Question about IBM IntelliStation Z Pro 6223-42U PC Desktop
I have this on PC: 1806: PCI/PnP Error ! Resource Conflict - PCI in slot 03 Bus:02, Device:0C, Function:00
2 Suggested Answers
SOURCE: I am getting an Error 1806: PCT/PnP Error!
u have to select proper restore point that generated before ur problem was begun.... i hope it will solve ur error
Posted on Nov 28, 2009
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
I have an Acer Aspire 5100 with Vista Home Premium on it...when starting the laptop acer 5100 it tries to start beeps...and it shows the following page of errors Bus 06, device 02 ,function 00 error...
It might be possible some kinda a BIOS corruption. Let us try this first. ASA computer starts keep on tapping F2, it will enter the BIOS setup utility, then press F9 and then F10, save the seeting and restart the computer. It should resolve the issue. But if the issue still persists, then update the BIOS. Visit the webiste mentioned below:
http://support.acer.com/drivers_download.aspx
Select the model and update the BIOS.
May 07, 2010 | Acer Aspire 5100 Notebook
I BOUGHT A USED ASPIRE 3100-5100 MOTHERBOARD AND GET THIS ERROR WHEN IT TRIES TO BOOT. ERROR Resource Conflict ? PCI in slot 03 Bus:06, Deice:01, Function:00 ERROR Resource Conflict ? PCI in slot 03...
You should try clearing the cmos battery. It's a small battery on the motherboard that can be taken off. Take it off for 20 minutes and put it back in. Then boot up again.
May 03, 2010 | Computers & Internet
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
check for an update of bios on acer.com it will fix your laptop problem....
Apr 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
IBM IntelliStation Z Pro 6223-42U PC Desktop Logo
1,087 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
