Question about Refrigerators
I have a Husqvarna Safir Freezer about 5 years old and the :"attention light" (at the far end on the top just started blinking and sounding an alarms....what does this mean as I do not have the manuals for the freezer or the frdige. Many thanks Cathy
  • 958 Answers
SOURCE: Kenmore refridgerator 78285892 Freezer light won't work
probably a bad socket. 10-12 years old metal would not likely to last inside a freezer box.corrosion could have eaten the metals...
Posted on Feb 12, 2008
  • 61 Answers
SOURCE: Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Posted on Oct 20, 2008
  • 1462 Answers
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Posted on Nov 17, 2008
rpbuice
  • 161 Answers
SOURCE: Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Posted on Dec 22, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
GE Profile Side-by-Side Refrigerator - Freezer Warms Up - Motor Gets Loud - Eventually Cools Back Down
Sounds like your thermostat is faulty this should be covered by a warranty This problem eats electricity so will need attention asap
Oct 29, 2012 | GE Profile PSHS6MGZSS Side by Side...
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
This refrigerator starts "Banging" sounds
This sound like one of the fans is hitting something.
One fan is in the freezer behind the back cover probably near the top.
Another fan is around back behind the cardboard cover. It blows air out the back and you can probably see it without removing the cover. Since this one is near the compressor it's most likely the one.
Feb 06, 2011 | KitchenAid Refrigerators
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Lights blinking and beeping
Have seen that on certain controllers before. Very possible your temp. sensor is open circuit or out of spec. or not making proper contact on the wiring harness. You would need a digital thermometer to check the sensor.
May 14, 2010 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on but the rest seemed ok. Today noticed a puddle from thawed meat. Sounds like...
Good day,
Serious problem. Either there is a freon leak or a restriction inside the tubing that carries the refrigerant.
Needs the attention of a pro.
Note. If the unit is under 5 years, leave it alone. It is still under factory warranty. Call for warranty service.
May 12, 2010 | Freezers
Water goes into machine but woun't spin after about 5 minutes th 5 far right lights start to blink wait a minute hit start button everything works fine. kenmore front load 5 years old
This could be a few problems - from the timer to a pressure switch - to a bad lid switch.
Please reply with the exact model # for a more exact answer.
Thanks!!
Mar 22, 2010 | Kenmore Washing Machines
My 5 year old Huskystar 216 sewing machine is
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Jun 22, 2009 | Kenmore 64802 Top Freezer Refrigerator
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
299 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
