Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool Gold GS6NBEXRB01 - While Auto-Defrosting, the water drips into freezer from inside Grill
I have about 1 and Half year old Whirlpool Gold GS6NBEXRB01. Everything works fine except that While Auto Defrosting, the water slowly drips into the freezer through inside grill. Please help me find out what is the problem here. I have attached some pictures.
Thanks
Venkat
  • Anonymous Mar 15, 2014
    It is a two door refregirator,itis almost 12 years and it still working good,only there is water coming out.
    Please help
    President:
  • 1,314 Answers
You have a frozen or blocked defrost drain behind the back panel with the vents in it remove the panel and clear the drain at the bottom in the silver pan
Posted on Jun 03, 2008
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water dripping down the back of the inside of our ET22DK/DM
your drain in the freezer is blocked. try defrosting the freezer. if that does work call your local repair company.
Jun 19, 2010 | Whirlpool Refrigerators
Water dripping into refrigerator from freezer
Drain in freezer is clogged usually with ice. Unplug frige and defrost 6 hours with doors open. Pull lower front grill and check drain pan for water. If no water remove rear panel inside freezer to clear drain hole, below coils in the middle...
Mar 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
3 year old left freezer door open for 15 minutes now freezer and fridge don't get cold
Unit more than likely iced over. Unplug the unit and place a fan blowing into the freezer section for about 2 hours. You must remove the contents of the freezer section when doing this. This will make a dripping water mess so be ready with a mop and rags to tend to the drips as needed. When the drips cease you are done with your manual defrosting drill. Plug your uint back in and return it to normal service. If after 2 - 3 days the problem repeats then your unit is not defrosting and will require further service.
Jan 06, 2010 | Whirlpool GS6NBEXR Side by Side...
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Water inside the refrigerator
check the drain almosr definately blocked with bits of food or ice.
Jul 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer defrosting
you have a defrosting issue for sure, you neeed to unthaw the freezer coil first and then find out if the defrost heater the defrost timer or the defrost bimetal is the issue one of these three parts is bad
Apr 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
668 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
