, if the ink cartridges don't move to the center when you follow the instructions on the LCD screen, see Printhead and ink cartridges do not move to center with access door open.
  3. When the printhead stops moving, pinch the latch on the black ink cartridge and lift it out of the printhead.
  4. Remove the new black ink cartridge from its bag.
  5. Remove the protective cap from the black ink cartridge.
    CAUTION: Insert the ink cartridge immediately to prevent the printhead from drying out.
  6. Insert the black ink cartridge into the printhead.
  7. Press down on the tab until you hear a click.
  8. Close the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
If the error continues, upgrade the firmware for your printer:
  1. Press the Cancel button on your printer to clear the error message. (If the error does not clear, contact us.)
  2. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
    2. Follow the instructions to install the firmware.
  3. If the error continues, contact us.
Support Link :
Mar 29, 2012 | Office Equipment & Supplies
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Nov 15, 2008 | Dell 962 Photo All-In-One InkJet Printer
Replaced ink cartridge printer continues to say no cartridge
you need to follow the whole procedure on your to ensure proper installation as soon as you install the new one, follow the instruction on the screen to calibrate your new ink
Nov 08, 2008 | Brother MFC-440CN InkJet Printer
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
I would take out both cartridges and put them in again. Realign the printer and the error codes should remove themselves. Try turning the printer off and on before puting the cartridges in again. That may make a difference. You can let your computer know not to tell you when the ink is low too. Let me know how this work for you.
Cynthia Charczenko
Dec 26, 2007 | Dell A940 All-In-One InkJet Printer
Kodak ESP 5 Printer Logo
744 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
