Question about Samsung L74 Wide Digital Camera
My L74 wide camera caught a bit of sand while in a jacket pocket and now when i try to turn it on the lens are jammed. Is there a way to unscrew thelens and get it clean at home?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 16, 2010
Testimonial: "Still haven't fixed the problem, but it shows visible improvements. Thanks for the tips!"
The lenses don't want to open
Sep 17, 2010 | Samsung L74 Wide Digital Camera
Was shooting with Canon PowerShot S3 IS and the lens won't retract,screen says lens error,restart camera. I have restarted camera, changed batteries etc... still nothing. You can hear a clicking sound like...
The lens mechanism had probably got some dust, sand or grit jamming it and stopping it from retracting. Sadly the lens will be difficult to repair yourself as it needs to be completly stripped from the camera. Find a good repair shop and get a quote locally.
Feb 08, 2010 | Canon PowerShot S3 IS Digital Camera
Camera digital lens wont contract in.
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Jan 28, 2010 | Samsung L74 Wide Digital Camera
I Turned on my samsung l730 camera and the lens got stuck and the screen just went black and the lens wont retreat and the only way i can turn the camera off is to take the battery out
what i did was i took off the front cover of it, turned it on while twisting the lens, and it came free. i used a screwdriver from a tech deck :)
Nov 22, 2009 | Samsung Digimax L730 Digital Camera
My camera won't stay turned on
Its possible that dirt, sand had got stuck between your lens barrel and the body and that why the lens is giving you problems.
You can try some of the following solutions to help you out:
1).Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
5: Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. Dont try very hard please.
Try the above and let me if its any help.
If the above does not help. Then you would need to take it to the nearest service center.
Mar 08, 2009 | Kodak EasyShare M1073 IS Digital Camera
Lens error 122,1,0,0 the lens is jammed and will not go back into the camera
Hi!
Try these prcedures--
1)  Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
2)  Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
3)  Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Try above procedures one by one. If first one fixes the problem then don't do the other procedures.
Thanks for using Fixya Utilities.
Rylee
Feb 21, 2009 | Kodak Easyshare M753 Digital Camera
I have a Cannon Powershot SD600, just got it recently and it worked great, then all of a sudden I noticed the cover lens's that slide over to protect the lens when you shut it off were messed up. Onle 1...
The Canon series are fine camera's, but they seem to suffer from lens errors (check how many people suffered from this by googling lens error canon).
The problem seems to come from sand/dust entering the body and jamming the lens gear. A handy person may be able to fix it, but I think Canon should have designed an enclosed lens gear so sand/dust can not enter.
Camera's are commonly carried in pockets, so it is logical sand and dust can be expected.
There are some issues with getting perfect focus in some situations.
Jan 03, 2009 | Canon PowerShot SD600 Digital Camera
Lens retracts with difficulty
1. Do you have a camera case?
2. Or do you not?
The dust fibers from the case might have gotten into the cracks of the lens causing it to jam. So everytime it retracts, it jams. That's what i'm guessing. My old camera got jammed from sand grains on the beach.
- Take a thin strip of paper, and insert it in the cracks of the lens and circle around the lens and find any dust or anything. The paper slip should come out a bit dirty if that's the issue.
- Gently nudge the lens around, until you hear a click. The lens might have jerked into another position from the inside.
Aug 08, 2008 | Canon PowerShot SD600 Digital Camera
Lens jammed with sand
This does not get fixed - throw it away and buy a new one.
Aug 03, 2008 | Olympus FE-280 Digital Camera
Power
To my regret,it seems like a problem with the lens servo motor.The lens unit can become damaged if it's opened while it was in your pocket, or in its case. The power button gets pressed and the lens attempts to extend, the lens gets jammed and the servo motors is damaged. This problem should be repaired by a certified technician. Ask first for repair cost quotation. Good luck !
May 26, 2006 | Kyocera Finecam S3L Digital Camera
Samsung L74 Wide Digital Camera Logo
79 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
